Question about Hobart Food Mixers
V1401 slips in all gears; what to adjust?
V1401 slips in all gears; used to stop/brake when placed in 2nd or 3rd, but seems to be getting worse. Is adjusting the planetary brake something a slightly mechanically-inclined person could do (assuming that will solve the problem)?
  • 640 Answers
Take the top cover off,in front of you is the brake.Turn the mixer on and you will see it spin (put it in 1st gear),stop the mixer.on the right side you will see a pin that catches the brake flange,if its worn you can replace it,if its not worn then the brake needs adjusting as it acts like a clutch.Let me know,im a hobart tech band repair these units often.
Posted on Nov 18, 2009
  • Hobart Expert
  • 119 Answers
You should adjust or repair the clutch, the brake doesn't have anything to do with it.
Posted on Jul 31, 2010
? Wrong rotation ?
as far as the motor you swapped wires on motor switch two wires either two blacks or one black and white
Sep 06, 2014 | Hobart D300 Stand Mixer
Locks up in 3rd gear after rebuild
Jeff your almost there....it must be the shifter into third....it must not slide fully into third....check for wear marks on the worm gear....and try running it without the protective cover on to see how it changes from 1st, into 2nd, then third...that mechanisim if not engaging totally in third.
Dec 03, 2013 | Hobart A200 Stand Mixer
Hobart D300 is stuck in speed 3, any ideas?
Best guess is that the gear for 3rd speed is seized together with it's brass bushing and the center, large transmission shaft. I don't recall which gear is for 3rd, but the transmission has two gears (2nd and 3rd speed) which have brass bushings in them. The brass bushing should spin freely on the center shaft (when in final position - sometimes they pull off the shaft tough, but spin freely when in final position, my opinion is that this is OK), and the gear should spin freely of the brass bushing.
My guess is that the 3rd speed gear, being seized to the center shaft, cannot freely idle on the center shaft, which would result in being stuck in 3rd gear.
Mar 17, 2012 | Hobart D300 Stand Mixer
I have a v1401 and its oil level is low. Where
you can buy @any hobart office in your area.
Jan 15, 2010 | Food Mixers
Hobart d300 spins but slips under load
sounds like you have a sheared key in one of the gears. which speed is it slipping in or is it all 3speeds
Dec 04, 2009 | Hobart D300 Stand Mixer
Hobart v1401 mixer slipping when in 1st gear.
Sounds like the planetary brake needs adjusting or the pin is worn.
Feb 12, 2009 | Hobart Food Mixers
The gear is slipping on my Hobart A200
In what speed is it slipping?You only use 1st speed for dough,right?Can you put it in gear and stop the hook from moving with your hand?Let me know.
Jan 13, 2009 | Hobart N50 Stand Mixer
3rd gear spends at 1st gear speed with clicking noise
A key is most likley sheared on the center shaft.Take the gears off the center shaft.
Oct 15, 2008 | Hobart A200 Stand Mixer
Hobart N-50 mixer clangs on 1st and 2nd speed
CE is the marking that shows its european conformant.  I think the difference is mostly in terms of the no volt interlock switch.  This means the KA style N50 bowl won't work with the CE models - too low.
Jun 03, 2008 | Hobart N50 Stand Mixer
Free standing hobart 30 quart
First gaer is slow one don't add too much.
Mar 03, 2008 | Food Mixers
Food Mixers Logo
385 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
