Question about Western Digital Caviar SE WD1600JS (WD1600JS20PK) 160 GB Hard Drive
The circuit board is fried can i get a replacement for this hard drive ?
  • 691 Answers
Hello
Thank you for using
FixYa for your problem
I am guessing you have important information on the board. Goto your dealer and request the same HD, swap the boards over and then copy eveything to a back up.
Swap the board over again and now setup the new HD in the system
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Posted on Nov 18, 2009
  • 34 Answers
Yes:
Look here
Where can i buy a seagate external drive circuit board to replace one I "fried" by overvaulting my current one?
Spare PCBs aren't usually avaiable as such. Unless something simple like a polyfuse blew on the board, then the original is probably toast. Your next option would be to obtain an identical drive and perform a transplant. But it will have to be identical - possibly down to the software revision.: (You may still have problems as tables of bad blocks are maintained by the controller)
Nov 28, 2016 | Seagate Computers & Internet
Mains short circuit fried drive
There is no way of fixing this hard drive, if you need to recover your data, then there are companies that can recover data off faulty hard drives BUT it will cost you an arm and a leg for their services.
Mar 08, 2013 | Computers & Internet
My Western Digital Caviar WD1600BB 160 GB hard drive in my dvd recorder is making a clicking sound, how do I test to see if it is the heads that are faulty or the circuit board?
Welcome to Fixya. If you are hearing a loud ticking or high pitch noise on the hard drive it means that the hard drive will be defective anytime soon. If you can take out the hard drive and backup the files on you computer and replace the hard drive on the computer. Loud noise can be caused by a bad spindle or the hard drive or the hard drive is frying inside the dvd recorder.
If you have questions please let me know. Thanks
Oct 10, 2011 | Western Digital Caviar WD1600BB 160 GB...
I plugged the wrong power supply (my laptop) into my Simpletech drive and couldn't figure out why just the power indicator flashed but nothing else happened. When I plugged in the right power supply...
It is worth a try. The circuit board of the SATA to USB interface inside the drive casing is definitely fried, but the drive itself could still be alive & usable.
Jul 12, 2011 | SimpleTech SimpleDrive Pininfarina 320GB...
I have an external hard drive that is not working. While reconnecting my computer I connected the AC adapter for the speakers to the Ext HD and the adapter for the Ext HD to the speakers. The output for...
Hello
Yes over voltage will fly the drive, at least the case and the circuit board inside. If your lucky the hard drive itself might still work, you can remove it from the case and connect it directly inside a computer or to another Case. if the drive doesn't work the control board in the bottom of the drive has fried as well.
To recover data you have to send it off to data recovery, or you might be able to use the circuit board from another same model hard drive to replace the faulty board, and it might work, but theres no guarantee.
only surefire solution is professional data recovery where they take the hard drive apart in a clean room environment, remove the discs from inside and put them on another hard drive, you can not do this at home since dust will get on top of the platter and its a goner shortly after that when you power it back on.
Nov 18, 2010 | SimpleTech SimpleDrive Pininfarina 320GB...
My WD3200AAJS will not spin up. I think the PC board is fried. where do i get a replacement for it. I need to get the information from the hard drive.
Just a suggestion;
I would buy another Western Digital WD3200AAJS, remove the circuit board, and install it in the one that needs it.
Copy off the needed info, then discard the drive. Install the circuit board back into the one it came out of, and have a good 320GB SATA Harddrive.
http://www.directron.com/wd3200aajs.html?gsear=1
http://www.iunitek.com/iunitek/index.cfm?fuseaction=shop.dspSpecs&part=1916995
Oct 20, 2010 | Western Digital Caviar SE WD3200JS...
Hard drive not spinning up
Hi you would have to buy a replacement drive that works that is the same as the one you zapped and change over the board to see if you did any other damage to the drive motor or send it to a recovery person which would probably be cheaper in the long run.
peter
Jul 13, 2008 | Seagate (9Y7275557) 400 GB Hard Drive
Western digital wd800
I would look on ebay. A problem you might encounter is that all drives contain spots that can't be written to and each drive has these spots listed in the original circuit. So, if you use a board from another drive, you can imagine that it will be trying to read your drive like it would have read the original drive. You might want to research this more as I am remembering this info from research I did quite a while ago. My memory is a little foggy on it.
Jun 18, 2008 | Jetway MiniQ 765Twin (miniq765twin)...
Samsung 160gig hard drive printed circuit board
try ebay with the same model number. You can transfer the circuit boards, retrieve the data, then you have a spare backup. Otherwise you can try to identify the component and check if digikey or mouser has a replacement. Sometimes if you're lucky the component is a bias diode that is designed to burn out with reversed power. Sometimes the visible damage may not be the only damage and other parts have fried. Touch a grounded object (like the case of your computer that's plugged in) before touching the components, and retouch it frequently, or wear static dissipative wrist strap
http://www.digikey.com/
http://www.mouser.com/index.cfm?handler=home
Nov 30, 2007 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
Seagate SATA 160 GB (ST3160827AS) fried!
Are the logic board model numbers the same? How about year and batch manufature? check on that.
Sep 20, 2007 | Seagate (ST3160827AS) 160 GB Hard Drive
Western Digital Caviar SE WD1600JS (WD1600JS20PK) 160 GB Hard Drive Logo
160 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
