Question about Maytag Legacy Series Top Load Washer
My washer leaks underneath at the back it. I heard either a pump or hose is the problem. How can I tell?
  • 169 Answers
Remove the skin and test her out. do it outside with water hoses should be able to tell what it is right away. pumps are cheap to replace.....good luck!
Posted on Nov 18, 2009
  • 11,896 Answers
You can remove the rear panel. Look where the external hoses connect to internal hoses. The insides of the hoses have a rubber o ring that tends to leak.
Front loader leaking underneath in the back corner on the left hand side
If its leaking during the fill cycle, its one of the water valves (solenoids) or associated hoses, loose clamps, etc. If its leaking during draining its the drain hoses, pump, clamps etc. Easiest way to tell. Pull it out, if you can remove the back, run it and look for the leak. Just don't touch anything while its running, you don't want to lose a finger or get electrocuted.
Aug 06, 2014 | Samsung Front Load Washer Control Board...
My whirlpool ultimate care 2 washer was leaking underneath while running, I removed the back panel and dropped the drain hose to the floor and extended it out the door to the yard and while filling the tub...
The drain hose must be at least level with the top of the actual tub in the washer. The water pump is only bad if it is leaking. If it is leaking from the front you either have a cracked outer tub, but it sounds like your water pump, easy to change out just get the model # and order it through an appliance parts distributor. The cost is about 40 to 50 bucks. good luck!
Aug 20, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Ultimate care supreme leaks underneath
First check the hoses to the machine. If they leak the water follows the hoses and drips on floor. Also check the hose connection at the washer. They will leak inside. Next it may well be a water pump going out or the plastic hose that is under pressure when operating. The pump is in the middle of machine underneth - Sorry - Good luck
Oct 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Leaking water underneath washer
it could be the pump or the hoses its hard to tell til you get in there and look to see for sure.
Jan 14, 2009 | LG WM-2277HW Front Load Washer
Washer leaking when filling up tub
Unlikely to be pump, sounds more like hose leaking, or drum seal.
Depending upon severity of leak, place a sheet of newspaper under front of m/c, pushing it as far back as you can. switch m/c on for a few secs, then switch off, remove paper and you should be able to judge where leak is.
Tilt m/c back and have a look underneath.
At 12 years old, if it looks major, I think I would replace m/c.
Plz rate my solution.
Thanks.
Dec 31, 2008 | Maytag Dependable Care LAT9206
Waher
ckd pump lean washer back against wall pump next to front ..2 clips hold pump to motor 2 clamps on hoses pump slides off motor ..also ckd hose from pump to drain underneath
Sep 10, 2008 | Roper RAX7244KQ Top Load Washer
Washer is leaking from underneath....
lean washer back against wall ck pump under front in center for leaks or dark gray area in pump face remove hoses remove clamp top and bottom of pump slide forward off shaft
Jul 30, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
My washer is leaking...
Open the rear panel on the washer. Check the 3 rubber hoses connected to the pump. Make sure there are no splits, or a **** in any of them. Also look at the pump and make sure the casing is not cracked and dripping (if coins enter the pump they can crack the casing, causing a leak). If there is a leak in a hose, replace that particular hose. If the pump casing is cracked, replace the pump.
Apr 11, 2008 | GE Spacemaker WSLP1100D Top Load Washer
Washer leaking
bestsy, your pump could be weeping. Sometimes they will develope a small leak and sometimes they let loose. They are easy to change, 2 clips and 2 clamps. Check out the photo, other things to check would be the hoses at the fill valve and the drain hose. Sometimes overloading will cause an oversplash. Catriver..post back.
Mar 21, 2007 | Kenmore 22422 Top Load Washer
LG WD-8016C Front Load Washer leaks from the bottom
Crawls, usually all leaks are visible. Im surprised the repairman did not actually get to the source of it. Your drain pump sits on the bottom and it possibly could be the filter cap, hoses to the pump or pump itself. Another area to check is the despensor. There are a number of hoses to this which could be leaking. The bellow itself could have a cut in it somewhere along the bottom. I would call the repairman back and have him at least get to the source of the leak...Catriver..post back.
Aug 14, 2006 | LG WD-16115FD Front Load Washer
Washing Machines Logo
105 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
