Question about HP Pavilion dv6000z Notebook
My DV6000 was hit by a power surge during a lightning storm. It is completely dead. no lights or any indications of power. I have multiple batteries and AC adapters so I know it is the laptop. Is there a fuse anywhere on the power supply?
    Brigadier General:
  • 10,406 Answers
No, there is no fuse.
Is the manufacturer's warranty still valid?
Did you purchase the computer via a credit-card that "doubles" the warranty?
Did you purchase an "extended" warranty from the manufacturer, when you "registered" it?
Did you purchase an "extended" warranty from the retail store?
Otherwise, find the nearest authorized HP repair outlet, and get it fixed.
Posted on Nov 18, 2009
Only one (out of four total) HDMI input is working on my set.
The HDMI switcher IC chips in TVs can be damaged but lighting hits near you house even if the power is protected with a surge protector. The damaging power comes in through the HDMI port and blows the chip out and it can affect just one port or multiple HDMI ports. Your best bet would be to just get a cheap HDMI switcher and use the one working port. The repair on the TV would require placing the control board and would run from $75-150 for parts plus the labor to install it.
Aug 16, 2012 | Televison & Video
I have a 47 inch sanyo. model# dp46848. A transformer blew in a lightning storm and now the tv will not power on. The power light will come on for 5-10 seconds and then shut off. The tv was on a surge...
But, was the cable/satellite feed protected? Lightning can come in from anywhere, not just the power line. The bad thing about the way cable and satellite installers ground things is, they ground to the same grounding system that the house does, which can backfeed the surge through the entire house - it shouldn't, but it can.
I would, however, contact the maker of the surge strip and attempt to file a damage claim. They all come with a liability warranty of some sort.
Jul 06, 2011 | Sanyo DP46848 LCD TV
I have a AT@T Model No. E5908, 5.8GHz Corded/Cordless Telephone/Answering System that has always worked perfectly until a bad lightning storm hit a couple of days ago which caused the power to go off. The...
I hate to be the bearer of bad news, but there is no reset on the phone system, and it's a near certainty that a power surge during the storm "fried" the sensitive circuitry in your phone. The same thing happened to me a couple of years ago and I ended up replacing my phone system. A corded phone in the house at the same time lost its ringer during our storm. To this day it still works fine, but will not ring. While you cannot save your present equipment, it's possible to protect your replacement by installing a phone line surge protector (available at just about any store that sells phones or computers) and a whole house surge protector that you install at the main outside breaker box (you'll need to search the web for that one. Look for a SYCOM surge protector).
Mar 30, 2011 | AT&T Lands Phones
Wii wont turn on, nothing had a lightning storm last night and now nothing
Try replacing the power cable, many times when there is a power surge and you do not have a surge protector it will burn out the transformer on the power cord. If you replace it and still nothing, most likely your Wii has been burned out by a power surge.
Feb 28, 2011 | Nintendo Wii Console
Zenith Z15LCD1 Completely dead set after a lightning storm. Did not have it connected to surge protector. Does it have a fuse for protection?
They have many fuseable links. I would suspect the mains input fuse feeding the on/off switch and power supply primary because if a power surge arrives there are filters that absorb the extra energy and yake out the fuse.
Hope that helps.
Dec 29, 2010 | Zenith Z15LCD1 Television
Lightning Surge, RCA 32V432T, will not power up
Throw TV AWAY,these tvs had alot of problems without lighting hitting them,It probably played out FBT flyback transfomer CK hori out put Transistor if shorted replace FBT also.
Aug 06, 2009 | RCA D52W19 52" Rear Projection Television
Lightning Storm/Affinity Washer
During a lightning storm, a lightning strike could have induced a high voltage surge in your incoming power lines. Left unprotected from these power surges, the weakest link ( normally low voltage electronic controls) are the most susceptable. Just because you had power available at the wall receptacle after a storm doesn't mean that your washer control system wasn't exposed to one of these surges and got damaged. On the contrary, it is extremely likely that the washer took a 'hit' and was damaged.Other devices plugged into the same receptacle may have survived that hit because electricity travels the path of least resistance.. In this case.. that path may have been thru your washer.. My point being is that your washer could have sustained a power surge and was damaged so don't rule that out. Of course, that surge could have taken an internal fuse or other component out too..
Jul 17, 2008 | Frigidaire Affinity ATF7000E Front Load...
HP Pavilion dv6000z Notebook Logo
187 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
