Question about Acer Aspire 5500 5570-2609 Laptop
How do you restore display resolution?
How do I restore the display resolution for ordinary computer use?
    Sergeant:
    Champion:
  • 310 Answers
Right click on the desktop and go to properties and set to a diferant resoluition
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
Posted on Jan 10, 2008
My on screen display has gone small
What do you mean has gone small? You mean your icons are smaller?
Try changing your screen resolution. Right Click on an open space on the desktop and select Properties. When the Display Properties window opens select the Appearance tab. Look down at the bottom and you can make sure your Font Size is Normal, if not change it to Normal. Click the Settings tab and change your screen resolution. The higher the resolution, the smaller the icons. Size 1024x768 is what most people use.
You can also get to the display properties to perform the steps above by clicking Start/Control Panel or Start/Settings/Control Panel. Look for Display or Appearance and Personalization. Open it and the display properties window will open.
If you are using Windows 7 you can also just click Start and in the search box type Screen Resolution. Look up at the top for the search results and click on Screen Resolution.
If you can't get it back to the way it was you can try doing a System Restore. System Restore allows you to select a Restore Point (date and time) before you started having problems. So if you display went small yesterday, then select a restore point before yesterday.
System Restore does not delete your data, documents, music, pictures, videos or programs (unless the program was installed after the restore point you selected). To start System Restore click Start/Program/Accessories/System Tools/System Restore then select a data and time before you started having the issue.
If you are using Windows 7 you can just click Start then in the search box type System Restore and look up at the returned search results and select System Restore.
System Recovery on the other hand deletes everything and sets your system back to when your first purchased it.
May 20, 2012 | HP Computers & Internet
I have a lg flat screen monitor, the words are blurred
Is it just the fonts that are blurry, or everything? If fonts only, then this almost certainly suggests that running the ClearType tuner again would solve the problem. But this applies to all displays, so if one is good and the other is not, then this isn't it.
If everything is a little blurry, then this suggests one of two problems -- the first, you report trying, which is that the display adapter is set to a different resolution than the native resolution of the LCD monitor itself. Your display adapter should probably be able to drive 2 monitors (the built-in laptop monitor and the external monitor) at once. You should be able to set their resolutions separately.
Assuming Windows XP: Start > Control Panel > Display > Settings > at which point, you should see two monitors listed in a dropdown. Set them to their native resolutions there (using the slider bar, usually all the way to the right), and save.
If you do have the display resolutions set to their native resolutions for both monitors, then it's possible that your external monitor is messed up. A quick test would be to run the on-screen settings, usually from a button on the monitor itself. If what is displayed there is sharp and what is displayed from Windows is not, then this points to a problem with the display driver. If everything, even the on-screen display is blurry, then perhaps the monitor settings are messed up -- usually there's an option to restore to factory settings -- try that.
Apr 02, 2012 | LG 22" FLATRON LCD Monitor
PC Windows XP 2009 and my Resolution cant go back to original setting i have tryed reseting the whole computer and nothing. any suggestions?
Screen resolutions are a part of the display. Click Start/Control Panel/Display When the display window opens click the Settings tab. Look down near the center of the window and you will see the resolutions bar that you can slide our use you mouse pointer to make it change.
If it fails to change and you know when you started having this problem try clicking Start/All Programs/Accessories/System Tools/System Restore. When System Restore comes up try restoring to a date and time before you started having this issue. Don't worry, System Restore does not delete any data, documents, music, pictures or videos. On the other hand System Recovery deletes everything and sets your system back to like it was when you first purchased it.
Mar 20, 2012 | Computers & Internet
The page dose not fit in the screen its cutoff right to left
Your display settings are wrong go to the display settings in control panel and change the resolution this site will tell you the correct size for your screen top left of your browser where it gives you the option to either Minimise,Restore or close click the middle one to restore this will bring your browser to the full size of your screen and re set the page to fit accordingly if that doesnt help try the link below http://docs.mioplanet.com/lcd_monitor_resolution_chart.php
Jun 27, 2011 | Computers & Internet
All of a sudden the image is not displayed in full widescreen mode it is now cropped at both sides. How do I restore to full widescreen image?> Thanks John Mleczko
You need to adjust the screen resolution.
Go to Control Panel - Display - Settings tab - change the Screen resolution.
Start at 1024 X 768 resolution and increase the resolution till you find a setting that suits you.
Jun 09, 2011 | Samsung SyncMaster T260HD flat panel TFT...
My computer screen is smaller then the monitor. There is about an inch of black surrounding the screen. It was displaying fine yesterday with my current set up but i had to do the factory restore thing and...
First make sure dispplay screen resolution is set to 1024*768 .
For that go to start ->control panel->display->setings set screen resolution to 1024*768 then apply .
If it is already set to 1024*768 then press menu button of monitor and increase horizontal and vertical position also put the picture in center first then increase both H and V position then it will give good display.
Also make sure display driver installed and working fine.
Let me know if you need further assistance.
Thanks for using FixYa.
Jul 03, 2010 | Computers & Internet
Monitor turns on for a while
sounds like your refresh rate is too high for the monitor. try this:
after bios check press F8 immediately, then select "safe mood" and click no if ask if you want to restore. then set your display settings. righ-click on your desktop, click properties, click "settings" tab, set your "screen resolution" to 800 by 600 (safest resolution), click "advanced" button then click "monitor" tab and select 60 Hertz for LCD and 75 Hertz for CRT Monitor. Click apply and restart your computer.
Apr 09, 2009 | Computers & Internet
My computer screen shrank and I don't know how to restore it to original size. Please help me.
right click the screen and if using xp go to properties then display and change the resolution back to how you had it, possibly 800 x 600. If using vista right click and go to personalize then display and change the resolution from there.
Hopefully this will help
Dec 28, 2008 | Toshiba Satellite A35-S159 Notebook
My Laptop screen's color broke up
I don't know of a real solution for this problem, but i know hitting ALT + TAB to go in and out of the games helps restore the resolution.
Sep 25, 2008 | Acer Aspire 5500 5570-2609 Laptop
I was trying to install Adobe Design Standard and I set the resolution to high. Now the computer and the monitor are out of sinc and I get this message: Analog Input Cannot display video mode I have a...
try to look for documentation on you lcd display.. usually lcd displays have a native resolution and attempting to work with a different one, although possible, is not recommeded. if you don't remember what your previous resolution settings were try to use system restore by going to start>all programs>accessories>system tools>system restore and restore to an earlier time (no data will be lost) and if you go back before you install adobe design.. you may have to reinstall it again.
hope this helps.
Sep 21, 2008 | Computers & Internet
Acer Aspire 5500 5570-2609 Laptop Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
