Question about IBM ThinkPad T43 Notebook
How to change screen resolution of t43 if it is
How to increase the screen resolution of t43 if it says max resolution is 1024 x 768
    Problem Solver:
  • 5 Answers
I Agree and Disagree with Ikkenom. the IBM T43 came with two monitors resolutions as you can see here:
http://www.thinkwiki.org/wiki/Category:T43
This means you may or may not be able to get a higher resolution. If you have a higher resolution monitor, and there is not option to go to a higher setting i would suggest the following, otherwise you are SOL
Depending on if you are running XP of Vista, follow the selected links and install the Video Drivers and Catalyst Control Centre, if you still can not achieve a higher resolution..
ATI Radeon/FireGL Windows Vista N/A 26 Apr 2007
v8.343-070209a-043671C Windows XP, 2000 N/A 26 Nov 2009
v8.593.100.7-090929a
Try running windows updates, and going into hardware optional, sometimes i have seen a video update there for the higher resolution.
Hope this helps
Posted on Dec 09, 2009
    Brigadier General:
  • 10,406 Answers
That 1024-by-768 value is the MAXIMUM supported by the computer.
The only way to go to a "higher" value is to buy a newer computer.
Posted on Nov 18, 2009
How to make my fonts smaller
Quick answer - not specifically to change font size, but to change whole screen size
The whole screen size can be magnified (zoom in) by simultaneously pressing CNTRL + ; the reverse operation (zoom out - what you want I think) is performed by CNTRL - (press cntl and + keys simultaneously)
Or change (increase) the resolution of the screen by right clicking a blank a blank area of the desktop and selecting 'screen resolution' in Windows 7 or in XP one the tabs similarly labeled, and increasing resolution if not at max already.
12.February.2015
Feb 12, 2015 | Computers & Internet
My computer monitor shows a message "out of range". I can't get rid of the message or show anything from my computer.
The resolution your computer is sending is greater than the maximum support resolution of your monitor that isn't working or is a resolution not supported. Connect one of the monitors that works and turn down the resolution to something small (800x600 or 1024,768) and then switch to the original monitor back, you should see a picture and can adjust the resolution to something larger that the monitor supports.
Aug 08, 2014 | Westinghouse L1928NV Monitor
Cant get a full screen
You may need to change the screen resolution.
Go to Control Panel - Display - Settings tab - in Screen resolution, move the slider to 1024 x 768 and Apply.
If you cannot increase the screen resolution then most likely the incorrect video driver has been installed. Install the correct video driver and you will be able to increase the screen resolution.
Apr 02, 2012 | Computers & Internet
Can I increase the screen resolution on my EV700B monitor higher than 800x600? How?
Open Control Panel - Display - Settings tab - Screen Resolution move the slider to the right to increase the screen resolution.
If you cannot increase the screen resolution, it means the correct video driver was not installed generic VGA driver was installed.
In this case install the video driver for your graphics card and change the screen resolution.
Apr 14, 2011 | Gateway EV 700 17" CRT Monitor
When I hook my tv up to my desktop computer the screen looks like it is going to work (it says dell then the loading bar fills up) as a monitor until it is time for my log in screen to come up. The screen...
hi,
This is normally due to a frequency or resolution incompatibility. Turn on your desktop computer, then change the screen resolution to 800x600 or 1024x768. Save the settings. Reboot to check that it is indeed saved.
Once you boot up on your TV, it should display fine. Gradually increase the resolution and colors to the max your TV can handle.
Feb 28, 2010 | Element Electronics FLX-3211B 32 in. LCD...
How change screen resolution hp g60-117us
If that is the max your current video card will do then your kinda hooped. Most video cards are part of the laptop motherboard and can't be changed out without changing the motherboard..... which means a new laptop.
Sep 27, 2009 | HP Computers & Internet
Resolution 16-10
Your resolution is based on your video cards capabilities. If your still using the original on-board, integrated video I doubt if you'll be able to reach such resolution. Open control panel, open Display. Click the Settings Tab. You will notice Screen resolution & there is a slide bar. Sliding the bar to More will increase the resolution. You'll see what the max is for your video card. As to your LCD monitor it's max resolution is capable of reaching 1680x1050. Keep in mind the word " capable ".
If you need that kind of resoluton you'll need to find a AGP video card that can go that high.
Please vote.....
Jan 30, 2008 | Computers & Internet
Wyse wt3235le running on windows 2000 server
OK What ya do is right click the desktop and go down to properties.. open this and there ya should be able to adjust ya resoloution and colour... It's max is 1024 x 768.
Jun 03, 2007 | WYSE Winterm 3235LE Network Terminal
IBM ThinkPad T43 Notebook Logo
637 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
