Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
I cant clean my glass on my stove where do i take it apart. i tryed the 3 screws on top put i still cant take it out ( the glass part)
  • 126 Answers
Put the door down, and unscrew all the screws inside the oven door. Be prepared for the door to come apart as you come to the last few screws.
Posted on Nov 19, 2009
How do i clean the inside the glass on my oven door
The door usually has about 4 to 8 screws on the inside. Remove the door first by opening it to 45' and lift it off its hinges. Sit it on top of the stove carefully after putting an old towel and a garbage bag on top of it. Remove the screws in the door and the inside will lift off the outside skin. Clean the glass with oven cleaner and reassemble. Ours needs doing too!
Feb 11, 2016 | Ovens
How can i clean the glass between my oven door,i noticed streaks and it makes the oven look dirty
Whirlpool door are a bit difficult to remove from the stove. the owners manual may tell you what you need to do to remove it. Once you have it off then the door can be taken apart by removing tye screws that hold it together. This should be done on a flat surface and taking a lot of care. Remember how it comes apart and reverse the procedure when putting it back together. If you break a glass they are expensive to replace if available.
May 30, 2015 | Whirlpool 30" Self-Cleaning Freestanding...
Why are there brown/white streaks inside oven door glass after using self cleaner 1 time?
Thank you for your post, friend!
From my understanding after you used the self-clean feature on your Frigidaire range you now have brown and white streaks on the indoor glass. Typically streaks can be removed by cleaning the interior glass. Normally it is recommended to have a professional clean the inside glass but a consumer can do it as well. Use caution when following the steps some pieces can have sharp edges. You will need to have a Phillips head screwdriver or small quad bit driver.
A. Refer to owners guide for instructions on how to remove oven door.
B. With door in broil stop position lift door assembly off hinges.
C. Lay door on table, position so that handle hangs freely over edge of table
D. Remove 2 screws and washers that secure handle to lining assembly.
E. Remove 8 screws that attach textured steel door wrapper trim to lining assembly 3 at top, 3 at bottom, 1 on each side
F. Lift door lining up and out of wrapper trim assembly.
G. Lay lining assembly on table with wool shield/inner part of lining facing up.
H. Remove 2 glass clamps via 2 screws per clamp. These clamps attach innermost clear glass to wool shield.
I. Lift out center clear glass from wool shield, this glass just lays onto the wool shield and is held in place by the glass/ clamps in item H.
J. Clean each glass with appropriate cleaner.
K. One glass that remains in door lining assembly can at this time be cleaned without further disassembly the lining assembly.
L. Reassemble in reverse order.
Hopefully this is helpful. -Matt
Aug 23, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire oven door glass clean inside
Good Morning Suzi - Generally, qualified technicians often perform complicated part replacement such as this, however this may or may not be specifically for your model. Below are generic instructions that I found on how to take your oven door apart to remove any stains that may be caught down in the door vents.
Tools needed: Phillips head screwdriver or small quad bit driver.
A. Open Door remove 2 screws and washers on door lining at door hinge area.
B. Refer to owners guide with door in broil stop position lift door assembly off hinges.
J. Clean each glass with appropriate cleaner, Windex, bon ami, fantastic, etc
I hope this information helps to some degree.
May 24, 2013 | Frigidaire 27 in. Electric Double...
How do you put door back onto Electrolux wall oven......Been trying for hours, no success!
Hello paulascor549 - I completely understand that you took the oven door apart to clean it, therefore you must have took the following steps to do so. According from my research you would have to reassemble in reverse order. If you have already tried to do so and it proves to be ineffective, contact a professional to move forward accurately.
Door Removal and Cleaning of Interior Glass
B. Refer to owners guide? With door in broil stop position lift door assembly off hinges.
Nov 24, 2012 | Electrolux 30" Built-In Single Electric...
My self cleaning kenmore stove seems to have grease between the window panes on the door. cleaning doesn't reach this problem. i need to get between the panes to clean them - how can i do this? will...
Taking the door apart is relatively easy and unfortunately the only way to clean between the two pieces of glass. All you need to do is remove the screws holding the outside cover on.
Jul 01, 2011 | Ovens
Glass top broken,can it be fixed
The glass top can be fixed. You will need to call a parts dealer to order. They usually run a couple hundred dollars. If you are going to replace yourself than you will need to pull the stove out and disconnect power. Than remove the side panels and it allows access to the screws holding the glass top in place. Be extremely careful when replacing these. They can break easily. Make sure you place burners and everything on the new one exactly how they are on the old one. Easy way of doing this is have a couple big towels and set next to each other and switch parts there. Remember that when you put it back together to clean it with glasstop cleaner before you use the stove.
Jun 13, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
I own a Kenmore stove model #639539J2. The glass
yes. open the oven door to the first "click". it kind of stops about a quarter of the way open. most ovens you grab both sides of the oven door and pull up. some models have a couple of screws you have to take out before you can remove the oven door. then lay it down with the insie of the door facing up and take out all the screws holding the oven door together. some may be on the sides or the top and bottom of the door. when apart, clean first with easy off, then clean several times with windex till streaks are gone. assemble door in reverse and put back on stove.
Oct 10, 2009 | Kenmore Ovens
Dirt and grease between glass in oven door
i have taken the glass from the inside of the oven,and just cant get grease off, tried everything ,bleach,even lemon juice,
any ideas jimmy
Aug 01, 2008 | Ovens
Outer glass needs cleaning
yes. open door slightly to first stop point, pull up on door. the door will come off. there are screws on the bottom of the door and on the side facing the inside of the oven remove these screws to take door apart
Nov 18, 2007 | GE Profile JTP18 Electric Single Oven
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
159 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
