Question about Magic Star Karaoke Microphone
The green light just keeps blinking and it doesn't
The green light on the mic just keeps blinking and the whole thing doesn't turn on any more. we tried switching batteries but it still doesn't work. the cradle where we put the mic doesn't turn on. please help.
Did you find the solution, I have the same issue and the Leadsinger company is not a verry serious company no one knows about this and no one can help! Thanks Cathy
Posted on Nov 30, 2009
Afterglow Wireless Headset Blue Flashing mic light
i have the same problem. i am worried. i was playing counter strike and we finished. everybody was congratulating. shortly after a loud beep a bit lower pitch than the turning of and on noise that the headset makes. i turned it on and off. the only thing that stopped the beep was to mute the mic. fiddles with the 2 buttons, the light dimmed greatly and the mic started blinking blue. if you are able to find any way to fix it please contact me on skype : Sassy_Sasquach. Thanks!
Jan 23, 2014 | Radio Communications
I try to turn on the TV and the power light keep blinking but it doesn't turn on, the screen remain black...
The set has a problem that is likely power related===consider having a shop or a tech look at it---cannot wish it away, someone will have to open and check things to even have a chance to fix this.
Dec 03, 2012 | LG 37LG30 37 in. LCD HDTV
Red/green lights both blink and tv will on turn on
Are the red and green lights blinking at the same rate or not? If the green light is blinking every 3 seconds and the red light is blinking every 1/2 second, the lamp door is not properly secured. If both lights are blinking at 1 second intervals, try replacing the lamp. If a new lamp doesn't solve the problem, the TV needs service.
I hope this helps.
Jun 23, 2011 | Toshiba 52HM95 52" HDTV Projection...
My mitsubishi medallion HDTV1080 won't turn on anymore. The green timer light keeps blinking and thats the only thing it does. Please help.
The tv power supply board it is dead.That the board where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Apr 24, 2011 | Televison & Video
6 red blinking lights
You have a bad thermal fuse.
Oct 23, 2009 | Televison & Video
Turn on the power and the green LED blinks on the front for a second, but tv does not power on
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD “device” and “menu” buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC’s is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
Jul 30, 2009 | Mitsubishi WS-55411 55" Rear Projection...
No sound coming from wireless mic
check the battery, if dead replace new. check the switch might be a cold solder or loose wire and finally check the condenser mic by placing a multitester to the two connectors of the mic with one wire from the mic desoldered. if there's a continuity, then its good. if there's no continuity the mic condenser is busted. go to radioshack and find replacement mic condenser.
Mar 28, 2009 | LeadSinger LS-3222 Consumer Microphone
Tv cuts off and green light flashes
Yup, it seems a lamp problem can give a blinking green light over the 10 times (1 - 10 times for diagnostic codes), but in my case rather than replace the bulb if it works for a minute then resets with the green light blinking, do what I did.
Take the lamp out and inspect it, it has breather screens top and bottom, if it cant breath because there clogged with dust, clean them, and you can remove the screens, use q-tips and clean the inside. I saved the cost of a lamp and it's working fine!
Jun 27, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
Magic Star Karaoke Microphone Logo
332 people viewed this question
Top Magic Audio Players & Recorders Experts
Michial Gueffroy
conquer111
Level 1 Expert
T-Comtech Repairs
T-Comtech Repairs
Are you a Magic Audio Player and Recorder Expert? Answer questions, earn points and help others
