Question about Siemens 24 in. SE25A091 Hi-Line Free-standing Dishwasher
It came to the end of a wash cycle but the pump just kept going, when you turn it on the pump is always on and it will not re programme
Samsung washer doesn't drain so I removed and tested pump and it runs fine. Is there some reason why I'm not getting power to the pump?
Check the turn nob and the corresponding switches.. if theres power going to the pump the something from the setting to the pump is broke. Id assume the contacts are not connecting thus skipping the drain cycle or youve got a bad switch
Oct 21, 2016 | Samsung Washing Machines
Zanussi zdt 6053 usually will not run full cycle (on any cycle) but stops with constant error beeps. But it is draining ok and sometimes goes full cycle (not often) Any ideas?
Could be anything!
If you suspect that there is a fault then it will be displayed by blinking LED "END OF CYCLE". As the display of failure in hexadecimal code it can flash up to max. 15 times than short pause and after that repeat fault code. You must to count the number of times the LED "END OF CYCLE" flash up.
Example from user manual: Anti-flood device is activated.
- continuous flashing of the indicator light of the running programme
- 3 intermittent audible signals
- 3 flashes of the END OF CYCLE indicator light
(which means "i30" fault code, the cycle is interrupted and the
drain pump switches on).
Possible causes:
Water leakage from the tub - sump and various connections
(pump, upper spray arm duct etc.); floating sensor blocked
mechanically; microswitch faulty; fill solenoid blocked
mechanically; circuit board faulty (solenoid triac short-circuited);
wiring faulty.
26226179-aipk5px1bmfkdpsmrgevaqwn-3-1.jpg Could be also:
To cancel a washing programme in progress:
- Open the dishwasher's door.
- Press the programme selection/cancel button for about 3 seconds,
until the indicator light of the running programme turns off and the
END OF CYCLE indicator light flashes, indicating that the running
programme has been cancelled and that the machine has
returned to setting mode. It is now possible to select another
washing programme. If a new washing programme will be
selected, check that there is detergent in the detergent dispenser.
NOTE: only during the drying phase, if the dishwasher's door will be opened and remains open for more then 30 seconds, the running programme will be automatically cancelled and the machine will return to setting mode. This will happen, always only during the drying phase, also when the machine is switched off by pressing the
On/Off button and remains switched off for more then 30 seconds.
Dado
Jun 26, 2016 | Zanussi Dishwashers
Oko 72630. Why is it stuck on rinse cycle?
Could be several reasons:
- Selected the "Night cycle" program (means standing with the drum full of water, reason: too much noise in the spin cycle)
- Set to the "Rinse hold" (means standing with the drum full of water, reason: wrinkles on the clothes)
According to your description I think that this is not a failure otherwise error E20 will be appears on display.
Once the washing programme has come to an end, END illuminates on the programme progress display.
If RINSE HOLD was selected, the display beside the START/ PAUSE button flashes.
1. After a rinse hold, the water must first be pumped out:
- Either press the START/PAUSE button (the water is pumped out and the washing is spun according to the completed programme;
After the START/PAUSE button is pressed again, the spin speed can still also be changed during spinning), or
- Turn the programme selector to PUMP OUT and press the START/PAUSE button (the water is pumped out without spinning),or
- Turn the programme selector to SPIN or SHORT SPIN and press theSTART/PAUSE button (the water is pumped out and the washing is spun or gently spun).
At the end of this programme step, the END indicator will illuminate.
2. Open the door.
As soon as the DOOR indicator lights up green, the door can be opened.
Dado
Aug 15, 2015 | AEG Washing Machines
How do i reset washing machine AEG 64840
You can choose the right programme for any type of laundry following the descriptions on the washing programme tables (see «Washing Programmes»).
Turn the programme selector dial to the required programme. The programme selector determines the type of washing cycle (e.g. water level, drum movement, number of rinses) and the washing temperature according to the type of laundry.
The pilot light of button 8 starts blinking.
The selector dial can be turned either clockwise or anticlockwise. Position "0" to Reset programme/ Switching OFF of the machine.
At the end of the programme the selector dial must be turned to position "0", to switch the machine off.
If you turn the programme selector dial to another programme when the machine is working, the yellow pilot light of button 8 will blink 3 times and the message Err is displayed on the display to indicate a wrong selection. The machine will not perform the new selected programme.
Dado
Jan 15, 2015 | AEG Washing Machines
The washer floods at the end of the cycle the pump is working this i know because when i manualy lift the mushroom float it pumps out could it be that there is a membrane in the mushroom float that is...
I'm not entirely sure what you mean by "floods at the end of the cycle". Is water leaking from the washer and where from?
The mushroom float isn't a water level sensor to determine when the washer should pump out. It's a second level safety feature to prevent flooding if the washer overfills. The flow meter regulates the water level in the washer.
Your pump is obviously working and there is no blockage in the drain hose, etc as the water pumps out when you lift the mushroom float. It sounds like the pump isn't receiving a signal from the controller to pump out at the end of the wash cycle. Lifting the float bypasses the controller and runs the drain pump.
Please try the following simple test:
1. Switch the programme selector to "Off"
2. Empty a bucket of water into the bottom of the washer
3. Turn the programme selector to any wash cycle
4. Press and hold the Reset button (start/stop) for at least 3 seconds. The washer should drain.
Please try this test and let me know if the washer pumps out. Please can you also be a little more specific about how and where the washer is flooding.
Thanks,
BElectric
Mar 17, 2011 | Bosch 24 in. SGS43C12 Classixx...
Washing machine will not wash or sping
Sounds like motor not running is this due to belt off/ or motor brushes worn or actual motor burned out ? Try the abc to find out. good luck.
Feb 22, 2010 | Washing Machines
Annoying beep when wash cycle finishes on bosch classixx 1400 express
Starting with the rotary switch in the off position, turn it one click clockwise, press and hold on the bottom right hand button, turn the rotary switch one more click CW and release the button. The number displayed is the volume for button presses, press the centre right hand button to increase/turn off (0). Turn the rotary switch one more click CW to select end of cycle volume, agjust and set the rotary switch to off to leave set up mode.
Dec 06, 2008 | Washing Machines
Wash.machine won't spin
Door lock switch # 131763245 if everything else is working fine this should fix the problem. It shorts out between the motor control board and the door lock from emptying the cycle and spinning. Try running your machine on drain/spin and see if it drains and tosses clothes and then stops with no spin. If that happens then it is your door lock.switch. Easy to replace by yourself and costs $65.00
Mar 13, 2008 | Kenmore Elite 45986 Front Load Washer
Siemens 24 in. SE25A091 Hi-Line Free-standing Dishwasher Logo
43 people viewed this question
Top Siemens Dishwashers Experts
aliasger yq
Mike
Are you a Siemens Dishwasher Expert? Answer questions, earn points and help others
