Question about HP Pavilion dv2020us (882780664913) PC Notebook
Will not start with battery installed - HP Pavilion dv2020us (882780664913) PC Notebook
  • 5,603 Answers
The battery has failed. Replace it. You may damage the charging circuitry on the motherboard if you keep trying to use it.
The USUAL thing is one cell within the battery has shorted. The USUAL cause of that is depleting the battery down too far.
Posted on Nov 18, 2009
Why do I have to keep jump starting it?
Your battery is fine but will need to be fully recharged. It is your alternator the is going out or very close to bein out now. Replace that and you should be fine.
Feb 09, 2016 | 2011 Lincoln MKX
What would cause my alternator and battery to keep dying in my 1991 dodge caravan
Disconnect the negative of the battery. is there a amp installed or just a radio After market or updated factory. How old the battery remote start or no remote start after market remote start cause this problems
Jun 20, 2014 | 1991 Dodge Caravan
I have a problem with a 2008 Dodge Charger, my battery went bad and I had to jump it off to take it and get a new battery put in but now my new battery won't start my car not even when the new battery...
When you jump started the vehicle, it started as normal and you drove to a shop to have a new battery installed.?? Correct??
1. Who removed the old battery and installed the new one?
2. Did the car start normally immediately after the new battery was fitted? How frequently were you able to drive the car on the new battery before the problem you described appeared?
3. Has anything been done to the vehicle since the new battery was fitted.?
Dec 21, 2012 | Cars & Trucks
Installation instructions for mercury 20hp electric start conversion
remove flywheel and install flywheel ring and charge coil install start button and neutral switch and starter , and landyard switch battery cables and a battery
Feb 11, 2012 | Boating
Computer just shut off and wont come back on. what can i do?
your battery power plan is not set correctly.
you have a bad battery
unplug unit. Take out battery pack plug unit into power without the battery installed.
if it starts up go to control Panel and reset power plan. have alarm go off at 20%
shut computer down... install battery pack...Start the computer
you should see battery icon and it should indicate it is plugged in and charging. if it doesn't start up you may have bad battery
Nov 27, 2010 | ASUS Eee PC 1005HA-PU1X-BK Netbook
Im trying to open my DELL vostro 200 desktop but it wont turn on. Hope you can help me to fix it. thanks!
you may not like the answer
unit may been dropped
suggest you remove battery and start unit without battery installed.
don't worry if it starts up goto e-bay and price a new battery.. I said price not bid or buy..get info off battery...shut down computer pull power plug...install old battery...install power plug...start computer.
if computer starts up... good. everything is great.
if not determine if battery is bad,,, best test is a load test....next best test....borrow a similar battery from a known working computer,,, if the computer starts up goto ebay and bid on a battery.
Nov 25, 2010 | Computers & Internet
Hard to start, new battery Son installed amp and subs for his stereo, now hard to start. Had to jump start to get home, thought it was battery. Disconnected all of the **** he hooked up left on charger 6...
the sound system may have damaged the electrical system burned up ground straps,overheated relays/solenoids and damaged alternator by pulling all that power to operate the system have starter and alternator tested and check the electrical system for damaged or burnt lines and its components
Feb 22, 2010 | 1989 Chevrolet C/K 3500
I have 2 deep cycle batteries. A selector sw. will select either battery or both. I want to install a starting battery and another switch, possibly to to select house or starting. I then require the...
Install your new start battery and connect it to the engine as normal. be sure to ground the additional battery to the others. Then install an automatic charge relay between the start battery and the common on the battery switch for the original pair of batteries. This will allow the engine to charge its own battery and whichever battery(s) you have selected on the dual position switch.
Sep 27, 2009 | Boating
A25 willnot start with battery installed will start without batt
the reason behind that is your battery has gone bad. that is how us techs actually test for a bad battery if the computer powers on without the battery but not when the battery is installed the battery is bad.
hope this helps
please rate well.
Apr 05, 2009 | Toshiba SATELLITE A10 A15 A20 A25 A35 A40...
Open Questions:
Toshiba Laptop doesn't start up. Black screen [Solved] -Dataalign If you are facing any kind of issues in Toshiba laptops or other products related to Toshiba brand, then you have come to the right place, as this article is an overview of where you can find the right kind of services, required for proper working of the gadgets by any tech savvy person, in particular the ones using Toshiba products. Another beneficial thing about using Toshiba products is its reliable Toshiba Customer Service , which can be reached any time for assistance with guaranteed satisfactory results. Toshiba customer care services are provided by highly efficient and knowledgeable tech support technicians having years of working experience in the field of providing dependable services to the customers of Toshiba. Toshiba support services provided by Dataalign are the best in class for their consistent services and highly advanced way of resolving tech issues faced by the customers. Dataalign tech support team comprises of expert technicians and they make use of high class technology for fixing the issues in Toshiba laptops and other devices as they have proper knowledge of all kind of issues with their perfect resolution. Dataalign technicians can be reached easily anytime from anywhere through the toll free helpline number +1888784-9316. Dataalign assistance providing Toshiba Tech support engineers are selected through a rigorous process of selection which makes them efficient for providing right support in minimum time with high accuracy. Technicians of Dataalign assist the customers in the most polite way with the assurance of providing highly accurate solution for every issue. For the answer of any kind of query related to Dataalign or for help regarding tech issues contact Toshiba support on their toll free helpline number.
Jun 21, 2018 | Toshiba Computers & Internet
See all HP Pavilion dv2020us (882780664913) PC Notebook Questions
HP Pavilion dv2020us (882780664913) PC Notebook Logo
35 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
