Question about Samsung TXM3297HF 32" TV
Whe turning on the TV, there is an audio tone and the screen lights up for like two to three seconds, then it powers down, turns off, by itself. The flyback transformer was most recently changed.
  • 1 more comment
  • Dick Stubblebine Nov 18, 2009
    As is stated in the heading of my problem, this is a 32 inch 720P, HDTV from Samsung (it has a CRT). It is the model as I stated above, a TXM3297HFX. I can not see in my problem description your second concerns?
  • Dick Stubblebine Nov 22, 2009
    Most recently changed out the flyback transformer. Prior to accomplishing that the TV would not power up. It now illuminates the CRT (picture tube) for like 2 to 3 seconds, and the speakers plays an audio sound similar to what is heard on a phone when you dial a wrong number. Then all goes dead. What might my problems be?
  • Dick Stubblebine Nov 23, 2009
    Wow! I'm going to try this in the morning. I replaced the transistor first, prior to replacing the transformer, and I had nothing. Then I replaced the fly back transformer, and the results were what I posted. Thanks for your latest info.
    Genius:
  • 1,112 Answers
Hello:
If you had the flyback replaced recently, the Horizontal output transistor should of been replaced with it also, it works in conjunction with the FB. It may be brakeing down when its under a load. In my years of repairing Televisions If I have to replace the flyback then I also replace the HOT along with, you may even have a bad flyback again, check the pins on the flyback for open or cold solder joints also. Try this also. With power off hit the mute key on the remote, push number keys 182 and then hit power button. This will put the unit in service mode, if after going into service mode the unit turns itself off then you may also have a main power supply problem..
Posted on Nov 23, 2009
  • Samsung Master
  • 11,800 Answers
The audio tone comes from the transformer. If you can easily hear it it's because the power consumption is high - what causes that i can't know without testing the tv.  It shuts down automatically (designed to do that) to prevent further damage.
Posted on Nov 19, 2009
  • Azrael SRL Nov 21, 2009
    The high level of the sound is caused by the vibration of the transformer, it's overcharged - forced to handle a higher than rated power.
    If the security systems fail then the transformer will overheat rapidly and short - which can easily start a fire.
    Brigadier General:
  • 3,513 Answers
The behavior implies that either a connection is effected by the heat of running or a component is failing under those conditions. It would be helpful to know the following:
1) Make and model of the unit in question here.
2) A description of what you mean by "starts to break up".
The shutdown is occurring because of internal protection circuits that kick in when a problem is detected. This is to prevent further damage. We should be able to provide a more detailed explanation of the problem and possible solutions once the info is posted.
Thanks
Posted on Nov 18, 2009
Toshiba 46 inch regza yellow light blinks and picture wont come on but I have full audio
Most likely the power supply board needs to be replaced. It could also be the T-con board or less likely the display itself.
If you don't know what you're doing, DON'T OPEN THE TV UP TO FIX IT, THERE ARE HAZARDOUS VOLTAGES ON THE POWER SUPPLY BOARD, EVEN WEEKS AFTER THE TV IS UNPLUGGED!
If you don't know how to do it yourself, find some local Electronic repair shops, get quotes, try to find reviews on the shops.
Sep 21, 2016 | Toshiba Televison & Video
When turning on the tv by either remote or switch on side screen will flash blue then turn off. Have unplugged tv still won't turn on.
Search Results
    Samsung TV Keeps Shutting Down - Forums - CNET
    www.cnet.com > Forums > Samsung
    CNETWhen I turn the TV on for the first time each day it shuts itself off within 30 ... There is ablue kill switch there, but you don't want to fool with that. .... The tv will not turn offwith the remote or the side buttons on the tv. .... I replaced the lamp but the tv screen will have a momentary flash of light on the screen then it will turn on and ...
