Question about Linksys EZXS55W EtherFast 10/100 5-Port Workgroup Switch (12503060)
Can u help me retrieve my wifi password?
I have the 10/100 5-port workgroup switch model EZXS55W
and i forgot what my wifi password is.
how can i find it?
or can u send me a new one please?
    Sergeant:
  • 310 Answers
You need to do a factory reset of your wireless router. This should clear the password in it. There is no password for your 5-port switch.
Posted on Nov 18, 2009
How do i connect two computers so they both have the same ip address i have a linksys 5-port workgroup switch will that work ? also i had hooked it up but only one of my computers had internet
They cannot have the same IP address due to the mechanics of DHCP. Buying a cheap 50$ router (not switch) will fix your problem as your internet service provider will see that device as a single unit that it will assign an IP and then the router will give out internal ip addresses so that they can get online. The switch does not have this functionality.
Feb 16, 2011 | Linksys EZXS55W EtherFast 10/100 5-Port...
I want to add a LINKSYS workgroup switch EZXS55W behind my wireless routher LINKSYS BEFW11S4 v2 via uplink cable connection. When hardwiring my anything to the switch port 1-4 does not get internet access
Are those 4 ports in different Vlan ?
If you connect your wireless access point to the 1st port are you able to access the internet through 2nd port or 3rd port ?
Are the ports 1-4 admin down ?
Dec 23, 2010 | Linksys Bundle: BEFW11S4 802.11b Wireless...
I have a Linksys 5-port switch connected to a cox cable modem and I'm trying to use it to connect two computers at the same time. Only one works at a time and I have to reset the switch and modem to get...
Because the cox cable modem will only bind to one mac address (computer). You need to purchase a router, any router linksys, dlink, will do, get a wireless one so you can setup wifi as well. Plug your cox cable modem into the wan port on the router, plug your pc into one of the ethernet switch ports, you can use your web browser IE to login to the router and secure your wifi signal, power cycle your modem to make it bind to the new router. Most linksys dlink are programmed for a class c network, you could in theory put 254 devices, computers on your connection now.
Aug 27, 2010 | Linksys EZXS55W EtherFast 10/100 5-Port...
Ps3 and computer wont go online at same time
upgrade the firmwae if it is of old version...!!!
and give static ips to both in your network address range sio that each one can pass through gateway!!
May 27, 2010 | Linksys EZXS55W EtherFast 10/100 5-Port...
How can i use my PS3 and computer at the same time?
plug in your ethernet cables to the 5 port switch
set the ip addess's up too and it should be able to go
on the internet at the same time,
I have my internet through my cable company and i want two com hooked up but are not going to have them online at the same time so can i use the 10/100 5-port model#EZXs55w by using the line coming out of...
Hello Friend
You could definately use Network Switch-10/100 5-port model#EZXs55w to Connect to Network Router or Modem using Uplink Port at back Panel of 10/100 5-port model#EZXs55w Switch.
Simply Connect Modem cable to Uplink Port of Switch and connect computers to other 2 ports of switch. Allow computers to get Automatic ip addresses..if computers still not getting ip addresses auto--contact cable company and config your cable modem to use NAT or enable NAT--
Oct 10, 2009 | Computers & Internet
Can't get two computes to run internet at the same time
If you login to your router and make sure DCHP is enabled, and then go to Services (services.msc) on your computers and make sure that the DCHP Client is running, it'll automatically assign IP addresses for your computers and they'll both connect okay.
Hope this helps
Chris (ziraffa)
Jan 17, 2009 | Linksys EtherFast 10/100 5-Port Auto...
Help
First, FYI, I hope you mean Switch and not Hub and I am to assume your Router's LAN ports are all in use as to why you want or need the 5 port Switch and that you have Wireless Access Points or maybe your Router is a Wireless Router.
Next, you have to connect your 5 port Switch to your Router LAN port. Next you need a Wireless Access Point device to plug into your 5 port Switch. It would be helpfull that all your devices are of the same name brand also.
Now you have a Wireless network.
Thanks,
podum
Sep 11, 2008 | Linksys EtherFast 10/100 5-Port Auto...
EZXS55W 5-Port Workgroup Switch
This is a wired network switch your inquiring about. Is this plugged into a wireless router?
If so what brand is the router.
Jun 10, 2008 | Linksys EtherFast 10/100 5-Port Auto...
Computers & Internet Logo
333 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
