Question about Hitachi 43UWX10B 43" Rear Projection Television
No fuse i bought this tv and there is no fuse right above where the plug goes in.....anyone know what fuse i need to get? if that didnt post the image is here http://i57.photobucket.com/albums/g218/chevytrucks2021/IMG00093-20091118-1607.jpg
  • chevytrucks2 Nov 19, 2009
    okay thanks that got me a solid red light on the front when i power it on and all the lights are on the back now im lost as to what to do
    it makes the sound it flicks off i get no picture but i get like two green lights and one red light on the inside.....the outside just has a solid red light.....then i hear a click noise coming from best i can tell the general area of the lights on the inside and its off until i unplug it and plug it back in
    President:
  • 1,284 Answers
It will be a 6 AMP GMA style fuse.
Posted on Nov 18, 2009
  • Don
    Don Nov 19, 2009
    Do you get anything on the screen at all? Does it sound like you can hear the high voltage charging up the picture tubes in the TV? If not then it is possble that you have a bad power supply board.
I recently bought a 2004 Lexus rx330 and I noticed that it didnt have a USB port. I dont know if Im just not looking in the right spot or if it just doesnt have one. If anyone could answer this, I would...
operators guide
most cars have 3 radio options,
the guide tells you how your's works
you are posted to the honda Accord, section, id bet posting to lexus
might be better, but my answer is correct.
Aug 02, 2013 | Honda Accord Cars & Trucks
ILO TV REMOTE CONTROL MISSING
Go to this webpage.
Here you can buy the original remote contol for your TV
http://www.remotes-express.com/Ilo/ILO2600.html
Jan 12, 2008 | iLO 2600 Television
Vacuum leak in 95 monte carlo
hook up the pcv valve [big time vacuum leak] same with egr valve check for carbon build up and vacuum leak in lines
May 13, 2012 | Chevrolet Monte Carlo Cars & Trucks
I was given a model 6591, plugged it in and it worked but didnt "****" and didnt sound right. I turned it off and removed the hose from the back found a badly plugged hose. Removed the hair...
The User Guide for the bissell Clearview Power Trak
http://canada.bissell.com/images/UserGuides/3590C.pdf
May not be your exact model but should be similar.
The Bissel vacuums include an internal thermal protector to protect it from overheating. When the thermal protector activates, the cleaner will stop running. Should this happen proceed as follows:
1. Turn the cleaner OFF and unplug from electrical outlet.
2. Check the Pre-Motor Filter and Post-Motor Filter for dirt accumulation.
3. Remove any clogs.
4. When the vacuum is unplugged and motor cools for approximately 30 minutes, the thermal protector should automatically resets and cleaning may continue.
5. If the thermal protector continues to activate after following the above steps, your cleaner may need servicing. Call Bissell Customer Service:
http://canada.bissell.com/Contact_Us.aspx
Mar 20, 2011 | Bissell 6591 Power Trak Revolution Bagless...
I have a CLT2054 and lost the power cord. I bought a new power cord but when I plug it in the light on cord goes out and TV wont come on. If I un plug cord light comes back on
You have short circuits inside the TV, the AC goes into shutdown when it senses too much current being draw. Post some pictures inside the TV if you can, wee need to look for short circuits, another thing, you bought new AC adapter with the same voltage and current rating, right?
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Jun 29, 2010 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
Hey guys need some help my eyes i didnt wear my glasses when i installed a new battery on my 1991 yamaha fzr. now i get nothing when i turn on the key. i check the small fuse, is there another fuse im...
Plus wire goes to the start solenoid right? Minus goes to the frame. Do you have power at the Plus terminal? How about the battery side of the solenoid? If you have power there, the next stop is the ignition switch. Check your fuse box.
There is that possibility that you installed a dead battery.
Was this a dry battery when you got it - you did add the SO2? Can you/have you charged it up? Can you volt test it, anything above 11 volts at stop is ok -/- hydro test it, 1200 is a good number
Let me know what happens
Thanks for posting your question at FixYa.com
Nov 02, 2009 | 1991 Yamaha FZR 600
I accidentally unplugged the wires to th epower buttton and need to know how to reconnect
If you do know which are the posts on the motherboard it does not matter which of the two wires goes to which post. typically, the Red goes to the post that is matked (either by a dab of paint or by the fact that the solder at its base is square rather than round.
If you do not know which are the right posts, then get a M/B schematic from emachines
Sep 22, 2009 | E-Machines eMachines Desktop PC
Polaroid 4241-TLXB wont stay on
I think I may have just solved this issue. Remove the back covers and turn the tv on until it the screen goes black. There will be a little red led that will light up when the screen goes black. right above that light there is 4 little swiches, the bottom one is labled BURN. Switch that one to the opposite direction. I don't know how but mine has been working for a couple days now with no issues. GOOD LUCK!
Jul 05, 2009 | Polaroid 4241-TLXB 42 in. LCD Television
S 40 INFO CENTRE LCD NOT WORKING
Were you drunk when you posted this??
Makes no sense at all.
Jun 16, 2008 | 2000 Volvo S40
Hitachi 43UWX10B 43" Rear Projection Television Logo
60 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
