Question about GE Profile DPSB613G Gas Dryer
My ge gas dryer model# dpsb613gd0ww shuts off after about 5min. I can restart it right away and it does not shut off on no heat cycle.
  • 54 Answers
SOURCE: GE Profile Harmony Gas Dryer DPGT750GC1PL not heating
If you hear the blower ramp up when you start the dryer and it slowly ramps down or quits all together then you need to replace the blower.
Posted on Jul 04, 2008
ngfam1
  • 639 Answers
SOURCE: Roper gas dryer not heating
DEAR FRIEND,
ngfam1 here for you!
I am happy to be of assistance!
CHECK THE LINT FILTER IS CLEAN AND CLEAN IT AFTER EVERY LOAD1
BUT IF THE VENT THAT LEADS OUTSIDE IS CLOGGED IT MAY CAUSE THIS .
IN THE OUTSIDE OF THE HOUSE THERE IS USUALLY A SCREEN AT THE VENT POINT THAT STOPS ANIMALS FROM ENTERING THIS VENT. GO LOOK AND CHECK THAT IT'S CLEAR AND FREE OF WADES OF LINT THAT MAY BE BLOCKING THE AIR OUT FLOW.
THIS WOULD STOP IT FORM DRYING AND GETTING HOT ENOUGH TO DO THE JOB! IF THERE IS A DOOR THAT FLAPS OPEN OUT SIDE AT THIS SAME LOCATION WHEN THE DRYER GOES ON, CHECK THAT IT IS HANGING LOOSELY AND NOT STUCK CLOSED!
OTHERWISE YOU WILL NEED SERVICE!
Here is a good service that I recommend to my customers,
in our 65 year old appliance business! they answer 24/7
Not expensive!
A&E Factory Service
1-800-905-9505 -(IN U.S.A.)
They are open to make appointments 7days/24hours
A&E is factory authorized service for most brands!
Including warranty work!!!
They will help you, and all will be well!
You will be fine now!
Thank You
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF!
Posted on Aug 26, 2008
  • 1028 Answers
SOURCE: Dryer heat shuts off after a few minutes.
replace the 2 black solenoids on the gas valve ..after heat up they sometimes will go bad and burner will not reignite even though the ignitor glows
Posted on Sep 24, 2008
mastatech
  • 478 Answers
SOURCE: gas dryer maytag MDG 7600 AWW Heats - then shuts off
Check the flame sensor mounted to fire tube, its a rectagle with a glass window, also the coil can be replaced on gas valve if they are weak,
You definitly want to check the exhaust vent and vacume.
704-819-6557 for tech help and parts.
Posted on Mar 14, 2009
  • 1122 Answers
SOURCE: GE Six Cycle Automatic Dryer just buzzes when I push start
most of the time when the syary button just busses it means the motor is gone,you can take it apart and clean and lube itmake sure nothing stuck in it,let me know if you need more help-mike
Posted on Mar 21, 2009
GE spacemaker electric dryer PCKS443EBWW. Dryer shuts off mid cycle on timed dry setting. Wait till cool down and will start again. Venting is clear, I vacuumed inside and around motor. Any ideas?!
Mark, Could be limit /over heat/thermal fuse/switch, check or have checked by a good repair Tech., diagnosed and estimate repair. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
What to Check when your Dryer Shuts Off Mid Cycle
Whirlpool Maytag Dryer Diagnostic Shuts off mid cycle not heating...
Kenmore Whirlpool Clothes Dryer Repair The Most Common Problem
GE electric dryer overheating shutting down
Jul 10, 2016 | GE Dryers
I have a Gas Whirlpool dryer model GGQ9800PW3. The dryer stops before the cycle is complete. It can be restarted, but again it will work for a while then shut off. I changed the temp setting from med
Oh oh sorry to say this but sounds like the motor windings are going bad? does it shut off then about 30 to 60 minutes later u can start agin? a bad cycling thermostat or thermistor could be culprit but I doubt that in ur case.
Sep 27, 2014 | Dryers
Ge front loader dcvh515efoww - dryer shuts off when put on heating cycle
Did you pull the dryer out or forward sounds like you may have pinched the exhaust which restricts air flow exiting the unit this will cause it to heat briefly shut down heat shut down and continue this cycle the fact that it worked before makes me think it something simple it will not tumble in any cycle if door switch not installed correctly.
