Question about Jet JBG - 8A 8" Bench Grinder
I need to find an two eye guards for the grinder in southern california?
  • 132 Answers
Check out toolbarn.com they most likely will have the parts you need and you can order directly from them
Posted on Nov 18, 2009
Can you find my brother, James Robert Newsom Age 76 in Southern California (NOT in San Diego)
I guess you had tried the White pages of california ?
Whitout an exact city name it is difficult to help you accurately
Try them
http://www.whitepages.com/name/James-Robert-Newsom/ca
Dec 23, 2014 | Games
Coffee beans are not going into grinder.
Your grinder is probably blocked.
It may happen if your coffee is greasy or oily.
Try to empty the coffee bin and using your vacuum cleaner, removed has much as possible the grounded coffee around the grinder.
Also, from the inside, look where the coffee grind should drop from the grinder to the brewer unit and removed any grind that could block and prevent coffee to drop.
Jun 10, 2014 | Saeco Odea Giro Plus Coffee Maker
Stopped working
The speed control pot has become dirty from eating it's own dust. Try squirting electrical contact cleaner into the slot in front of the pot. Guard your eyes!! Rotate the pot from end to end a few times and repeat if necessary. Let it dry before applying power.
Jan 22, 2014 | Dremel Multi Max Kit
Removing finger guard and cleaning ceramic grinder in Saeco product
Before starting, find the parts diagram for the Incanto Deluxe (google search: "incanto deluxe" "parts diagram").
To remove the finger guard, first remove the silicon plug (part number 90 in parts diagram) in the center of the grind adjustment knob by poking an unbent paperclip with a small hook along the silicon plug's edge, twisting 90 degrees and pulling the plug out. Next unscrew the phillips head screw (part number 15) way down in the center of the adjustment knob and remove the knob. Then remove the phillips head screw (part number 120) holding the finger guard to the bean hopper.
I'm not sure how to work on the grinder, but from here at least you should be able to get to it. I suspect that simply removing the finger guard may make things a lot better.
Mar 14, 2012 | Saeco INCANTO DELUXE Espresso Machine
I have a D28110 angle grinder and I want to use a 1/8"cutting disc with it. Do I need a different guard than what it came with?
haven't heard of a different guard for the cutting disc you want to use. Most people remove the guard when using them
Sep 15, 2011 | Dewalt D28110 Heavyduty 412" Small Angle...
What should the clearance on the top and bottom be when using a bench grinder, in mm
The top guard should be set at 6mm and the bottom guard should be 2-3mm from the grinding wheel.
hope this helps,
Apr 05, 2011 | Clarke Power Products Cast Iron Bench...
Is it safe to use the 41/2" hand grinder one handed?
The danger of using a grinder single handed is that if the disk catches in the workpiece, the grinder will try to pull out of your hand and you can loose control of it and risk possible injury or damage what you are working on. This is especially dangerous if you are working off a ladder or on a height as you could loose your balance.
When using an angle grinder you should always wear eye protection and try to keep your head to one side out of the plane of the disk avoiding sparks and possible fragments of the disk which will fly at high speed if it shatters.
Mar 04, 2011 | Garden
Do you need to keep grinding guard on when using a cup wire wheel on the grinder?
Hello, W/D here.
It's always a wiser choice to leave the guard on to help keep particles from being slung at you.
In addition to the guard, you should also wear eye protection. I have extensive experience in industrial work, and I cannot emphasize strongly enough how important this is. Where I worked, working with a wire wheel required that the guard be in place and that the operator wear safety glasses and a face shield. An eye injury is one of the most serious accidents that can be easily avoided.
Best regards, and work safely, --W/D--
Feb 09, 2011 | Dewalt DW802G Heavy Duty 4 1/2 Inch High...
Need manual for craftsman bench grinder model # 257.191300. misplaced other one. hope you can help. mike
Mike
Not sure what was happening when the previous reply was created, but the owners manual is part number 211260001 $7.99 at SearsPartsDirect.com
That said, I'm staring at my own copy of the the owners manual and I can't really see why you would want to pay for one. The only really useful information is the parts diagram which is online at SearsPartsDirect.com. The rest is generic grinder information (support workpiece, select proper wheel, etc.) and CYA (always wear gloves and eye protection, don't remopve safety guards, don't use damaged wheels, don't stick your finger in the light socket, don't cross the steet in the middle of the block, etc.)
Jun 07, 2009 | Craftsman 6" Bench Grinder with Lamp
Jet JBG - 8A 8" Bench Grinder Logo
91 people viewed this question
Top Jet Grinders Experts
DrBogo
Level 1 Expert
Pieter Vleeshouwers
Pieter Vleeshouwers
Tom Chichester
Are you a Jet Grinder Expert? Answer questions, earn points and help others
