Question about Polaris Scrambler Men's Mountain Bike
2001 polaris 400 scrambler. Front axle came loose from wheel. How do i repair it
    Problem Solver:
  • 11 Answers
Tighten the bolt on the inside of the axle
Posted on Nov 19, 2009
What is the correct resistance for the stator on a scrambler 400
try:
http://atvconnection.com/forums/polaris/348629-97-polaris-400-4x4-scrambler-no-spark.html
Also, for more general info, several you tube videos address this topic for motorcycles, but it is the same general concept. If you identify the wiring harness link between the stator and electrical system, the main issue is to test for all legs to be at about the same resistance and for all legs to be putting out about the same voltage at idle and at rpms. See link
https://www.youtube.com/watch?v=5v2LtHlvcqI
Feb 11, 2015 | Polaris ATV
2000 500 scrambler one tire is going in 4 wheel drive when im in 2wd and it pulls me to the right when im driving
could be a bad cv axle joint or maybe your brakes are sticking and also maybe your bearings are trying to freeze up hope this helps
May 30, 2012 | Polaris ATV
I have a2004 400 sportsman A04CH42AQ Only left front brake works good how do i get all 3 wheels to stop at the same time thanks Ron Smith
i would start by bleeding the system.sounds like the problem.the scrambler has two master cylinders.
Apr 12, 2011 | Polaris ATV
98 400 scrambler where do you drain the crankcase oil and wheres the oil tank
i just got a 2001 polaris 500 and the oil tank is under the gas tank behide the rad cant miss
Mar 21, 2011 | Polaris ATV
I have a 400 polaris sport 1998 2 stoke that i put a 4 stroke breather on it and it seems to be looseing power and hesitateing,i was wondering if there is a special breather and filter i need to use
yea it must be a loose breather ie a 2stroke one as the 4 stroke is woven tighter so it gives it less resistance the 2 stroke engine will be getting starved of air buddy one off a car does brilliant trust me there the most open you get
Mar 10, 2011 | Polaris Scrambler Men's Mountain Bike
I have a 2001 Polaris Scrambler. One of the front wheels stays engaged when the machine is switched into 2-wheel drive. Any ideas?
check the wires that come out of the hubs and make sure they did not get snaged on somthing and torn apart
Dec 28, 2010 | Polaris ATV
Helping a friend,where is the starter?Don't want to take off something that doesn't need to be taken off. 2001 polaris scrambler 400 4x4
<br /> <br /> sadly enough there is alot to do to get to the bolts easily<br /> <br /> <ol> <li>take off pullstart not the front few bolts that hold the cord but the ones on the case behind those.<br /></li> <li>you will now see 2 bolts under the flywheel to the bottom those are the front starter bolts.<br /></li> <li>Take off clutch cover and clutches (may be able to get away with just the front clutch) and you will see the rear starter bolts.</li></ol>
Mar 12, 2010 | Polaris ATV
2 stroke scrambler revs high on its own
there should be an idle screw on the carb, set it when the choke has come off. You'll recognise it because it will have a spring underneath it.
Dan
Sep 05, 2009 | 2001 Suzuki GSX 400 Impulse
Polaris Scrambler Men's Mountain Bike  Logo
137 people viewed this question
Top Polaris Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Polaris Cycling Expert? Answer questions, earn points and help others