Mar 21, 2014 | GE Dryers
I have a GE DCVH660GH0BB gas dryer.That doesn't heat or sometimes heats for a short while then stops heating.
You will need to check the thermostats on the blower housing for continuity.
Nov 23, 2012 | Dryers
Electric Dryer Shuts Off
During the auto-drying cycle, the moisture sensor could be the problem.
If it also shuts off prematurely during the timed cycle, the operating thermostat could be turning the heaters off before the machine reaches operating temperature. Another possibility is that the operating thermostat does not turn off the heaters at all. When the machine heats up, it gets too hot and the high limit thermostat turns the dryer off.
Apr 20, 2010 | GE DWSR483EB Electric Dryer
DescrI have a GE profile harmony electric dryer model #dpgt750ec1pl. About 5 minutes into a drying cycle the blower shuts down. There is still heat but no air coming out of the dryer duct. Any suggestions?...
you should not have heat when motor stops there is a switch in the motor to shut the element off....yours is not working(you could burn your house)replace the motor.
PLEASE DO NOT TRY IT AGAIN...can't be lucky all the time
Aug 07, 2009 | GE Profile Harmony DPGT750EC Electric...
Heats and runs, but not long enough to dry clothes; then would not turn on and run at all. maybe dryer ''thinks'' clothes are dry?
Hi, After the dryer shuts off, can you restart it right away or does it need to cool down before restarting? If it needs to cool down for a bit, the motor is going bad. If the dryer is running a full cycle but not completely dry, check your venting to the outside and make sure it is clean.
If this is a gas dryer, the coils on top the gas valve might be shutting down early and not reopening later in the heat cycle.
I hope this gives you some direction. Please let me knwo if I can assist you further on this problem
Vic
Jun 13, 2009 | Dryers
GE Gas Dryer Model #dbvh512gfoww heat problems
Hi, It sounds like the coils on top the gas valve are bad. If the ignitor glows but shuts off before a flame, the coils need changed.
I hope this helps. If I can assist you further, please let me know.
Thanks
Vic
May 24, 2009 | GE 7.0 Cu. Ft. Super Capacity Gas Dryer -...
Heat shuts off after a few minutes
Check Replace Thermostat. The Dryer Thinks Its Not Lighting Because The Thermostat Isn't Working.
The Dryer Has A Safety Mechanism So It Wont Flood Your Home With Gas. When The Thermostat Is Broken The Unit Doesn't Detect The Heat And Shuts Off The Gas.
If You Like You CV
Jan 09, 2009 | GE DBXR463EBWW Electric Dryer
Open Questions:
Black marks from dryer My GE Profile dryer which is only about 5 years young is now leaving black streaky marks on my white sheets. I've discovered this only happens on my sheets since they are the only thing I dry on high. I've never seen the marks on any other light colored loads that I do on medium heat. And I could never figure out where the marks were coming from. And regular Shout, laundry soaps, bleach, etc. did nothing to remove them. I had to do two back to back dryer loads on high both full of sheets after company and after the second load I noticed some black residue on one of the upper corners of the door which opens left to right, with this residue on the top inside right of the door. I wiped it off with a finger first and it's more powdery than oily. Reminded me of graphite from a pencil. I took the used dryer sheet and wiped the rest off the door and then looked at the dryer in the corresponding location. My dryer model # DPSR610EG0WT has white plastic edging between the inside of the door and the drum. This powdery substance is coming from both sides of this plastic edging on the top exactly where I saw it on the door. I crammed the dryer sheet in both sides inside and outside of this edging and wiped around it and it was BLACK from this stuff!! I tried some Carbona grease cleaner on my sheets and I thnk that worked for the most part to remove the marks on my sheets. But now I have to rewash and redry them all over again. What is this stuff and what do we have to do to stop it from happening? My husband is a master mechanic from birth (even though he has a white collar desk job) and can repair and fix anything. Now he's listening to me since I told him I'll start drying his shirts on high! Please advise!
Apr 23, 2013 | GE Profile DPSB613G Gas Dryer
GE Profile DPSB613G Gas Dryer Logo
166 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
Sal DeAngelo
Are you a GE Dryer Expert? Answer questions, earn points and help others
