Question about Dell Inspiron E1505 Notebook
TSST corp DVD+-RW TS-L632H ATA device don' t work i installed norton security 360 and i had kaspersky in my computer and the device vas deleted
    Champion:
  • 206 Answers
First, remove the AV that deleted the device. After that, right click to my computer, manage, device manager.
The on the right panel, right click on any device :scan for hardware changes.
Now the computer should find the device, and install the driver for it
Posted on Nov 19, 2009
TSST corp DVDRW TS L632H ATA error 10
http://www.pcworld.com/product/29398/dell_inspiron_e1505.html?p=specs
Kel,
1) Left-click on Start
2) Right-click on My Computer.
3) Left-click on Properties at the bottom of the list.
4) Left-click on the Hardware tab.
5) Left-click on Device Manager
6) Left-click on the + sign next to Disk drives
7) Right-click on the name of the optical drive -
TSST TS L632H
(Name and model number, actually. may just have TS L632H )
8) Left-click on Properties
9) Left-click on the Driver tab
10) At the bottom left-click on Uninstall
A Microsoft 'squawk box' will come up.
"Warning you are about to uninstall this device, ya-da, ya-da."
Left-click on OK.
Close all windows. Go back to your desktop screen. Turn the computer off.
(Start > Turn Off Computer > Turn Off )
Wait 1 minute. Turn the laptop back on.
After Windows has fully loaded, (And all the programs you have in the Start menu), you should see a pop-up out of the system tray.
"Found IDE/ATA device", and perhaps another one after it,
"Found TSST TS L632H"
No?
Suggest you remove the optical drive, and reinstall it again.
Not that big a deal. One screw, and it slides out. There are contact pins that may be 'corroded'.
(They are gold plated. Gold isn't supposed to corrode. My word )
By unplugging it, (BY sliding it out), and plugging it in again, it will help clean the contact pins. Mostly it helps ensure the optical drive is plugged in tight.
http://support.dell.com/support/edocs/systems/ins6400/en/sm/index.htm
Optical Drive
http://support.dell.com/support/edocs/systems/ins6400/en/sm/opdrive.htm#wp999869
Still no? You need a new optical drive.
http://www.discountelectronics.com/index.php?l=product_list&c=3554
Just from a quick search.
For additional questions please post in a Comment.
Regards,
joecoolvette
Jul 10, 2012 | Dell Inspiron E1505 Notebook
Code 39. Windows cannot download device. Driver
Go to http://pcsupport.about.com/od/driverssupport/ht/upperfilters-lowerfilters.htm for the solution. I had a similar problem (Code 39) with my optical drives and Windows 7 64-bit. This solution corrected it.
Aug 09, 2010 | Dell Computers & Internet
How do I install a TSST corp CD/DVDW TS-L632D ATA device
It should just plug in and windows will reconize it.
Sep 25, 2009 | Computers & Internet
TSST Corp CDDVDW TS-L632N ATA DEVICE
Try to uninstall your optical drive on device manager and restart your system.
->if that doesn't work try a firmware update.
->if that still doesn't work,replace optical drive.
that should resolve your problem
May 29, 2009 | HP Pavilion DV6700T Notebook
Inoperable DVD RW in Dell Inspiron 1525
Probably the quickest way to verify if the drive itself is good is to boot your restore disk. If it boots that, then it is probably a driver conflict.
Start by turning off anything you can in the bios. Network, printer port, usb, etc.
Reboot and try deleting drivers in the device manager. Then let it rediscover the devices. Sometimes that will do it.
Apr 28, 2009 | Dell Computers & Internet
TSST Corp CD/DVD RW TS-L632M ATA device wont play discs. Driver is current
I also have the TSST cd/dvd with the same problem but I just realized that is a comflict between all these programs I have installed (Windows Media Player, Sonic and Roxio Easy Creator 6). WMP will not even show it, then I went to Roxio audio central an it worked perfectly. I tried to change the default back to WMP but it wont take it. I believe this happens because Roxio was the last I installed and took control of the sound. Hope this help. I will be uninstalling my WMP and installing it again so that I can keep it as my first choice.
Apr 22, 2009 | Computers & Internet
The TSST corp DVD+-RW TS-L632H ATA Device in my computer
Click on the link below. I had the same problem. Downloaded the software, and it was fixed within 5 minutes.
http://support.microsoft.com/gp/cd_dvd_drive_problems
Mar 09, 2009 | Dell Inspiron E1505 Notebook
Error 39, corrupt DVD/CD-Rom Drive
This has been a common windows issue. I'm sure that this will solve your problem. You can go to this link, http://tinyurl.com/toshibadvd, download the registry file and run it. After that, just restart your computer and it should be good to go.
If you're not sure and is worried about security since this is messing with the registry, you can just click on this microsoft link where it explains and gives you detailed instructions on how to manually edit the registry and fix the problem. http://support.microsoft.com/kb/929461.
This is typically the same thing, the first one is just a shortcut on how to do it. Just a reminder, EDIT THE REGISTRY AT YOUR OWN RISK!!!
Mar 30, 2008 | Toshiba Satellite A205-S4617 Notebook
Dell Inspiron E1505 Notebook Logo
930 people viewed this question
Alun Cox
