Question about Dell 3100cn Laser Printer
Drum full of waste toner. Do i have to replace the
I am getting an error message "drum full of waste toner". Do I have to replace the whole drum unit?
  • 547 Answers
I have no idea what ikkenom is smoking.
The Drum Cartridge unit is as user-replaceable as a toner cartridge.
Yes, you will have to replace the drum cart.
http://accessories.us.dell.com/sna/PopupProductDetail.aspx?c=us&l=en&cs=bsdv&sku=310-5732
Dell wants $169 for this part. Here's what it does:
Highlights
* Applies toner to the page
* Provides a usable life of up to 42,000 page impressions (up to 10,500 pages per color)
Overview The Imaging Drum Kit from Dell is specifically designed for use with Dell Color Laser Printer. This kit includes an imaging drum and instructions on how to replace it. It applies toner to the page and offers a usable life of up to 42,000 page impressions (up to 10,500 pages per color).The part number located on this toner cartridge is: P4866
Manufacturer Part# : M5065
Dell Part# : 310-5732
It comes with very detailed instructions on how to remove the old cartridge and install the new one. Very easy, but there's no way around the price tag.
Posted on Nov 25, 2009
    Brigadier General:
  • 10,406 Answers
This is not a "user-replaceable-part".
Take the printer to a qualified technician, and pay him/her to trouble-shoot.
Posted on Nov 18, 2009
My machine says Drum Error, refer to trouble shooting for maintenance?
Drum Error:
The corona wire on the drum unit
needs to be cleaned.
Clean the corona wire on the drum unit.
(See Cleaning the corona wire on page 122.)
or
The drum unit has reached the
end of its life.
Replace the drum unit.
(See Replacing the drum unit on page 130.)
and/or
Open the front cover
press Clear/Back
Press Start, then 00
after the screen show "accepted"
close the front cover and you are good to go.
Feb 03, 2011 | Brother MFC-7340 All-In-One Laser Printer
E019 in canon copier 2016 j.the machine runs n at last error comes E019, may be toner censer has problem how can i solve this.where would be the censer pls help me .
You need to replace the drum unit. The E019 error code means that the Waste Toner is full, but the problem with this model is that the waste toner cartidge is built in the drum unit so you have to replace the whole drum unit.
Nov 11, 2010 | Canon iR 2016i Black and White Copier
I have a Canon Image Writer 2020. I am geting an
waste toner is full.replace the whole drum unit
Mar 03, 2010 | Canon imageRUNNER 2000 Copier
Canon imageRUNNER 2020 alternates between displaying Error Code E019 and saying "Waste Toner Full".
hi you have a waste toner error code, the waste toner is apart of the drum unit in these machines so you will need to order a new drum unit for it.
easiest way to fix the problem.
Canon Tech
May 28, 2009 | Canon imageRUNNER 2000 Copier
Waste Toner is full. It's a iR2020/iR2016 photocopier and I need to clean it. Please help.
Hello sir; According this particular model,the waste toner box comes with drum unit, for another word if waste toner box is full you have to replace whole drum cartridge.
May 08, 2009 | Canon iR 2016i Black and White Copier
I just replaced the black ink cartridge and now getting the message that drum waste is full replace. What does this mean?
Apr 03, 2009 | Dell 3100cn Laser Printer
Copier ha a message that says replace toner drum.
It means that the internal drum unit is full of waste toner and that the drum is worn out too. The people at cannon made the drum unit to last when the waste toner internal compartment is full.
When you buy a new drum the instructions are in the box and very easy to install.
hope it helps
Mar 24, 2009 | Canon ImageRUNNER 1670F Copier
Imagerunner 2016, waste toner full error message
hey, wel if the copier is showing a message saying that the waste toner is full it means the waste toner deposit is attached to the drum unit.
so, open up the frotn cover, pull down the (drum)-lock lever, it should release the left cover, then pull towards you the drum unit, and there you go.
the black case with a small trasparent cap is the waste toner deposit.
you have two ways to go.
1 you may remove that rounded transparent plastic cap and be able to vaccum the waste toner (dont even try reusing that toner, it wont work ok) or
2 you can go the other way wich allows you to easily vaccum it: remove the drum (the roller itself) then the charger roller, then the cleaning blade and there yo go again, but now you got more space to vaccum and believe me it is easier this way.
an additional choice would be to buy a new drum unit gpr18 i think (check please) and forget all about vaccum-ing.
Jan 23, 2009 | Canon imageRUNNER 2016 All-In-One Laser...
Error message "Waste Toner Full Replace The Drum" which was replaced approximately one month ago.
Open the left cover,remove the drum.you will see on the drum unit there is plastic plugs that you can remove,remove them and remove the waste toner in the dustbin.put the plugs back and insert the drum in it's place.
Dec 04, 2008 | Canon imageRUNNER 1023iF Black and White...
Clear Error Message
Hello Bruce,
I want to help but I am a bit confused. First of all just to provide you with additional info, there are basically three criteria that cause a need to replace the drum. One ,as in your case,is when the waste toner level reaches a level that the waste toner sensor gets covered with toner and it gives you the prompt you received. What happens is that despite the fact that in an ideal world ALL of the the image that is formed on the drum to be transferred to the paper actually does transfer completely and therefore no waste. Real world is that a small portion of the image remains on the drum and is cleaned off and deposited "into" the cavity of the drum where the waste toner receptacle resides and the waste toner sensor does as well. Once the waste toner sensor sees an excessive level it generates the prompt you received and the cpu begins to count pages (and I'll be d$%&ED if I can find the exact number) and if the drum is not replaced the device will give an error code and shut down. We will return to this topic in a moment as it is truly the source of our dillema. The second reason to replace the drum is that copy quality has turned to ****. The 1023 drum is good for........laugh with me as to how they determined this number, 26,900 copies. Not 26k. not 27k. Collective ROFL. This second criteria manifests itself in just crappy looking copies, and the end user calls for copy quality problems. The third reason is the abstract. For example a foreign object damages the drum. This includes the human hand.LOL.
So, after all that hot air I just expelled I am at a loss as to why you are still getting an error message. The new drum should have satisfied all the requirements as the waste toner sensor is happy now, and there is no counter that needs to be reset. I am sorry that I could not be of more help. I know you will cuss me for saying this, but, power off and power on and see if that helps. And we cannot eliminate the fact that the waste toner sensor that resides in the drum unit is bad. Entirely possible.AND...remember that the cpu is counting only sheets of paper not toner usage. So if the copier thinks the waste toner is full, and it does not "see" that everything is ok now, it will give you an E-19 error code after so many sheets of paper pass by. I looked in the service manual and could not find a finite number of copies after the waste toner sensor gets pissed. Then the machine goes wheels up. If I can help further(like I helped alot this time) let me know. ...........SPINAL.......
Jul 14, 2008 | Canon imageRUNNER 1630 Copier
Dell 3100cn Laser Printer Logo
1,051 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
