Question about Ricoh Aficio 450 Copier
Prints black dots at bottom of page - photoconductor was replaced earlier today
    New Friend:
  • 22 Answers
The black dots could be a few things, the most likely would have something to do with the drum area because the dots didn't appear until after service. If the dots are only about an inch apart it is probably the charge roller. If there is only 1-2 dots per page, the issue is likely with the drum. These figures are assuming you are running 8 1/2 x 11 paper with the long edge being fed in first. If this is the case, you can change the paper to feed with the short edge first and this may get you by until the technician gets back out to fix it.
Posted on Nov 19, 2009
I have a lexmark c534dn that has an issue printing light on the left side of the pages. It seems to be an issue with black prints but color comes out okay. I replaced the black toner and the black...
that is possible. The transfer belt contains four transfer rollers, one for each toner. However, if the printer is dirty inside then it is also possible that the black scanner is polluted. A damaged contact can cause this issue so I would check all the contacts that cartridges and drums seat against to make sure one is not stuck before going the route of a transfer belt which is likely more than the printer is worth.
Dec 01, 2014 | Office Equipment & Supplies
Printer only prints top and bottom lines on page
All web based documents, especially bank statements, require a COLOUR cartridge, so if your cartridge is empty, it will print blank pages. Although the font may look black... it is normally NOT. Altentaively you may also need to instruct your printer to print "background images".
Jul 08, 2012 | HP Deskjet D1000 J110a Printer Catalog...
Lexmark c532n prints smudges on page
The problem could be caused by the photoconductor units. Try to swap the affected photoconductor units (like swap the magenta with black and cyan with yellow). If problem still occurs, then the photoconductors need replacement. I suggest you contact Lexmark Technical Support for assistance. Thanks
Jul 26, 2010 | Lexmark C532n Color Laser Printer
Blue dotted line of right side of paper
Sounds like the cyan photoconductor unit needs to be replaced. Usually what ever the color dot is that photoconductor has a pinhole in it and the only to get rid of it is to replace it.
Apr 06, 2010 | Ricoh Aficio SP C411DN Laser Printer
4 colour dots on printout but not 150mm apart
Measure the distance between two of the same coloured dots down the page, if it is just over 150mm then it is caused by scratches on the photoconductor drum (this is the only thing that has a 15.4mm circumference). Try printing a black and white only document, only the black dots should appear. Removing the photoconductor and gently polishing the blue drum with a soft cloth can help if the scratches are not too deep, otherwise a new photoconductor is the only route.
Sep 06, 2009 | Epson Aculaser C1100 Printer
The Lexmark c530dn prints fine. Smudging down both sides.
Your problem is caused by 2 worn photoconductor units. If you open the front door like you are changing toner, the photoconductor units will be mounted to the door that swings down. You will see should see four units one for each color, red, blue, yellow and black. If you look at the red and black units the ends will look different than the blue and yellow. The photo units have teflon coating that wears off and causes your proble. The replacement part number is C53030x and you will need 2 of them. Just replace the red and black ones and your printer will be back to normal. If you can't locate them locally, let me know and we can ship them to you.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 year of PC and printer support/service
Jun 15, 2009 | Lexmark C530dn Laser Printer
Cs-2030 leaves a black line on left side of page...
The waste bin might be full,try emptying it. Also check the photoconductor unit
May 26, 2009 | Copystar CS-2030 Copier
Lexmark E232 Printer prints all characters fine but leaves about an inch gray/black margin on the left side of the paper. Tried replacing the toner cartridge and it didn't help. Any suggestions?
If this model has separate toner and photoconductor then the photoconductor is at end of life and needs to be replaced. Follow the directions that come in the new photoconductor package to install and reset the PC count this is important.
Luck
Mar 07, 2008 | Lexmark E232 Laser Printer
Yellow line on edge of page
on a ricoh - that would be the pcm - photoconductor module on an ecosys the module should last 100,000 pages nothing ever seems to last that long send an email to http://www.pcandl.com/ or call where you bought it
Aug 07, 2007 | Kyocera Mita FS-C5016N Printer
Epson epl6200l photoconductor dirty
when i am printing a small dots black appear.. what is the problem? photoconductor unit? were can i buy one here in the philippines?
Dec 27, 2006 | Epson laser Printer EPL-6200L Laser
Ricoh Aficio 450 Copier Logo
148 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
