Question about Dell XPS M2010 Wireless Bluetooth Keyboard
The keyboard has 3 led lights blinking after pairing is attempted and still won't pair with pc.
    Problem Solver:
  • 11 Answers
This isn't a fun solution - the best thing I've come across is to hit both reset buttons (on the computer, and on the keyboard) until both are flashing - pull up your bluetooth settings (from control panel (I've got mine shortcutted into my task bar)), then disconnect the keyboard, and search for a new item - after the computer finds a new keyboard, connect using a new pairing code.
While this might not be the best solution, it works for me, and I don't know of a better one, or quicker!
Posted on Feb 15, 2010
  • 4 Answers
Download the correct driver and firmware update from Dell's site. Allow the process to complete when installing (it will appear to hang)
Posted on Mar 25, 2010
  • 380 Answers
I wish I could give you a solution. truth is, blue tooth keyboards and mice are not a good idea. they fail often, regardless of the manufacturer, and they are unreliable. Sometimes they fail because of sync, sometimes they fail because of drivers, and sometimes they fail for no known reason. If you want my opinion, you are better off buying a nice USB keyboard with a USB port built in (for your mouse), then buying a long USB extension cord and placing it near your 'command center'. Blue tooth keyboards and mice are just not great.
Posted on Nov 19, 2009
Samsung bluetooth keyboard ee-cp905 will not accept the codes that is giving for pairing. I have it plug in thinking it needed to be charged not working. There is a red light that keeps blinking
Simply, it should pair; nothing mysterious about it. So if you can't get it paired, return it to shop, so they should test it and if find it defective, they should give you a new one
Apr 06, 2015 | Online ON Wireless Bluetooth Keyboard...
My lenovo keyboard is not working.i have three blinking lights above number lock
Is it a corded or non corded keyboard. Possible problems with non-corded: Dead Battery, no link to USB receiver(dongle) on computer, bad USB receiver (Dongle) on computer. From Lenovo Website:
Keyboard and Dongle Paring:
Auxiliary tools: PC with Windows XP or Windows 7, two AAA cells
Pairing steps:
1. Insert Dongle into PC. Be sure that the Dongle is recognized by PC and the distance between keyboard and the Dongle is within 10cm.
2. Press down F2, F3 and F4 at the same time, install cells, release F2, F3 and F4 and then Press "3" to begin pairing. After finishing pairing, press "Windows" key to check whether the pairing is successful. If "Windows" key works, it means that the pairing is successful; otherwise, the pairing fails.
That was all I could find on the site.
Sep 22, 2014 | Lenovo Keyboard
The remotes for my system do not operate when I press the lock or unlock or remote start buttons. Is there a way that I can reprogram the two remotes to work with my remote start sytem. It is the python...
The "pair" the remote with your system:
1.PRESS AND HOLD the f button on the remote UNTIL the transmit LED lights solid (approximately 10 seconds)
2.PRESS AND HOLD the remote start button (circle arrow) UNTIL the LED blinks 3 times and the amber transmit LED lights up. Your remote is now ready to pair.
3.. Turn the key to the on position
4.Within 5 seconds PRESS AND RELEASE the control button on the antenna.
5. Within 5 seconds PRESS AND HOLD the control button. The status LED will flash one time and the siren will chirp to confirm that the system is ready for remote pairing.
6. Press lock button on remote. System will respond with chirp toconfirm pairing.
Oct 28, 2010 | 1401 Remote Start/Keyless Entry System
Won't stay on
If you already replaced it with a new set of batteries, try to check the lights on the mouse (Led light) if there is no light at all, it means you logitech mouse is already faulty. If there is a light, try pairing the device by pressing the pairing button (it should flash/blink)
Hope this helps.
Mar 16, 2010 | Logitech Cordless Mouse
Jabra BT2050 blinks three times; doesnot pair up
Hold round center button for 10 seconds, light will stay on and be in pairing mode.
Nov 20, 2009 | Jabra BT2050 Bluetooth Headset
I can't get Jabra BT 2050 bluetooth into pairing mode. I follow the instructions but never get the solid light. What can I do?
Booklet instructions for how to pair it with a new device are wrong. It tells you holding the power button will put it into pairing mode but it does not.
Pairing mode is done by turning off the ear piece, then holding both power and answer/hangup at the same time. The LED should flash fast 3 or 4 times and then stay on solid. You might need to hold just power till the very first flash THEN begin holding answer/hangup as well as power till the LED goes constant. I’ve also had luck when frustrated by just holding all 4 buttons at once.
Oct 10, 2009 | Jabra BT2050 Bluetooth Headset
Free Pulse
The following procedure will re-establish the communication link between the Headphones and the Wireless adapter, this is called "pairing". Before you start please make sure both the headphones and the wireless adapter are fully charged and turned off.
Note: The headphones and the wireless adapter come pre-paired from the factory.
1. Press and hold the power button on the headphones. See Figure 1.
Figure 1
2. Continue to hold the button down until the LED starts flashing red/blue in an alternating pattern. Release the button when the LED starts flashing red/blue. See Figure 2.
