Question about Atkins Digital Thermocouple Thermometer - Range -40 - 500F
How to recalibrate the atkins thermocoupler model 340
    Problem Solver:
  • 5 Answers
A !
Posted on Nov 18, 2009
How to put batteries in item listed below
You need to post make and model number. A Google of those numbers brings up nothing.
In my experience battery compartments always have a diagram. 'Springs' always go in the negative, 'Buttons' always on the positive.
40429t0ss 340 Google Search
Dec 05, 2016 | Cameras
Wires to coil are not hooked up on a 72 dodge with a 340 v8
Since you have not provided the model of your 72 Dodge you might want to do a google/bing search on your 72 Dodge (Dart, Challenger, Charger or whatever) and search 72 dodge 340 coil diagram select your model and it will provide a diagram for your model... Hope it helps...
Oct 12, 2013 | Cars & Trucks
What flavors does the Atkins shakes come in?
The Atkins shake comes in six different flavors: milk chocolate delight, dark chocolate royal, mocha latte, cafe caramel, vanilla, and strawberry.
Feb 04, 2013 | Health & Beauty
How does the Glucerna Shake and the Atkins Shake compare?
These two popular meal replacement shakes have both differences and similarities:
Glucerna Shakes are lactose free and gluten free. They are taken by people with diabetes in order to help them control their A1C. Atkins Shakes are low carbs, high protein shakes used by people who are on a low carb diet.
Glucerna shakes contain 27 grams of carbs per serving, while the Atkins shakes contain only few grams of carbs.
Glucerna shake contains 10 grams of protein while Atkins shake contains 15 grams of protein.
Glucerna shakes contain around 200 calories per serving. Atkins shakes contain around 150 calories per serving.
Looking for year model for an epiphone sst studio serial # 10082302339
check out giovanni stores do will be able to help you, it belongs to the chet atkins family guitars
Dec 01, 2011 | Epiphone SST Studio Guitar Acoustic
Need manual for Cooper Model TRH670A
You are going to need to contact the manufacturer directly. Cooper-Atkins can be reached at:
http://www.cooper-atkins.com/Contact.asp
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 09, 2011 | Heating & Cooling
Temperature does not always reach set point of 425 F.
Oven will not hold correct temperature:------- This can be caused if temperature probe not working.Resistance across temperature probe leads at room temperature (70°F) should be approximately 1096 ohms.----------- Other possibility for this problem is :--- Temperature control not calling for heat.When heat is required, there should be continuity between terminals 6 and 7 on temperature control.-----------Inadequate or improper ventilation.Check ventilation hood. Verify draw and make up air adjustment.-----------If all this checked out ok then its calibration problem.For calibration follow this procedure:--
It can be problem with temperature controller. TEMPERATURE CONTROLLER (Standard-Control Models Only) The calibration of the temperature controller should not be changed until sufficient experience with cooking results has definitely proved that the temperature controller is not maintaining proper oven temperatures. Before any recalibration is attempted, the oven temperature should be checked by the following procedure: 1. Remove all trays and pans from the oven. 2. Place a thermocouple or a reliable mercury oven-type thermometer at the center of the middle rack. 3. Turn the oven ON and set the temperature control knob to 400°F. 4. The amber "heat on" light will go out when the oven temperature is reached. 5. Allow three cycles for the temperature to stabilize. 6. Read the thermocouple or thermometer immediately after the light goes out for the third time, and again immediately after it comes on the next time. 7. If the average of these readings varies by more than 10°F from the dial setting, recalibrate by the following procedure. Recalibration should be attempted only by a competent service technician. Use the following procedure to recalibrate the oven: 1. Loosen the two set screws that secure the temperature-control knob to the temperature-control shaft. 2. Remove the knob from the shaft, being careful not to rotate the knob or shaft. 3. Replace the knob on the shaft so that the indicator mark on the knob points directly at the temperature that was measured at the center of the oven. 4. Re-check the oven calibration. ----------- Part number for temperature probe is 1181996 and you can order if from the Southbend service center. -------- If you want the manual and wiring diagram for your oven.Please click the link directly:-- http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man ----------- after you click the link,a page will open in that you fill the 5 letter number.And click the "download now " option.It will ask you to save or discard.Click the save option and download will start.It will take 2 mins to download.Then click the download file to open it.And go through the manual.------------This will help.Thanks.Helpmech.
Jan 28, 2011 | Southbend ES10SC Electric Single Oven
I can't get my scanner to work on my Deskjet 340.
The most common solution is to download the full-featured software for your model and operating system.
HP DeskJet 340 Downloads
If you have some other model, please do not fail my solution. Instead, post more details of your printer model. Thanks!
Jan 12, 2010 | HP DeskJet 340 InkJet Printer
Oven temp low. recalibrated up 35 degrees, 375
no you need to still recalibrate the unit if your using the baking style thermo they are famous for being off 75 degrees
Aug 09, 2009 | Kitchen Ranges
Atkins Digital Thermocouple Thermometer - Range -40 - 500F Logo
503 people viewed this question
Top Atkins Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you an Atkins Measuring Tool and Sensor Expert? Answer questions, earn points and help others
