Question about Hitachi 57F500 57" Rear Projection HDTV-Ready Television
We have a hole in our screen - Hitachi 57F500 57" Rear Projection HDTV-Ready Television
  • collinswildc Nov 23, 2009
    thanks! both screens are damaged 57f59a is the model # and is a hitachi projection
  • SD Tech
    SD Tech May 11, 2010
    Most of these sets have 2 screens, are both damaged? Confirm actual model number and I will get you the part numbers and cost for screens. SD TECH
    President:
  • 1,284 Answers
On a Hitachi model 57F500 there is a super shield screen on the front and its part number is KR02075. Behind that is the actual screen assembly which consist of the lenticular and fresnel lenses and its part number is KR02845. If the impact wasn't that great then most likely you only need to replace the super shield. Either way the parts are around 3$375.00 in cost. Please take a few moments to rate my answer. Thank you.
Posted on Nov 18, 2009
Testimonial: "thanks so much! appreciate your help! "
  • 261 Answers
In this case you will definitely have to replace this screen. But my question is, How did you get the hole?
Testimonial: "3 kids and a light saber! fill in the blanks! any idea of cost of new screen?"
  • Karla Alvarez Tostado Nov 21, 2009
    Well this is the disappointing part.
    They ran between 800-1000 dlls.
    Top Expert:
  • Hitachi Master
  • 14,553 Answers
Part number for the screen unit(contains both screens) is :
UX26082Suggested list price from Hitachi is $251.00
sd tech
Posted on Nov 23, 2009
My hp lcd monitor screen is accidently suffered a pin hole. how to plug this pin hole to make screen normal and prevent white light from escaping from screen and read words on that part of screen which get...
LCD is Short for liquid crystal display, a type of display used in digital watches and many portable computers. LCD displays utilize two sheets of polarizing material with a liquid crystal solution between them. An electric current passed through the liquid causes the crystals to align so that light cannot pass through them. Each crystal, therefore, is like a shutter, either allowing light to pass through or blocking the light.
If you have a "hole" in it then you will most likely have to replace the display.
Aug 29, 2013 | HP Computers & Internet
I have a hole in my screen its a jvc
You need to replace the screens. Call JVC with the model# of your set and JVC will tell you the part# so you can ordere a replacement
Mar 15, 2013 | JVC HD-61Z575 61" Rear Projection...
I descaled my Coffee Deluxe machine and am now having a water flow problem. Water comes out the centre hole in the filter holder just fine but when I put the filter back on, the holding screw blocks the...
Water is supposed to flow through the four holes then to the screen, then the coffee, so if you are not getting any flow through the screen then either the holes in the diffuser are blocked or the screen is dirty.
Mar 14, 2011 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
The chain has snapped and hit the left side crank case and put a hole in it about the size of a 10p. Do you think I could cover this with something and if so can you reccomend anything as the cost of a new...
If you're sure the piece that got punched out is gone and not inside the engine waiting to ruin your day even further then you could in theory get by with good old jb weld.
Remove the cover and totally degrease the thing inside and out. While it's off look for any bits loose inside the cover. Find yourself a bit of steel mesh (window screen) big enough to cover the hole plus a bit. Put the screen over the hole and use a sharpy to mark it's edges. remove the screen and take a drill with a small bit ( < 1/8"). Pop a few holes in the area of coverage of the screen and around the hole. These holes give the jb weld more grip as it will flow into the holes and harden. The holes need not go thru but if a few do its good.
Take a small file and roughen the surface around the hole so the jb weld will have something to grab onto. degrease the area again.......now smear some jb around the hole from the outside and set your screen into the jb weld....add some more jb over the screen. Use a wet finger to smooth out the jb weld (if you add over this then don't forget to clean and roughen again).
Look inside the cover and smooth out any jb that came thru to the inside. Of course you have roughened inside the case so any jb inside will adhere nicely.
Once the jb has fully set you should be good to go....monitor your repair for any leaking. Also look closely for any cracks radiating away from the hole and make sure your repair covers them as well.
Cheers!
Take care.
Dec 08, 2010 | 2000 kawasaki KMX 125
Bottom screen is faded and lines on it
Take the battery cover off by undoing the small screw, when the cover is off there will be five small holes neer the bottem, on the far right near the small philips screw there should be a small hole with little screw deep in the hole. With a thin ended screw driver turn it one way or another it should adjust the screens brightness.
If the dosent work then a new bottom screen will be needed.
Jan 17, 2010 | Nintendo DS Lite Console
In the corner there is a hole but still works
I'm afraid you have damaged the screen, it's lucky that you still get a picture if there is a hole in the corner, the only way to repair it is to have the screen replaced.
Aug 02, 2009 | LG 42LG30 42 in. LCD HDTV
Hole in screen
the screens are very expensive about 400.00 and you would need to go through a tv epair shop to order the screen.
Feb 09, 2009 | Philips 9P5034C 50" Rear Projection...
My screen is screwed
PLEASE RESET USING THE RESET PIN PRESENT IN THE SIDE!!
AND FORMAT THE PLAYER ... GUESS PLAYER HAS INFECTED BY VIRUS!!
Mar 03, 2008 | SanDisk Sansa e200 MP3 Player
How to attatch 7" Pelican Game Glass to slim Ps2
Slim PS2s have to holes on back left and right. The far edges one lower right hand side of the power plug and another on the upper left side of the fan exhaust. Hard not to notice. I've never actually noticed they were screw holes I figured they were just... holes. Hope this helps.
- Xero Necross
Dec 26, 2007 | Sony PlayStation 2 Slimline Console
X10d
through the hole of the screen??? Im sorry I dont understand the question.
Apr 23, 2006 | NEC PlasmaSync 42PD3 42" Monitor
Hitachi 57F500 57" Rear Projection HDTV-Ready Television Logo
214 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