Figure 2
3. Once the headphones LED is flashing red/blue, press and hold the power button on the wireless adapter. See Figure 3.
Figure 3
4. Hold down the button until the LED starts flashing red/blue in an alternating patter. The LED will blink blue, then turn off for a few seconds then blink red/blue. Release the button when the LED starts flashing red/blue. See Figure 4.
Figure 4
5. Once both the headphones LED and the adapter LED is blinking red/blue, press the volume up button once on the headphones. See Figure 5.
Figure 5
Once the headphones is paired with the adapter, the LED on the headphones will blink blue once every two seconds. See Figure 6.
Figure 6
When the adapter is paired the LED will be solid blue. See Figure 7.
Figure 7
The adapter may continue to blink red/blue for a few seconds even after the headphones LED starting blinking blue. This is normal; the adapter may take a few additional seconds before the LED turn solid blue.
Once the headphones and the adapter are paired, it is not necessary to pair them again even if the batteries on both units are completely drained.
Additional Note: Repeated pairing will not improve the sound quality or give the headphones and the adapter a cleaner connection.
Mar 11, 2008 | Logitech FreePulse Wireless Consumer...
Installing a French ( Brand is Genius) keyboard to my Dell computer.
Pair to a Bluetooth Device (new and re-pair)
  1. Locate the Bluetooth icon in the lower-right corner of the computer screen, and compare the status to Table 1.
    (The Bluetooth icon may be hidden, click the Show hidden icons arrow to show any hidden icons.)
    Bluetooth Icon Status Enabled - The Bluetooth adapter is ready to pair with another Bluetooth device.
    Connected - The Bluetooth adapter is already connected to a Bluetooth device (if the desired device is not the one its connected to, it will have to be re-paired). Disabled - The wireless switch is off. For information on how to turn the wireless switch on refer to the
    Online User's Guide. None When no icon shows the Bluetooth driver needs to be installed, refer to Dell Knowledge Base Article:
    "How to Download and Install the Latest Dell Wireless Bluetooth Driver" Table 1: Bluetooth status
  2. Verify the following conditions have been met:
    • Batteries are Installed in the Mouse and Keyboard.
    • The Bluetooth adapter, USB Bluetooth adapter or 13/19-in-1 Media Card Reader is installed in or attached to the computer.
    • The latest version of Dell Bluetooth Wireless Keyboard and Mouse Bundle is installed,
      if unsure refer to Dell Knowledge Base Article: "How to Download and Install a Driver"
    • The Bluetooth device you are going to pair is within 30 ft. (10 meters) of the computer.
  3. Right-click the Bluetooth icon in the system tray.
  4. Click Add a Bluetooth Device.
  5. Turn on the Bluetooth mouse and press the Bluetooth connect button on the bottom of the mouse. The Bluetooth LED on top of the mouse should start blinking. If the LED does not blink, press the Bluetooth connection button again and hold it down for 2-3 seconds until the Bluetooth LED starts blinking.
  6. Click Next to start searching.
  7. Click the icon for the mouse to highlight it and then click Next.
  8. The connection is set up automatically. Once the connection to the mouse has been created, the wizard closes and returns to the Bluetooth Settings window. The new connection is now listed there. The link symbol under the mouse indicates it is connected.
  9. SetPoint will now launch and ask to check for updates, click OK. If an update is available click to download it.
  10. After the update has been applied, click OK.
  11. Turn on the Bluetooth keyboard and press the Bluetooth connect button on the bottom of the keyboard. The Bluetooth LED on top of the keyboard should start blinking. If the LED does not blink, press the Bluetooth connection button again and hold it down for 2-3 seconds until the Bluetooth LED starts blinking.
  12. Click the box next to My device is set up and ready to be found and then click Next to start searching.
  13. Click the icon for the keyboard you want to connect to in order to highlight it and then click Next.
  14. When the keyboard is connected, the Confirm Keyboard Connection screen appears. A passkey that has been generated for the keyboard is shown. Type in the passkey as it is shown on the screen. Note:
    The keyboard can only store one passkey. The passkey is unique to each computer. If you try to connect the keyboard to more than one computer, the passkey is changed each time you create a connection.
  15. The connection is set up automatically. Once the connection to the keyboard has been created, the wizard closes and returns to the Bluetooth Settings window. The new connection is now listed there. The link symbol under the keyboard indicates it is connected. You are now be able to use the devices.
Aug 25, 2017 | Trust Silverline Direct Access 12879...
Iphone and headset
Is this the first time you're pairing iPhone and jawbone or it's been working before?
If this is the first time,
1. Go to settings-general-bluetooth and turn on the bluetooth on your iPhone 2. Press and hold the button above the LED light until the LED light flashes Red and White 3. Go to your iPhone and click on Jawbone and it should connect.
If it's been working before:
1. Make sure Jawbone is fully charged. 2. Press and hold the button below the LED until white light blinks 3. Go to iPhone make sure bluetooth is on press Jawbone to connect
If this procedure fails try the to follow the First Time Pairing Instruction
Hope this works for you.
Nov 21, 2007 | Apple iPhone Smartphone
Dell XPS M2010 Wireless Bluetooth Keyboard Logo
3,091 people viewed this question
Alun Cox
