Question about Troy Bilt 5.5hp Self Propelled Mower
Rope binds when trying to start - Troy Bilt 5.5hp Self Propelled Mower
  • 437 Answers
Is the stop cable pulling back far enough to release the flywheel brake? You may have a cable strechted that needs to be replaced. If you can not find your model on line, get it to me and I will try to help..
Posted on Nov 18, 2009
I am trying to sew a rope braid as a quilt binding... the zipper foot is too far from the rope... can I move the needle??
no
but you can get a 1/2 foot that allows the rope to be close to the needle
it is used for piping where there is a need to get the stitch close to the rope
available from any sewing machine supply shop
Jan 25, 2017 | Sewing Machines
323 L Husqvarna Trimmer pull cord wont retract. Put in a new spring driver, other spring is fine. The plastic Drivers are holding the spring in its spot. I've tried the bolt tight and lose.
Check binding of the pulley on it post, that washer is not biding the pulley. Too much side play between pulley and post will cause binding. Also make sure spring in seated in the housing correctly.
  • Rope length before tying knots 30"
  • Rope size no larger than #4 (1/8") Preferablely #3-1/2 (7/64)
  • Tension on pulley. wound tight and back off approxiametly 1 turn.
May 09, 2015 | Husqvarna Garden
I have a Briggs & Stratton 5500 watts generator that I hardly pull the rope for start, begins stuck then its loosen again and again gets too hard to pull, any suggestions please help
If the unit is older it could have heavy carbon in the cylinder heads, it could be a ring sticking and binding, do a compression test. Compression is high or mechanical binding.
Feb 24, 2015 | Briggs Stratton Portable Generator 305cc...
Poulan pro 5020 pull start binds up
Try pulling out the spark plug. Fuel or oil may be in the cylinder. Fluids can not be compressed so this could be the cause of the bind.
Apr 05, 2014 | Garden
What would make a tohatsu m25c2 hard to pull start?
try taking apart pulley case that will tell you if there binding
Jul 16, 2012 | Garden
Recoil pulley assembly keeps binding. Rope stays in pulley, but won't retract. Must remove motor housing , loosen 3 pulley hold down guides, & uncock the pulley. spring tension on recoil is fine....
Have you ever replaced the recoil rope, if you had is it a larger rope then the one that came with it? If so, that could be the cause of the binding. I had that difficulty once.
Aug 05, 2011 | Garden
Starter rope will not pull out all the way. What could the problem be?
There are two possible reasons, one is the rope is too short, or two the starter spring is wound too tight, and is coil binding, start by fitted a new starter cord, and re tention the spring, so as you still can turn the pulley by hand at least a further 1/2 turn with the cord fully out ( to avoid coil binding the spring )
Feb 06, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
CRANK ROPE IS IN A BIND OR STUCK
Hi, if you remove the recoil housing you have a good chance of freeing the rope if it's bound. Try pulling the rope to see where it's tangled and use a screw driver to pry it loose. Good luck.
Dec 22, 2010 | Homelite Consumer Products Backpack...
Chain saw won't start - pull starter pulley hard to pull?
If it worked fine the last time you used it, then pull the spark plug and try pulling the rope. See if it's easier or if gas shoots out of the plug hole. I've seen this happen when the diaphram in the carb goes bad from sitting over winter. It loads up the cylider with fuel and makes it very difficult to pull the rope. If there is no fuel in the cyliner and it's still hard to pull, make sure there is nothing binding the clutch/sprocket. I've had chucks of wook lodged in there that caused it to bind the crank output, which resulted in a hard pull on the rope as well.
May 26, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Rewind don't work
as you put the side with the recoil starter back on the saw, ensure the rewind pack isn't binding. before tightening the screws, pull the rope out a few inches and let it rewind. if it won't, something is binding. keep moving the side panel till it will rewind. I have done this before myself. get it all put back together and it won't work.....
Jan 29, 2009 | Poulan Pro Chain Saw 46cc 20"
Troy Bilt 5.5hp Self Propelled Mower Logo
55 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
