There's a noise sounds like coming from the steering column when left turn signal is used (right side works great)...left turn signal does not work well in cold weather, just warmer weather
  • 534 Answers
Check the wattage of all the bulbs on the left turn circuit - ensure they are of correct wattage rating.
Also check condition of bulb sockets - look for corrosion or water ingress.
If all above OK, check turn signal switch - contacts may be worn out/damaged.
Posted on Nov 19, 2009
Turn signal light right flash
flasher/blinker is busted. this is located under your dash board. remove steering column cover, turn on LEFT turn signal (yes, the one that is working), then you will hear a clicking sound. locate the relay that causes the sound. there you can see 2 relays (one for LEFT, other one for RIGHT turn),replace busted one.
Jun 11, 2013 | 2002 Toyota Tundra
I have a 1991 Mercury Cougar. The wipers on this car do not operate at the correct setting. When its set to off they still go, when set to intermitent they go off etc. Blinkers usually dont work but...
the multi function switch will affect the signals but not the tail lights as they are on their own circuit.with the right side lights only working it sounds like a wiring problem for the left side and the wiring needs to be checked out at the rear of the car.the dim lights on the right side could be not enough voltage supply or a bad ground which again can be related to the wiring problem for the left side.the multi function switch is the switch that you use to turn on the signal lights change low to high beam headlights,turn on the wipers.it is located below the steering wheel with the wires running down the inside of the steering column.the signal switch is also located below the steering wheel on top of the column.the steering wheel will have to be pulled and the plate removed to see the switches and remove them.the wiring connectors are at the base of the steering column under the dash and they are removed by pulling them out through the column upwards and feeding the new ones down through the same way paying attention as to how the wires a routed through the column.
Apr 12, 2011 | Mercury Cougar Cars & Trucks
My left turn signal works but it wont blink which fuse is it? or is it something els?
It sounds like the flasher relay is stuck closed. It is located under the left side of the dash, to the right side of the steering column. Try replacing that and double check if you recently replaced any bulbs that they have the correct base for the sockets. Sometimes the bulb might look right but the base is slightly different. The correct turn signal bulb for your vehicle is a 2057, and an EL12 or FL12 for the flasher relay.
Mar 15, 2011 | 1995 Chevrolet Beretta
Hi, as I was turning right with my signal on and then an immdiate left with the signal on when I heard a cracking noise come from my steering column, then the right signal would not turn off automatically....
There is a fitting around the steering column with the indicator switch and cancelling mechanism on it. It sounds like this has come loose or cracked. You will need to strip down the shroud around the column to investigate.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
Feb 16, 2011 | 1997 Plymouth Grand Voyager
Left turn signal outside lamp, front and back do
Inspect the turn fuse under the hood. There are seperate fuses for L and R
Feb 06, 2010 | 2003 Chevrolet Silverado 1500
99 park avenue turn right side turn signals inop does it have a relay and were is it located
If the left side still works, its not the blinker relay, the thing you hear ticking. Both left and right signals go through the same signal stat. Turn on your hazard flashers and make sure the bulbs on both the left and right side come on. If the do, you may have a problem with the turn signal switch on the steering column itself. If only the left comes on, it could be bad bulbs on the right side or a wiring issue. Wiring issues are more rare on Park Aves.
Jul 09, 2009 | 2000 Buick Park Avenue
1997 dodge avenger turn signal probs and location
replace the turn signal switch it self, mine did the same thing with the left turn signal, put in fuse and it will continue to flash... went to junk yard pulled one out of a 97 avenger just like mine, swapped them out and now it works fine. looked to be like some corrosion... to repace: 3 screws under columb, 2 screws on side of signal switch (black plastic side). unplug and replace
Mar 20, 2009 | 1997 Dodge Avenger
98 Buick Lesabre Blinker Problem
If ALL Wiring in Trunk is Good Then Its The SWITCH = Multifunction Switch<<
Feb 11, 2009 | 1997 Buick LeSabre
Turn signals don't work
i have a similar problem but my left signal works, when i turn the right on it just does an annoying buzz sound. if you can think of any explination for such shinanogins help would be greatly appreciated
Nov 25, 2008 | 1989 GMC K1500
Steering noise
I have a 2000 Mercury sable sedan and when I turn to the right a get a squeaking noise coming from
the rod that attaching to the outer tie rod, the sound is coming from the boot on the right side of the rack and pinon sterring?
Sep 18, 2008 | 2000 Mercury Sable
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
Electro Med Services...
