Question about OKI C6100n Laser Printer
Oki c6100 not printing in color - OKI C6100n Laser Printer
    Brigadier General:
  • 3,513 Answers
This is a common issue with the oki model. Please download the updated drivers and install them fresh from the link provided bellow.
http://my.okidata.com/pp-C6100dn.nsf/openingdrivermenu?OpenFrameSet
Also need to upgrade the firmware .
Thanks
Posted on Nov 19, 2009
  • 44 Answers
SOURCE: my printer is not printing
Oki appear to only have made a B6100 model printer, this is actually classed as a workgroup mono printer and only prints in black and white, It is not a colour printer here in the UK. I think the US may have this as a C6100 and I think it is similar to the 5000 series of printers. the user manual can be found at http://my.okidata.com/PP-C6100n.nsf?opendatabase . I would print a Menu Map and check the settings and also check the driver setting is not set to B/W printing.
SOURCE: Radio Shack Oki C6100 wont print color - firmware needed !
Hey, I got it worked out so that it will print color. I called OKIDATA and initially they said they didn't know what to do and you needed to go back to Radio Shack. Then after talking to a supervisor the associate gave me the following instructions to download
1 - go to okidata.com 2 - click on "drivers" at the top of the page 3 - select "color page printer" 4 - select "C6100n" 5 - click "go" 6 - on the new page that comes up, on the left side of the page, click "Utilities" 7 - Scroll down to "English Job Accounting SERVER" and download the file (version 3.54) 8 - After the program is installed, open it and click the Printer Tab and "Add A Printer" 9 - Once the printer is found, it should show up in the list on the right of the screen. 10 - Right-click the printer and select "properties" 11 - Click the "User" tab - there should be in the status row something about "disabled color printing" 12 - Double click on the rows that say that and for each do the following:
1 - Click the "Use Restrictions Tab" 2 - De-select "print in mono" and "disable color printing"
Then when you've done that for each row, Click "ok"
And then you should be good to go. It worked on my computer right after that. I'm directly connected via USB and also connected wirelessly through our small network.
Posted on Dec 07, 2009
linswad
  • 258 Answers
SOURCE: Radio Shack Oki C6100 does not print color
I'm not familiar with this printer, but my Samsung colour laser has an option in the driver for choosing 'color' or 'grayscale' - make sure it's not something as basic as that for starters.
Posted on Mar 26, 2010
  • 10406 Answers
SOURCE: it only prints black and white
Somebody must have followed the instructions:
Print Only in Black and White:
• Click Start > Settings > Printers and Faxes.
• Left click on Laser to highlight.
• Click File > Printing Preferences.
• Click on the Color tab.
• Click on the circle by Grayscale to move the bullet to that selection.
• Click Apply and OK.
to switch from "colour" printing to "black".
So, "unclick" the 'Grayscale' setting.
Posted on May 09, 2010
  • 366 Answers
SOURCE: when I turn on my OKI C6100 I keep getting a
It may not be an actual problem with your printer. The two things that cause most Communication Errors are a failing Printer Cable and corrupted Printer Drivers. Problems in your actual Computer System [bad software, hardware problems, incorrect settings, etc], can also cause communication errors. You can delete your old drivers and download the latest available drivers.Bad or corrupted drivers can cause many problems. "DEINSTALL" [remove] your old drivers/printer first and then reload drivers.
Reset printer and hope it works.
Posted on Jul 19, 2010
Wide yellow line and blotches in blue background
he poor quality in OKI LED color printing might be fallen on one of the following problems:
- Toner is almost running out
- Drum is scratched or its life almost terminated
- Belt is scratched or its life is almost terminated
- Fuser is scratched
- LED Print head is dirty.
Depend on the knowledge and experiences of each person, the solution is solved easily or takes much time or much labor as well as money This is my suggestion that I have learned from my experiences on OKI C3200, C5300, C6100, C330 that I own:
- First, you should have extra printer accessories suchj as toner and drum cartridges (Y,B, C, M) and fuser, belt for reservation. I think you should have them since someday your printer must need them after they reach to their life limitation.
- Test one after one with the good ones. First testwith tonner cartridges. If the test is OK then continue to test drum cartridges. If it is OK then test fuser and so on. Finally if it is OK, then you must look at the LED Printer heads.
Below is the bad print-out:
:hbc-error.jpg?w=183&h=296After following the steps that we suggest, we found the LED head above the red drum is dirty. Below is the picture after it is clean:
hbc-ok2.jpg?w=181&h=300
Oct 25, 2013 | OKI C3400N Single Pass Color Printer
How do you change the settings on a HP C6100 Printer to print in black ink only.
You can find the settings in the print driver software. Go into your Control Panel and right click on the C6100 in the Printers & Faxes section. Choose Properties, and go to either the Color Management or Advanced tabs. You should see an option somewhere for printing in Monochrome or Color -- select Monochrome (or it might say Grayscale) and save the change.
Aug 22, 2010 | HP Photosmart C6100 All-In-One Printer
It only prints black and white
May 09, 2010 | OKI C6100n Laser Printer
Radio Shack Oki C6100 does not print color... only greyscale. Solution on your site might work on another operating system, but the suggested fix is to download a utility called "English Job Accounting...
Mar 26, 2010 | OKI C6100n Laser Printer
Oki C5500 dont have TC/IP menu, do you help me.
Symptom:
Unable to reach Printer from local network or Printer falling off network and needs to be rebooted before being able to print
Cause:
ecblank.gif ecblank.gif ecblank.gif Resolution:
Install OkiLAN8300e Firmware 4.06 (C5500/C5800) or 4.55 (C6100) update using Oki LPR Utility
Are you on a Mac?
Mar 10, 2010 | OKI C5500n Laser Printer
My printer is not printing in color its a oki c6100 in only prints in black and white
Nov 18, 2009 | Office Equipment & Supplies
OKI C6100 has the following error when printer is turned on: Replace Image Drum 562:C Drum Life
Try this:
1.Press Menu = printer displays "Paper Menu"
2.Press Next 4x = printer displays "System Menu"
3.Press Select 1x = printer displays "Factory Defaults"
4.Press Next 7x = printer displays "Reset Toner Life"
5.Press Select 1x = printer displays "Resetting Toner Page Count"
6.Press Ready
Nov 11, 2009 | OKI C6100dtn Led Printer
My new Oki C6100N won't print in color without some sort of code. Do have have the code know what it is? Thanks in advance and we will repay you.
My new Oki C6100 bought from Radio Shack will not print color, Radioshack wrote firmware so only managers could print in color. Need firmware to write over RadioShack firmware.
Oct 22, 2009 | OKI C6100n Laser Printer
Service call 980:Error
hola
quiem puede ayudarme a desifar el error 980 de ld oki c6100
gracias
Apr 09, 2008 | OKI Office Equipment & Supplies
OKI C6100n Laser Printer Logo
558 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
