Question about Kenmore 64902 Electric Dryer
Dryer won't heat up--could it possibly be the heater element?
  • 132 Answers
It could be, but the thermoswitch is a more likely suspect. it is installed on the heater element "tube" with 2 wires on it. With the dryer unpluged, remove the 2 wires and check it with a self powered continuity checker on the 2 leads, if it lights it is ok if no light it is bad. it is held in place by one screw.
Posted on Nov 18, 2009
Dryer won't come on. Wire block burned. Wires test good. Heating coil lookes burned
A good heating element should have continuity. When the heating element breaks, there is no continuity between the heater terminals. But sometimes, the broken ends of the heating element can make contact with the metal heater housing (from vibration) and draw a large current, causing the symptoms you have described.
To confirm a "short" between the heating element and the heater housing, check for continuity between the housing and each heater terminal. (The shorted part of the heating element is usually welded to the housing.) Occasionally, the short will not be welded, but a visual inspection will verify (welding scars and black soot) that a short has occurred, intermittantly.
Replace the terminal block, heater, damaged internal wiring, and possibly the thermal fuse, thermostats, and power cord.
Good luck
Mar 06, 2017 | Dryers
Kenmore 240 volt compact electric dryer not heating model # 110.89182990
U need to check the heating element ,u know how are CALl for service
Mar 13, 2015 | Kenmore Dryers
Kenmore stackable washer/dryer. Model 417.93802209. Dryer will run but won't heat. Flipped breaker. Suggestions?
Possible that the heating element has burnt out, or that the thermostat that controls the element is defective. If you have a low or warm setting try that also as it may use a different element? Good luck.
Jan 20, 2013 | Washing Machines
Dryer won't heat up
Test the heater element first then the thermal fuses
Dec 15, 2012 | Hotpoint NVLR333EE Dryer
Dryer won't heat
This might be a faulty fan belt or a faulty heater element, either way take it to a repair centre and GET A QUOTE before agreeing to any repairs.
Oct 08, 2012 | LG DLE2350W Dryer
Whirlpool dryer overheats element high heat all heat settings
First check the heating element for short to frame. If it is not shorted remove the filter chute and clear it out. The control thermostat has 4 wires. 2 small wires come from the timer and power up a small heater inside the control thermostat making it shut down faster for perm press and knit cycles. Over time this bimetal inside the control stat won't shut down fast enough or not at all. If it won't shut down then the element will gl;ow reed and the base 250 stat on the heater chamber will shut down. If it fails to do so then the smaller one up top will trip at 300f. If it fails to trip or the filter chute is clogged the fuse skinny white plastic thing next to the control tstat will met and shut down operation.
Here is my HOME MOVIE ROPER DRYER NO HEAT
It shows the various components and how to check.
Jul 31, 2012 | Dryers
Dryer does not heat
Whenever I see this problem I look for reasons why the dryer stopped heating. You might think the heating element is the priority thing to check and you would be right. But their are other things to look for besides the element. I inspect the dryer inside and out for signs of lint buildup and vent blockage. If I see a lot of lint I know it might very well be a safety limit has popped. Most dryers have 2 limits mounted next to the heater element on the heater housing.A lager one is rated @250f and a smaller one is rated @300f. If that smaller limit is tripped then you will have no heat,however, the dryer will still run. If the filter housing and blower area really get a lint buildup then a melting fuse rated @350f will kill the dryer so that the thing won't catch fire. I have manuals and repair photos for most American models HERE
Jun 18, 2012 | Dryers
Dryer won't heat I've replaced the heater element
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 11, 2011 | Kenmore Dryers
LG DLE2532W NO HEAT
Sounds like the heater element is bad that is the main cause for them not to heat up . Their should be a cover on the back that comes off and you can get to the heater element after removing it .
Feb 23, 2009 | LG DLE2532W Electric Dryer
Heating element in Crosley Clothes dryer
Before you replace the heating element, check the thermal fuse. All heaters have safety thermal fuse. This opens in case the thermostat fails. This is normally attached on or near the heating element, looks like diode. (When replacing, do not solder ! this will damage the fuse)
May 30, 2007 | Crosley CDE6000 Electric Dryer
Kenmore 64902 Electric Dryer Logo
231 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
