Question about Kenmore Elite 45986 Front Load Washer
Cold water intake will not allow water to pass, does it have a flood safe cut off somewhere? How do I re set it?
  • 132 Answers
Turn the water off going to the unit and turn the unit on with the water still off, then as the machine "starts " turn the water on very slowly, if you have no shutoff at the machine you will have to shut a main off. Just remember to turn on the water very slowly so it wont trip auto shutoff if it has it.
Posted on Nov 18, 2009
Intake Cold water filling into machine while turned off
You have either a faulty solenoid valve on the cold intake or you may have knocked some limescale into the valve while changing the pipes. Try some descaler in the valve first and operate a few times. Hope that makes sense!
Feb 01, 2016 | Washing Machines
Error code e15
The E15 error message specifically indicates that there is a flood issue on the unit. This usually happens when the bottom part of the unit becomes flooded with water.
STEP 2
If this happens, there is a possibility of a leakage somewhere in the system. This occurs mostly on the drainage system of the unit where the water passes through different hoses pipes before finally releasing the water to the sewage. STEP 3
This problem can be solved by inspection. Remove the unit and take off the cover. Drain all the water and look for the source of the leakage.
Mar 04, 2014 | Bosch SGE63E15UC 24 In. Stainless Steel...
1989 mpv mazda does not start on cold mornings and days
I'm assuming the engine cranks with the starter but does not start and run.
check the operation of the cold start injector. This is a separate fuel injector that injects fuel into the intake manifold to help richen up the mixture for cold starts. It operates on a timer that is linked to a sensor that measures engine coolant temperature. Once warm or the timer runs out, the cold start injector is turned off. Other things to check:
Fuel pressure too high (floods engine through cold start injector), engine coolant temp sensor or intake air temp sensor is stuck at full hot (doesn't allow enough fuel for cold starts), fuel injectors are leaking (floods engine with fuel).
Feb 10, 2011 | 1989 Mazda MPV
My washing machine wont fill up with water.
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Dec 30, 2010 | Hotpoint Washing Machines
K1500 1999 Vortec 350. Weak spark causing motor to flood. Suddenly spark gets brighter and the motor starts right up. It takes forever to get to that point though. Any thoughts?
another issue that causes flooding in the Vortec 350 ( which, I assume you have) is the fuel injection spider. The spider assembly also contains a fuel pressure regulator if faulty can allow too much fuel to pass through the injectors fouling the plugs (a common problem), While your in the upper intake you might as well take care of your lower. A leaky inner seal on the lower intake can cause out to ceep in to your heads causing a faulty spark.
Jul 31, 2010 | 1998 Chevrolet K1500
Stops mid cycle
Sounds like a cold water problem. Try running washer set for cold water only. See if it stays running. Most rinses are cold water. If you have low water pressure it can stop due to protection circuit that allows washer to fill for only so many minutes. If it isn't full at end of time span, it may shut down. Try checking inlet valve screens for restriction. Turn off water and remove hoses from back and look into place where you removed hoses. You should see a screen in each one. Scrape out build up with a small screwdriver. Flush out with water.
DO-NOT remove screens to clean. If any debris gets into valve it can cause valve to remain open, flooding house.
Apr 01, 2010 | Zanussi ZWF1640 Front Load Washer
I HAVE HOT (WARM) WATER IN COLD LINES, ESP., THE TOILET 1ST FLOOR, also, I never get very hot water.
Hello,You have a bad faucet/fixture somewhere in the house.The water is by-passing thru gravity to heat up the cold water pipes&toilet when not in use.
Jan 20, 2010 | Grundfos Comfort Series Replacement Valve
Freezer is too cold, ice crystals. Refriderator
I'm not sure which one you have, but try this: Look for the area where the air passes from the freezer to the refrigerator side, in the wall somewhere between them. Make sure that there isn't something blocking the passage. This is a good place to start.
Regards,--W/D
Jul 10, 2009 | Kenmore Refrigerators
I just put in a new carburetor in my 87 corolla sr5 and it has cold start problems and the idle wont stay at a set rpm all the time
You probably have vacuum leaks somewhere. Be sure your base gasket is tight, and all your hoses are tight and not cracked. Use a length of fuel hose held to your ear with the engine running, and listen for a hissing.
May 18, 2009 | 1987 Toyota Corolla 2 Door
Kenmore Elite 45986 Front Load Washer Logo
43 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
