Minolta ep 1080 copies have vertical grey stripes with a white halo around the text
  • 1,110 Answers
You need a drum cleaning blade. This blade cleans the drum between copies.
You can verify this by opening the "clamshell" or lifting the top half of the machine like you do when removing a paper jam. Then look under the top half of the machine on the inside. You should see a reddish or greenish colored cylinder called the drum. It is about in the middle from right to left. If you see the same black bands on the surface of the drum as you do on your copy then the drum cleaning blade is bad.
This cylinder should normally be clean.
Good Luck.
Posted on Nov 18, 2009
SC23-14 FOR BIZHUB 1050 KONICA MINOLTA
Drum motor failure to turn.
There may be foreign material in the drum unit locking it up. Also possible motor failure or board failure.
Mar 10, 2014 | Konica Minolta DEVELOPER - BLACK - 120000...
Minolta EP 2080 the copy on colored paper is ok but copies on white sheet is very faint
This will be due to the ae setting you will need to adjust this it sounds like it has been set for the color paper
Jan 28, 2011 | Konica Minolta Office Equipment & Supplies
I have a Minolta CS Pro EP 1031 Printer that makes streak marks
Drum cleaning blade has gone bad. Especially true if the streaks seem to get progressively worse as you run multiple copies. In other words run 10 copies. If the last one out is worse than the first one out it is the drum cleaning blade. Cheap part...around $25
Oct 12, 2009 | Minolta EP1031/1031F CS/PRO Copier
White vertical stripe on color images when they're printed
You may have some dust on the imaging window (printer head). Remove the toner cartridges and clean it with some tissues.
Apr 28, 2009 | Konica Minolta magicolor 2430 DL Laser...
Viewsonic Monitor and the text is not black but grey.
try to log in safe mode and reinstall the display adaptors or uninstall them and reboot
Feb 01, 2009 | ViewSonic G90fb 19" CRT Monitor
My iphone's screen is white with vertical stripes
try to restore ur fone manually.
that should work
Dec 29, 2008 | Apple iPhone Smartphone
Why does minolta copier print white stripes?
TRY TO CLEAN AND CHECK MAIN CHARGER AND TRANSFER CORONA FOR VOLTAGE LEAKAGE,AND CHECK DEVELOPER GEAR AND DEVELOPER DRIVE GEAR
Dec 03, 2008 | Minolta EP1030/1030F CS/PRO Copier
Minolta EO 1080 Copier-Error Code C05
Did you do anything to the fusing unit (ie cleaning thermistors or replacing the fuser roller?) That code means you have a temperature problem.  It will also come up if your power cord is loose.  You can check it by taking off the back cover of the copier and pressing in the trouble reset button while the copier is on.  It's a small black button. If the code goes away, you're good to go. If it comes back, you might have to replace some of your fuser components.
Oct 13, 2007 | Office Equipment & Supplies
75 people viewed this question
k24674
