How do I replace an ink tank? The manual did not come with the printer when it was given to me.
  • wrader182 Nov 18, 2009
    All went well with replacing the yellow ink tank on the Canon IP 6600D printer until I tried to push the tank into place. It just doesn't quite go in. It's exactly the same size as the one I took out, without any trouble. I've lifted up the little gray handle that controls the narrow lid over the tanks, but this tank still
    doesn't go in. There a "push" sign, but I don't think I should have to push with all my might.
    Baffled,
    Bill Rader
  • wrader182 Nov 19, 2009
    Great! Just what I needed. Problem solved.
  • 17,970 Answers
If you can give us more details about the make and model printer, I'm sure we can give the information and solutions to your problem.
Contact us again.
Posted on Nov 18, 2009
  • ZJ Limited
    ZJ Limited Nov 18, 2009
    Review inside the cavity, maybe is something obstruction.
    You tell us that dont have the manual and other documents, check HERE for select the essential docs and driver, etc. You can download directly. Also here you can review the Canon-iP6600D-Service-Manual
    Good luck.
I was given a ricoh aficio 3110dn printer that has not been used in about a year. i need to replace the cyan ink cartridge as it shows in the display to replace.
CLEAN THE MACHINE
These are general guidelines for cleaning and maintenance.
Item Action:
External Covers Clean with damp cloth.
Paper Feed Rollers, Connecting Rollers Clean with damp cloth.
Right Ink Sump Clean with damp cloth.
Friction Pad (Paper Trays) Clean with damp cloth.
Ink Collection Tank: Replace then reset counter with
SP3-008-003
Apr 19, 2017 | Ricoh Office Equipment & Supplies
Hi, I refilled cartridge CLI-526M fromCanon Prixma MG5250 and I have the error U130. How can I resolve the error to reprint? Thanks.
FAQ: An Error Message Is Displayed on the LCD
Issue
If an error message is displayed on the LCD, take the corresponding action described below.
Cause
The following ink may have run out. Replacing the ink tank is recommended. U041 Print head is not installed.Install the print head.U051 / The type of print head is incorrect.Install the correct print head.U052 Some ink tanks are not installed in place. U072 / More than one ink tank of the following color is installed. U071 The remaining level of the following ink cannot be correctly detected. Replace the ink tank. U130 The following ink tank cannot be recognized. U043 U140 U150 The following ink has run out. Replace the ink tank. U163 There are no photos in memory card Contact the support center or service center for ink absorber replacement. Press OK to continue printing Ink absorber full. Service required Timeout error has occurred The device may be incompatible. Remove the device and check the manual supplied with the connected device An unsupported USB hub is connected. Remove the hub. B200Printer error has occurred. See the manual **** Printer error has occurred. Turn off power then back on again. If problem persists, see the manual
Jul 06, 2011 | Canon MG5250 Printer
I think I put in a wrong colored toner cartridge. Pages printing in wrong colors. Can't find a list of the cartridges I should be using.
The make and type of cartridge is generally given in the users handbook/manual provided with the printer. If you do not have that ,you can log on to Canon web site and then go to support. Select your printer model and you can find the the specification of cartridge to be used with your printer. The list of the cartridges is given below: BCI-3eBk Black ink tank, BCI-6Bk Black ink tank, BCI-6C Cyan ink tank, BCI-6M Magenta ink tank, BCI-6Y Yellow ink tank You can also go the this link and download the manual if you do not have the same http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_ip_series/pixma_ip4000#Overview
Nov 17, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
New printer. Black cartridge doesn't work. No black on test sheet
Try
Resetting the Ink Counter When an ink tank is replaced, the ink counter must be reset. The low ink warning is only displayed properly if the ink counter is reset.
Message Prompting Confirmation of Ink Tank Replacement
If an ink tank is removed, the printer will output a message prompting you to confirm replacement of the ink tank at the start of the next print job.
When an ink tank has been replaced, follow the procedure below to reset the ink counter. The low ink warning is only displayed properly if the ink counter is reset.
