Question about Powerline BellSouth Ethernet Adapter (PL9640ETHBS) Network Adapter
I have a bellsouth powerline eth adapter 9640...We have moved into a new office building and I don't know how to make the new router talk to the adapter.
  • 358 Answers
I believe you should be able to enter the configuration page of your router.
If yes, then follow these steps:
1.) When you get to the configuration page, select the place where the LAN has to be configured.
and Select the router to be DHCP, that is, to distribute IP-Adress dynamically to the network.
2.) After this, get a switch, an unmanaged switch (i.e just a normal switch), and connect your router to it using a straight-through cable, on one of the ports.
On the other ports, connect your PCs.
3.) On your PCs, go to the network adapter and right-click on it then go to properties, then inside the column, select TCP/IP Config and select the "Obtain IP Address Automatically". Do the same for the DNS Server too.
4.) Repeat the same thing for ALL other systems connected to the Switch.
5.) Now, after all these, create a network connection setup and give them all the same Workgroup.
Remember to select that "All the systems connect directly through a Switch" when you are setting it up.
6.) Next, restart your systems.
This should make your system ethernet adapter connect to your router automatically.
In case you are using Vista, what you just need to do after Step 3 is to right-click on your "my computer " icon, then properties, then Advanced System settings, Then click on Computer name, Then select Change.
On this "Change" page, you can just type the name of your workgroup and select OK, then restart your system.
Kindly keep me posted about the problem.
Hope it helps.
Goodluck
Posted on Nov 19, 2009
Asus ac68u router is not working with my powerline adapter. The router is brand new and less than a year old. The powerline adapter are tp link 500mpbs model tl-pa411. I have tried directly connecting
HAVE YOU DONE A VOLTAGE CHECK ON THE ADAPTER? IF NOT, READ WHAT THE VOLTAGE ADAPTER OUTPUT IS. IF THE MEASUREMENT IS DIFFERENT OR DON'T GET A READING AT ALL IT MEANS YOU HAVE AN OPEN CIRCUIT ON THE ADAPTER. MOSTLY MOST WIRES BREAK UNSEEN INSIDE THE PLASTIC INSULATOR NEAR THE PLUG END OR NEAR THE ADAPTER END, WHERE THEY BEND MOST.
Oct 28, 2014 | ASUS RT-AC68U Dual-band Wireless-AC1900...
Using belkin gigabit powerline adapter with a wirless router
Try to configure the 2 routers to work with one another when they are next to each other using standard ;an cable. Once working the powerline should work fine. If you try to configure them when they are apart you have 2 things that could be causing problems to take out the powerline to begin with, then when they are working close, move them apart
Nov 05, 2017 | Computers & Internet
Connected the Powerline adapters to my network, 1 into my Sky D-Link Wireless ADSL Router and one into the back of my PC. The powerlines can see each other but my PC doesn't get network connectivity.
This is the main disadvantage of Power-line devices.
1. Well firstly you need to make sure that the activity lights are ON on both the Power line adapters. 2. Don't use any Surge Protector or Extension cable, just directly to the wall. 3. Try in the same room first. 4. Power line devices works well where wall sockets are interlinked with common wiring as it is the mode of data transfer.
You can just power cycle the device, there is nothing much you can do about this. If its new device, get it replaced
Jul 03, 2011 | D-Link PowerLine AV Starter Kit DHP307AV...
I have had a pair of Belkin Powerlive AV adapters (F5D4072) for a while now and they work really well across my house between two routers. I recently bought a 2nd pair of the newer F5D4074 adapters (old...
There are two standards for powerline: HomePlug 1.0, which has a maximum link speed of 85Mbps and HomePlug AV, which has a maximum link speed of 200Mbps. You can use the two standards within the same building, but they are not compatible with each other.
HomePlug 1.0 - F5D4050, F5D4070. Powerline Turbo (F5D4071, F5D4073)
HomePlug AV - Powerline AV (F5D4072 + F5D4074 + F5D4077 + F5D4081). Powerline AV+ (F5D4075 + F5D4079) + Powerline HD (F5D4076 + F5D4078) and Powerline HD500 (F5D4085)
May 31, 2011 | Belkin F5D4074 Network Adapter
I have just bought Belkin Powerline AV starter kit. I have a Belkin N1 Wireless Modem Router connected through a Carrier PoE adapter. I have tried to connect my Sony TV and PS3 through the powerline units...
Try reset the device and start a new configuration.It seems that your networwork have issues between the router and the powerlines.All need to be in the same network as per router configuration.Connect one adapter to your router and plug it into an available electrical outlet. Plug the second adpter into an available wall outlet and connect the other end to any device with an available Ethernet port such as a gaming console, set-top box, or computer.
pd: OS to use the adapters; Windows 2000, XP or Vista.
Feb 24, 2011 | Belkin Powerline F5D4050 Network Adapter
I have 4 Belkin Powerline adapters, two F5D4074 and two F5D4072. On Belkin website they are declared compatible, but I can't manage to transfer the password between the 72 and the 74, with the result that...
Also try to rest the adapters and reconfigure them again.
Dec 31, 2010 | Belkin F5D4074 Network Adapter
Belkin powerline adapter doesnt connect to internet
try resetting the adapter
if not working try updating the firmware
if not working make sure ur adapter is pluged in the same power(electricity) phase of ur house with the router
the house will have different power phase so make sure of it
both the router and the powerline adapter must be in same phase of electricity
Jan 18, 2010 | Belkin Powerline F5D4050 Network Adapter
Powerline ethernet lost connection
this is usually caused by dirty power, have you installed cfl light bulbs recently?
you might also check to see if any existing full fluorescent lights produce a buzzing noise.
Aug 14, 2009 | Powerline Computers & Internet
Computers & Internet Logo
561 people viewed this question
Top Powerline Computers & Internet Experts
Chris Larocque
Ivan Young
Ivan Young
Are you a Powerline Computer and Internet Expert? Answer questions, earn points and help others
