Question about RCA F32649 32" TV
Guide plus I lost my remote, The other day I lost power to this tv, now the guide plus menu keeps popping up every few minutes. I press menu and it goes away, then reappears in a minute or so. How do I get rid of this for good?
Can you let me know if you got help for this? the gude plus menu is blank and keeps popping up in the middle of a show for no reason. then the picture goes out behind it. the sound works ok though.
Posted on May 17, 2008
I have a RCA guide plus gemstar t.v.I have lost the remote.to set up the guide plus in a new area I need to change the zip code.Its a 2003 model 36F53OT.where can I order one or an alternative solution.
you can access guide plus from front panel switches. press menu and select no. 7 or 8 guide plus setup. it asks for zip code type in using another remote using keypad.
Sep 17, 2011 | RCA 36F530T 36" TV
I have an 2001 RCA TV model F31317 it has a Guide plus. Is there a way to turn off the guide plus? I have went through the programing and can't find anything in the menu to suggest a way to turn it off. My...
You can disable this only by going into the Guide Plus+ menu. If you have the original remote or one that matches the feature, press Guide then Menu (sometimes you need to hold this for a few seconds), navigate to Setup (right arrow until it is highlighted). OK, Menu or the down arrow all let you enter the menu. Then use the up/down arrows to select Review Options. Select Off (only two choices). Press OK and exit the guide.
I hope this helps.
Oct 02, 2010 | RCA Televison & Video
The guide menu keeps popping up and it loses the remote programing. I cleared it out once by pressing several buttons, including the power and mute button simultaneously until I gained remote control...
You have bad switches inside the tv. When a switch gets stuck nothing else will work including the remote. In other words, the microprocessor can take only one command at a time. Replace all the switches at one time to avoid trouble later.
Oct 13, 2009 | RCA Televison & Video
Guide Plus keeps popping up when the remote is used to turn TV on
there should be a way to turn it off in the user menu. usually it's under setup.
Jan 10, 2009 | RCA Universal Remote Control
How do I remove the guide plus from coming on at power up?
I found the solution!
With the remote, press the Guide button. This should bring up the Guide Plus+ screen. Press the right arrow to move the cursor all the way to set up and it will ask, "What would you like to do?" Arrow down to "Review Options" and press OK.
The first question is, "Guide Plus+ System Auto Display? On / Off"
Arrow down to Off and press OK.
Jan 01, 2009 | GE 32GT740 32" TV
Guide Plus crashing
This problem is possibly a failure on you digital main pcb. Hoping its not hardware, best thing is to try to totally reset the guide plus. Go into the guide plus menu and find the setting to reset or restart setup. If this does not solve you issue, try hard booting the tv (unplug for 2 minutes) and try again. In quite a few cases, the manufacturer of the tv will have a software upgrade that may fix guide plus issues. Contact your manufacturer for that information
Dec 07, 2008 | Televison & Video
Can't get the Guide Plus screen to go away
Try these options
Option A:
Select the GUIDE Plus+™ Menu from the Main menu.
Select Setup.
Select Options.
Select Off.
Option B:
Select GUIDE Plus+™ Auto Display from the GUIDE Plus+ menu.
Select Off.
Option C:
Press GUIDE on your remote control.
Select the Menu bar.
Press the right arrow button to select Setup.
Choose Review Options.
Select Off.
May 16, 2008 | RCA F27649 27" TV
Hi I have a rca tv that has guide plus on it , But I have lost the remote and the demo keeps popping up. Is there a away to take it off without the remote control?
yes U can use volume up and down channels up and down and menu key as ok key look in the guide plus is and option to turn that of just play with if still having problems let me know and I' get the steps to get rid of
Apr 17, 2008 | Televison & Video
RCA TV f27422 TURN OFF THE GUIDE PLUS
Hello, I have had my TV for 3-4 years and have dealt with this stupid guide popping up for the last 2 when I got curious to see if it was something I wanted to use. FINALLY I came across a solution - so far so good but tomorrow it could be back? I did not have the option field some suggested to use. So saw another suggestion for something else and so far so good. When going into the setup guide. Select the USA, place all 0's in the zip code area and NO for everything else.... no VCR no cable, etc.
Hope this helps..
I also was able to do this without the remote - IF you can get the menu to pop up you just have to use the numbers to select what you need. Found the remote and saw nothing different as far as menu options. Good luck.
Jan 17, 2008 | RCA F27442 27" TV
Rca tv f27628
http://sci.tech-archive.net/Archive/sci.electronics.repair/2006-12/msg01203.html
Turn on the TV
using original remote:
Bring up TV Main Menu and select option 7 (TV Guide Plus Menu)
Select option 1 (TV Guide Plus Setup)
Find the MENU, GO BACK and Input button on your remote
Press the MENU Button then immediately:
Press the GO BACK button then immediately:
Press the INPUT button.
Note: It is important to press the Menu, Go Back and Input buttons quickly (within a second of each other)
Nov 11, 2007 | RCA F27628 27" TV
RCA F32649 32" TV Logo
212 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
