Question about GE Refrigerators
We have a GE Freezer made in 1997. The compressor doesn't shut off.
  • GE Master
  • 5,097 Answers
That sounds like it isn't cooling or the thermostat is bad (and not registering the temperature change). A freezer thermometer might help determine which is the problem. If it isn't cooling, then I'd suggest having the refrigerant replaced by a professional who will check for any leaks in the system. If it is getting cold (and then colder), it's more likely to be the thermostat. It may be possible to order a replacement part. However, I don't know if this is a do-it-yourself job.
In either case, you may want to consider replacing the unit. Energy Star requirements have gotten better over the years and you'll get a more efficient unit.
Posted on Nov 18, 2009
Freezer is making a loud noise. sounds like the motor. GSS201EMA
inside the compressor there are springs which prevent the motor from banging against the case. If one of them breaks the compressor will make quite a bit of noise, It doesn't affect function but is very annoying.
Aug 07, 2011 | GE GSS25SGRSS Side by Side Refrigerator
GE Profile freezer is reading 22 degrees F. I have set it to 0 degrees and it doesn't appear to be working.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jun 30, 2011 | GE Refrigerators
I have a GE model GSS22JERFWW S/N AL243114.The freezer portion doesn't freeze the ice trays and the refrigerator portion doesnt keep anything cold as it should even tuned up to 9 whereas it used to...
Things to check: does the compressor run? Does the fan close to the compressor run? Does the inside fan run? Is the rear wall inside the freezer covered with frost? That would indicate that it is not going into defrost which will have the same result (no air movement). Does this help?
May 20, 2011 | GE Refrigerators
Freezer just stopped working
Is this a frost free freezer? If it is, and the compressor and refrigerant is good, the problem probally lies with the defrost timer. What the defrost timer does, at regular intervals, typically every 12 hours, shuts down the compressor and powers up a defrost coil to melt any frost that has built up on the cooling coils inside the freezer. It probally the small square box that you mentioned. Some have a hole where you can turn the cam to the timer and that should switch the power from the defrost coil to the compressor.
Hope this helps.
Jun 27, 2010 | GE 25.1 cu. ft. / 711 liter Chest Freezer...
Things in freezer melt and re-freeze
Your condenser fan motor at the compressor is either filthy or needing to be replaced. Air flow is pulled over compressor to keep it at a good operating temp. If the fan cannot pull air across compressor it will over heat and shut down on overload. Imagine working in yard on hot summer day and wearing a dust mask over your mouth and nose. Your body shuts down more needing more rest. Same thing with refrigerators, they have to be able to breathe properly also.
Jan 27, 2010 | GE Freezers
Ge side by side tpx24biyaww freezer not cold enough.
hi there,
have check the current rating,this can determine if your freezer is under charge,use a clamp ammeter hook it up on common line of compressor,set ampere on tester to 50 amper so you can read clearly,compare this on rated current on manuals or theres a description tag on backside of your freezer look for rated amperes .this should be done by aircon / ref technician if you can't do this,have check also the leak , have a nice day don't forget to rate me,thank's
May 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Model # GSS20IEPA WW Fridge warm...freezer is fine
HI,
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
any further question let me know.
thanks,
Mar 28, 2009 | GE GSS20IEP Side by Side Refrigerator
GE Side by Side Ref
Sounds like an internal mounting spring for the compressor. Only solution is replacing the compressor. However the compressor can run in this condition for years. Replacement compressors only have a one year warranty. A new refrigerator comes with a five year warranty.
Dec 13, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Sal DeAngelo
Lawrence Oravetz
okcchemist
Level 1 Expert
