Ge 7 cycle 2 wash top loader. machine fills, agitates, but the dial stop when it is time to drain.
  • 1 more comment
  • leescott1226 Nov 18, 2009
    how do i start, remove dial?
    do i need to remove dial
    washer wont drain, do i remove the dial, if so how
  • 17,970 Answers
There are two probable causes. firstly have you checked your button trap which is found at the bottom of washing machine. this may be blocked but do put a towel down on the floor as water will escape. this is normal.
Secondly it could be the pump this needs a technician. Sounds like the pump has gone bad, is clogged up or has something such as a sock stuck in the drainage hose.
You will have to unplug it and take the back plate off to check it out.
Can you hear the pump start up after the wash cycle ends? If so, could be your timer is going bad or a clog.
Would check the pump and drain hose for clogs first.
Hope helped.
Posted on Nov 18, 2009
  • 11,896 Answers
Either the selector switch for drain is not reading accurately, or pump/drain is blocked. I first would check for any clogs, in the drain screen and drain itself. Then also check the pump for jams. You can test power to the pump with a voltmeter to see if there is power. If so, then pump could be bad. If no power, then switch is likely bad and you can test that with test light or ohmmeter/voltmeter.
  • Nate Stansfield
    Nate Stansfield Nov 18, 2009
    to remove the dial, you will have to dismantle all the top screws and take apart the top piece that the switch sits in. Then once you have access to the wires, you can test them with an ohmmeter or test-light to determine that it is the switch that is faulty.
Washer fills with water but doesn't begin to agitate to wash. It also drains but doesn't spin when we set the dial to that
Your agitator pindle. has come loose From the spline. Try to lift up on the agitator. If it lifts off the spindle easily then it has worn out the spline. That is what connects the agitator to the s
Feb 06, 2013 | GE Profile WPRE6100G Top Load Washer
I have a approx 11 year old GE WBSE2090A0WW, it will (on light wash) automatically fill, agitate, spin, fill again...then stop. It will continue if I manually advance the dial to spin, then it will drain,...
Do you have a check valve in your drain line to the municipal sewer ? It can prevent backups that are quite unpleasant.
Is your laundry room drain properly vented ? (I know mine is not but so far so good.) New homes built by reputable contractors should meet all codes but there are lots of renos done by homeowners who don't know or don't care.
My front loader has a filter that must be manually cleaned from time to time. The main symptom is very slow filling.
Sep 17, 2012 | GE Washing Machines
My GE top load washer is about 5 months old. It fills up and runs through the agitation cycle but then stops at the end spin cycle. The clothes just sit in the water. I checked the hose for kinks and...
I have had this problem with two of my previous washers a top loader and front loader.Each time it was a faulty pump that drains the water from the tub after the wash cycle is complete. If the water does not drain from the tub the machine will not go to the spin cycle. Both of my washers were 5 or 6 years old when this occurred. If the washer is only 5 months old it should be under the manufactures warranty. Good Luck.
Nov 12, 2010 | General Electric WBB2090G Top Load Washer
Kenmore Heavy Duty Series 70 washing machine gets stuck in cycle.
Either your timing motor has broken or the gears that it drives are stripped. The timing motor is easy to replace but if the gears are stripped you will need a whole new dial assembly.
May 09, 2017 | Kenmore Washing Machines
Fills correctly, won't agitate, drains correctly, won't spin. then goes off after it thinks it's completed the cycle.clothes remain soaked.
it is most likely your washing mode selector it tends to do that because the dial will stop turning and it will cause problems like that.
Apr 09, 2010 | GE WBSR3140DW Top Load Washer
Agitater problems will not agitate
To Reset computer. Unplug for 2 minutes, plug back in, open and close lid 7 times slowly to reset computer. This should solve your problem.
May 09, 2009 | GE WBSR3140DW Top Load Washer
Kenmore washer quit working
it may be waiting for a faulty heater to kick in. try it on a cold water wash, no heat and see if it continues the full wash. if it does not then it may have a faulty timer.
Mar 16, 2009 | Washing Machines
Machine fills and agitates, but won't drain
Please empty your machine and run the machine empty. If the washer goes through the whole cycle without any clothes. Please let me know
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
Ge top loader washer agitator does not work
To check the agitator. Start the washer into wash cycle. Once started Push down on top of agitator. If it catches some times or all of the time when pushing down, then then doggets are worn, under the agitator. You`ll have to remove the agitator to see these. If by pushing down on the agitator, nothing changes, Then you probably have a transmition problem. Check this and let me know what you find.
Nov 27, 2008 | Kenmore 22422 Top Load Washer
Washing Machines Logo
18 people viewed this question
Top Washing Machines Experts
