Question about Masonry Tools
How do you remove the blade on a Bosch JS100 Biscuit Joiner? I've got the springs removed and the blade accessed from below, but now what tool do I use to remove the blade? There is no obvious tool like a hex or torx the works. I wonder if the blade is removed from above, but the only way I see that could be done is to take the the arm & motor off. The instructions are vague, I'm lost. THere is a place for a wrench behind the blade and I've got that covered, but what's next? Please help. I am mechanically & technically inclined, but this one's got me. Doug Yasika Danville NH doug.y@des-con.com
  • 5,603 Answers
Not sure about your particular unit, but most of these, like their counterpart angle grinders, have a button to press at the head that locks the spindle so that the blade fastener can be removed.
Posted on Nov 18, 2009
  • 132 Answers
I have seen directions online and they say you have to remove the fence also to access the blade
Free maual
Home Depot has the manual on the product site: http://www.homedepot.com/p/Ryobi-Biscuit-Joiner-Kit-JM82K/100052027 . The direct link to the Use and Care Manual is http://www.homedepot.com/catalog/pdfimages/17/175517e7-c28a-4e27-b960-111cfabb29db.pdf .
Ryobi also has the manuals for most of their products here: https://www.ryobitools.com/power-tools/support/manuals . See https://www.ryobitools.com/support/manuals/details/JM82,%20JM82G , for the JM82 manuals.
I hope this helps.
Jun 13, 2015 | Ryobi Jm82 Joiners
Where can I get a cutting blade for a Cbj-50 biscuit joiner
any hardware store will have them in stock, best way is to remove the blade (pay attention which way teeth are orientated!!!), take it with you to the hardware store and buy same internal and external diameter and teeth number (can be more teeth but not less!).
other way - go to any saw doctor (saw sharpening services) and ask to re-sharpen the existing saw, they usually charge about half value of the blade to sharpen existing one.
if you find answer helpful, please do not forget to vote for it...
Oct 30, 2014 | Saws
I have a Porter Cable biscuit jointer, model 527 and I'm an amateur woodworker, NOT a mechanic. I can't locate my owner's manual on this tool and have the smaller blade in the tool currently. ...
Model 557 is shipped with a 4" diameter blade installed. This blade is used
for all operations except for the "FF" biscuit. The "FF" biscuit requires that
the 2" blade (furnished with the tool), be installed as follows:
DISCONNECT TOOL FROM POWER SOURCE.
1. Loosen four blade cover retaining screws (A) Fig. 10, and remove blade
cover.
2. Depress and hold spindle lock button (B) Fig. 11, while rotating blade by
hand until spindle lock engages.
3. Continue to hold spindle lock button while using the 5/32" hex wrench
(furnished with tool), to remove blade retaining bolt and flange, (by
rotating counterclockwise).
4. Remove blade and store in a safe place for future use.
5. Place 2" diameter blade (furnished with tool), onto blade mounting
flange (orient with teeth facing in same direction as directional arrow
cast in housing, see Fig. 14).
6. Position blade retaining flange (flat side out), to spindle, insert blade bolt
and rotate clockwise until hand-tight.
7. Depress and hold spindle lock button (B) Fig. 11, while rotating blade by
8. Continue to hold spindle lock button while using the hex wrench
(furnished with tool), to tighten blade retaining bolt securely, (by rotating
clockwise).
9. Rotate the "quick set" depth adjusting turret (A) Fig. 12, to the "FF"
position.
10. Lift safety lever (A) Fig. 13, fully retract the plunge mechanism, and
reposition the safety lever as shown in Fig. 14. Slowly release pressure
on plunge mechanism.
11. Reposition blade cover plate to tool, and secure in place with the four
retaining screws (removed in step 1).
DO NOT OPERATE TOOL WITHOUT BLADE COVER INSTALLED
Sep 06, 2017 | Masonry Tools
Manual for Ryobi biscuit joiner JM80
They call it a "plate joiner".
Go to
http://manuals.ryobitools.com/system/files/5567/original/jm80_239_eng.pdf?2011
Sep 01, 2010 | Ryobi Thickness Planer Blades
Is there a 2" blade available for the DeWalt Biscuit Joiner
Because of standardized sizes of biscuits, the only blade you can and should use, is the same size that comes with the tool. Anything smaller will not create the right diameter groove for the biscuits to fit properly.
Feb 16, 2010 | Black & Decker DW682K Dewalt Plate Joiner
Bosch 4000 tablesaw won't start. Brushes replaced
I found that the remaining problem was a intermittent at the switch, which disassembly and cleaning resolved.
Tilting the motor / blade assembly down allows access from below, to the 3 screws fastening the controller circuit board cover on the brush end of the motor. From there, one can easily test exposed wires for power supply, see that brushes are contacting and clean accumulated sawdust.
Jan 06, 2010 | Bosch Electric Table Saws
How to fit bosch PHO 15-82 planer blades
  1. Unplug from mains and turn planer upside down.
  2. Using Allen key (stored in heel of planer) slacken off the 2 sets of 3 screws that clamp the blade in place. One 360 degree turn should be enough
  3. Use piece of wood or flat screwdriver blade to slide old blade out the side of the blade track.
  4. Rake any dirt out of the blade track with screwdriver blade.
  5. Slide in new blades, check it is correctly centred and tighten screws. Take care not to over-tighten.
  6. Repeat with second blade.
  7. Carefully rotate blade carrier by hand checking that blades are parallel to the sole of the plane.
  8. If blades are out of true you will need to remove them again, take off the blade clamping plates and adjust the blade locating plate, which is held in place by 2 further Allen screws.
Pictures below from Bosch manual for further information
Sep 16, 2009 | Bosch Tools & Hardware - Others
Blade change problem for Porter Cable 557 plate joiner
Putting it in the freezer for a couple of hours may loosen the screw by contraction and or you will have to use an impact wrench unless it is completely stripped , then you will have to drill it out.
Apr 08, 2009 | Porter Cable - Cable 557 Factory -...
Masonry Tools Logo
75 people viewed this question
Top Masonry Tools Experts
ray gallant
Tom Chichester
Are you a Masonry Tool Expert? Answer questions, earn points and help others