    Philips/Magnavox Tv Problems ? - Home Forums
    ths.gardenweb.com > Home Forums > Electronics
    Mar 26, 2005 - I turned the tv on then off a few tims then eventually the piture would come on. .... time, the LED will flash continuously along with the volume going up to max. ...... You can use the remote to turn the tv off and on but nothing else. ... If you press the power button over and over it stays on a blue screen but as ...
    Top 208 Complaints and Reviews about Akai ' Page 3
    www.consumeraffairs.com > Electronics > Televisions
    Rating: 1.9 - ‎37 votes
    The screen will not turn on with the remote, side switch or rocker arm. .... It will flash for a second and the blue Akai screen will display very briefly, but then .... Akai LCT3201AD TV does not turn on using either remote or power button. ... I turned itoff one night and the next time I turned it on, the green light came on, but it did ...
    Get help with audio, video, or power on Apple TV - Apple ...
    https://support.apple.com/en-us/HT200197
    Apple
Jan 28, 2016 | Televison & Video
Older-model Toshiba TV shuts off by itself
There is a large sand filled resistor on the main board close to where the power cord attaches that cracks. This will stop power until it cools enough to make the connection then heats up rapidly to open it again. It may be worth the trouble if you're handy with a soldering gun and can get the back off the TV. If not then I'd consider getting a flat screen.
Aug 21, 2014 | Televison & Video
DLP powers down after 1 minute; no sound or audio
REPLACE LAMP IF PERSISTENT REPLACE THE LIGHT ENGINE COS THE COLOR WHEEL IS WORN OUT
Jul 07, 2013 | Televison & Video
My tv whe I turn it on will only stay on for 4 seconds and then turns off, and the stand by light is on and blinking.
Have you when set turns off and standby or power light flash to count here the blinks if in a sequence like seven blinks, pause etc? This se should have the error buffer.
Dec 09, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Hi, I have a Sony KDL-46XBR9 LCD Digital Color TV. This morning my son was watching cartoons and it clicked itself off. It has sometimes done this in the past, so we did something else for a couple of...
This tv have a power supply board is the causes and the problems.Ur tv power supply board finally gave out and not supply the right voltages to the tv system anymore.That the board,where the tv power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Dec 06, 2010 | Televison & Video
LC-32SB24U LCD HDTV... Brand new, just out of box. Turn on, goes to language menu for about 1 second max,too fast to adjust, then screen goes black and little green led power light starts to blink. And...
Good Day, texxastam;
Do this:
1. UNPLUG TV
2. HOLD IN VOLUME DOWN &INPUT buttons on TV
3. Plug in the TV. (the TV will turn itself on).
4. A blue "K" should now be showing on the TV screen, release the buttons.
5. Press and release the VOLUME DOWN & CHANNEL DOWN buttons simultaneously on the TV. (A blue service menu will appear on the screen).
6. Using the remote, press the DOWN SELECT button once. (The highlighted line should read INDUSTRY INT (+CAUSE) OFF
7. Using the remote, press VOLUME UP once (OFF changes to ON).
8. Press ENTER. After a few seconds the screen turns green and shows - Industry INIT success - at the top of the screen.
9. Unplug the AC cord for 10 seconds then plug back in.
Good Luck, big IRISH.
PS; I did not make this up... it's from SHARP> again good luck...you may have to do this several times....too...get the timming down.
Aug 07, 2008 | Sharp Televison & Video
Plasma will not turn on
Sounds like u might have a bad power supply
Apr 05, 2008 | Televison & Video
JVC Projection TV shuts down by itself.
47" JVC TV TURN THE POWER ON THERE ARE SOME BLUE LIGHTS THAT COME ON BUT NOT THE TV. THEN AFTER A FEW SECONDS THE BLUE LIGHTS FADE AWAY.
Dec 15, 2007 | Toshiba 50H81 50" Rear Projection...
Samsung TXM3297HF 32" TV Logo
55 people viewed this question
Henry  Thomas
Henry Thomas
