Question about Nikon D70s Body Only Digital Camera
Shutter sticks halfway
Recently the my shutter has been sticking after exposure. It doesn't re-set to ready position until I hit the release button again which triggers it to close. It happens one out of every 5 or 6 shots. The images are mostly ok. Now and then there is a ghosting that shows up on these specific shots.
  • 42 Answers
Some mechanical defects could be there at the shutter assembly unit. Must check before it gets deteriorated.
Posted on Feb 12, 2008
6ya staff
SOURCE:
The viewfinder screen is completely black. no image whatsoever. it seems like the camera is functioning everything works from what i gather
Since it's a film camera, there are a couple of things to check:
1. You have left the lens cap on.
2. If this is a single lens reflex camera, take the lens off and make sure that the mirror isn't stuck in the "up" position. If it is, GENTLY pull it down until it stays down. At this point, your shutter may be open. Try cocking the shutter again, fire off a test shot, and see if the mirror sticks in the up position. If it does, you probably need to replace the mirror bumper foam - age can make foam deteriorate into a gooey, tar-like substance that can make the mirror stick in the up position.
3. Does the camera have a T (for Time) setting on the shutter speed dial? If so, turn it off the Time setting and set it to a manual shutter speed such as 1/60 - or whatever your 'X' synch speed is.
4. Your batteries died in mid-exposure. Replace the batteries. You may have enough juice in them to show the viewfinder display, but not enough to finish the exposure and close the shutter.
Nov 16, 2017 | Pentax MZ-60 QD 35mm SLR Camera
How do i get my camera from having a time delay between flash and actual picture
This is a common situation with compact point&shoot cameras. Between the time you press the shutter release button and it takes a picture, it has a lot to do. It has to find the subject and focus on it, meter the light and set the exposure, perhaps set the white balance, and other things. Larger, more powerful (and more expensive) DSLRs have more powerful processors and additional hardware to speed up the process.
One way you can reduce this shutter lag is to press the shutter release button halfway to focus and meter before you need the picture. Keep the shutter button pressed halfway until the action hits its peak, then press it the rest of the way.
Jun 29, 2012 | Polaroid Cameras
Jun 29, 2012 | Polaroid i531 Digital Camera
From the time i hit button and the time the picture actually takes is way to long i miss the pic how can i fix this
This "shutter lag" is a common situation with most compact point&shoot cameras. The camera has to do a lot of work when you press the button, including acquiring focus, metering the exposure, and switching the circuitry from displaying on the screen to recording to memory. More sophisticated (and more expensive) cameras have more hardware to reduce this lag.
You can reduce the shutter lag by anticipating the action. Press the shutter release button halfway to focus and meter. Keep it pressed halfway until the right moment and then press it the rest of the way.
Jun 25, 2012 | Kodak EasyShare C330 Digital Camera
There is too much delay when I try to take a picture.
This is a common situation with most compact point&shoot cameras. The camera has to do a lot of work when you press the shutter release button: it must focus on the subject, meter the light for proper exposure, and switch the electronics from displaying on the LCD to recording the image to memory. Larger (and more expensive) cameras have additional hardware to deal with most of this, eliminating the "shutter lag."
You can reduce the lag by pressing the shutter release button halfway to focus and meter the exposure. Keep the button halfway down until the right moment and then press it the rest of the way down.
Nov 08, 2010 | Pentax Optio S7 Digital Camera
How do I change the shutter speed?
This is "shutter lag," the delay between pressing the shutter release button and the camera actually taking a picture. This is a common situation with many compact cameras. The camera has to focus on the subject, meter the exposure, and switch the circuitry from displaying on the screen to recording the image and saving it in memory. More sophisticated (and expensive) DSLRs eliminate this shutter lag by having more dedicated hardware for this.
With a compact camera, you can reduce the shutter lag by anticipating the shot. Press the shutter release button halfway to focus and meter the exposure. Continue to hold the shutter release button halfway until the right time, then press it the rest of the way.
Jan 17, 2010 | Canon PowerShot SX100 IS Digital Camera
How to get manual focus on Olympus Camedia C-750 ultra zoom digital camera
TTTTTTTTTTTTTTTTTTTTTTTTITf correct focus cannot be obtained
When the subject to be focused is not on the AF target mark (not positioned
in the center of the composition), you can use the following steps to obtain the
correct focus on the subject. This operation is referred to as "focus lock".
Determine the position of the subject after focusing (Focus Lock)
1 Press the power switch.
• The camera turns on in the shooting
mode.
• The lens extends and the monitor turns
on.
• The orange lamp lights.
2 Turn the mode dial and select a
shooting mode.
"Shooting mode" (P.36)
3 Position the AF target mark on
the subject you want to focus on.
• When shooting a hard-to-focus
subject, point the camera at an object
about the same distance away as the
subject.
Press the shutter button halfway
until the green lamp lights.
• When the green lamp lights steadily,
the focus and the exposure are locked.
• When the green lamp blinks, the focus
and exposure are not locked. Release
your finger from the shutter button, reposition
your subject and press the
shutter button halfway again.
5 Keeping the shutter button
pressed halfway, recompose
your shot.
6 Press the shutter button fully.
Try the above, info from D-535, C-370 and X-450.
I can email you the complete manual if this works.
Regards
Phillip
Sep 12, 2009 | Cameras
Shutter takes to long to take pic and subject has moved.
This is a common problem with compact point&shoot cameras.
You can reduce the delay by anticipating the shot. Pressing the shutter release button halfway focuses and meters the exposure. Keep holding it there until the right moment, then press it the rest of the way.
Jan 04, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
I want to have the camera take a pic of my family on its own
Yes. You can even choose between 2 seconds and 10 seconds. Put the people in the shot. Focus the camera on them by holding the shutter button down halfway, and without releasing the shutter button, press the button all the way down to start the self-timer. (That's what the manual says. I go into the menu on the camera and set it up that way.) To do it from the menu: when the camera is on, hit the menu/ok key. The self-timer mode will pop up. Hit the right arrow. Here you can choose between the 2 and 10 second timer options. Select one. The timer won't start until you have pressed the shutter button halfway to focus and press the shutter button all the way down as stated earlier.
Dec 16, 2008 | Fuji FinePix S5200 / S5600 Digital Camera
The camera takes too long to take a photo. What should I do?
Press the shutter button halfway and hold it to set the focus, then press it the rest of the way down to take a photo. If you press the shutter button down all the way at once, it takes time to focus and set the exposure before the shutter releases. It may take longer than when pressing the shutter button in two steps.
Sep 12, 2005 | Epson PhotoPC L500V Digital Camera
Nikon D70s Body Only Digital Camera Logo
76 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Ekse
pictureman4u
Are you a Nikon Camera Expert? Answer questions, earn points and help others