Important
If infrared communication is performed in Windows XP or Windows 2000, the printer will not output the message asking for confirmation of ink tank replacement.
Reset the ink counter from the printer driver when you replace the ink tank.
1 Check the message, and click Yes.
Note
Mistakenly clicking No instead, will prevent the low ink warning from functioning properly. If this happens, be sure to open the driver's Properties dialog box and manually reset the ink tank counter in the Maintenance tab.
2 Select the replaced ink tank, and click OK.
The dialog box allows you to select the replaced ink tank.
When both black and color ink tanks have been replaced, select both Black and Color.
If you have not replaced the ink tank with a new one, click Cancel.
Resetting the Ink Counter in Printer Properties dialog box
1 Open the Printer Properties dialog box and click the Maintenance tab.
2 Click Ink Counter Reset.
3 Select the newly installed ink tank, then click OK.
Sep 30, 2009 | Canon PIXMA iP90 Mobile Printer
New black cartridge installed. Won't print. HELP please.
Try
Important
Note
Ink catridge emply.
Hello there,
Please download the following manual for instructions on installing the cartridge (ink tank).
http://gdlp01.c-wss.com/gds/0900005979/ip4300_qsg_us_v1.pdf
Detailed instructions are given in pages from 35 to 38.
Merry Christmas!
Dec 20, 2008 | Canon PIXMA iP4300 InkJet Photo Printer
REPLACING INK TANKS
Please perform the steps given in the below webpage to install the print cartridges.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00654420&cc=us&lc=en&dlc=en&product=1141647
Apr 22, 2008 | HP Photosmart C4180 All-In-One InkJet...
Ink cartridge problem
Solution: Snap in ink tanks properly MP500
Ink Tank Seated Properly Refer to the following steps to verify the ink tanks are seated correctly:
  1. Confirm that the printer is powered on and press the Open button. (The paper output tray will open.)
  2. Lift the scanning unit (printer cover) completely. (The print head will move to the replacement position.)
  3. Open the inner cover.
    CAUTION:
    a. Do not try to manually move or stop the Print Head Holder.
    b. Do not touch any metal parts.
  4. Press down on the ink tank until a click is heard, thereby making sure the ink tank is seated properly.
    Note:
    Make sure that the ink tank is inserted in the slot that corresponds to the ink tank's color.
  5. Ensure that all the ink tanks are installed properly and the ink tank lamps light red.
    Note:
    Ink Tank Lamp
    You can check the status of each ink tank according to the way its lamp flashes.
    • - On: The printer is ready to print.
    • - Slow flashing (at about three second interval): Ink is low. Prepare a new ink tank.
    • - Fast flashing (at about one second interval): Ink tank is empty, or the printer is not ready due to an error.
    • - Off: An error has occurred and the printer is not ready to print.
  6. Close the inner cover and the scanning unit (printer cover).
    Note:
    1. When closing the scanning unit (printer cover), be careful not to jam your finger.
    2. When starting printing next time, the print head cleaning launches automatically.
Mar 30, 2008 | Canon Pixma MP500 All-In-One InkJet...
Refilling Ink in Canon Pixma MP830
Hello, I found this in a repair manual for the MP830. summery is to press and hold the stop/reset button for 5 or more seconds. I copied the info from the manual too. The remaining ink amount unknown. [1683] (Applicable ink tank icon) The remaining level of the following ink cannot be correctly detected. An ink tank which has once been empty is installed. Replace the applicable ink tank with a new one. Printing with a once-empty or refilled ink tank can damage the print head. If printing is continued without replacing the refilled ink tank, press the Stop/Reset button for 5 sec. or longer to record the use of a refilled ink tank. Note: After the above operation, the function to detect the remaining ink amount is disabled.
Jul 17, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Error Message - Used Ink tank full
User manuals and trouble-shooting guides for this model can be found here: http://www.usa.canon.com/consumer/controller?act=SupportDetailAct&fcategoryid=230&modelid=7960
Oct 19, 2006 | Canon BJC 2100 InkJet Printer
Computers & Internet Logo
David Payne
David Payne
