Question about Casio Exilim EX-Z40 Digital Camera
Sony Cybershot 4.1 digital compact camera flas problem
I have a Sony Cybershot 4.1 digital compact camera. I took tousand of pictures with it. For some time, the flas does not work. What can I do?
How to transfer internal memory pictures on a DSCW70
Unlike most brands/ models of cameras, the Sony CyberShot (DSC) cameras feature internal memories, (not enough to hold sufficient data). If you took a few shots before inserting the memory card, the pictures are stored in the internal memory. You can transfer/ delete those pictures by the following steps.
1. switch off the camera,
2 open the battery/ SD card slot cover and remove the SD card.
3. close the cover and switch on
4. press the display/ preview button and your picture should be visible on the screen.
You can now do whatever you want with your picture.
Does this help? Please provide some feed-back if my answers do help.
Sep 09, 2014 | Sony Cyber-shot DSC-W70 Digital Camera
Sony cybershot, but displays neg through lcd
This happened because you are not a camera repair technician. You took a complicated piece of electronic equipment apart without any knowledge of what you were doing. I'm glad that at least, your pics turn out.
Feb 02, 2010 | Sony Cyber-shot DSC-S700 Digital Camera
Recently purchased Sony Cybershot DSCW180. Took 3
Yes, you need to have memory stick because camera has limited internal memory that can store few pictures only.
Put new memory card, format it through camera Menu and copy internal memory pictures to memory stick, take our memory card from camera and delete internal memory pictures either one by one or format internal memory through camera Menu.
Thanks.
Dec 02, 2009 | Sony Cybershot DSC-S950 Digital Camera
Blurry pictures
there is a problem with your hardware in the set.
The IMAGE IC has got a problem. So change it for the best result.
Apr 24, 2009 | Sony Cyber-Shot DSC-T3 Digital Camera
VGA...?
Reset the camera... go to menu-initialize-ok ... like the previous solution... does yur camera after u take the photo say in red "RECORDING" for few seconds?
Feb 17, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Sony cybershot dsc-n1 took 6000 pics and stopped working Screen went white before died with lense extended no sign of power next cybershot DSC-N2 took 15,000 pic and died just refuses to turn on. no power...
no non of sony cameras come with any life pan
ya they are telling something baout life cycle
but i have cybershot with 29000 pic and my friend is having about 20000 so if your cameras is in warrenty period then go to sony service station they will fix it
or if you r out of warranty period then go for repairing your camera probebly changing CCD of your camera will fix this problem
Mar 26, 2008 | Cameras
Auto delete
If you are refering to the pictures you took on the camera before you put in the memory stick, then you took those pictures on the internal camera memory. the camera is set to default on the memory card whenever one is in. To get to the pictures on the internal memory, remove the memory stick and you should be able to view the pictures. To transfer those pictures to your computer follow the steps in the manual, just be sure not to have the memory stick in.
Dec 23, 2007 | Sony Cybershot S650 Digital Camera
Casio Exilim EX-Z40 Digital Camera Logo
32 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
