Question about Jensen GPS
Having trouble getting directions... freezes up
  • 10,865 Answers
Hello. Thanks for choosing Fixya! Locate the reset button. In most Jensen models it is very small. Push it in with the stylus and you should be back up and running. Best regards, Joe
Posted on Nov 18, 2009
The screen freezes on home page and cannot get any further
Hi, If you are having trouble with your games freezing it is possible that you have corrupted data on the PS3 hard drive. The link below will take you through resetting the drive.
http://www.fixya.com/support/r4853494-fix_playstation_3_corrupted_hard_drive
If you still have trouble it is possible that you are having trouble with the PS3 system its self.
Let me know if you have any more problems or questions
Good luck.
Oct 01, 2010 | Sony Playstation 3 (PS3) Console
Fridge freezing up
Check the fridge sensor. On my Hoover HNMF2805AL80 f/f, first I replaced control module - still freezing.
Have just replaced cheap fridge temperature sensor. Part No. 97061619. Trouble is you have to cut into insulation at back of fridge to replace. I just plugged in sensor & placed inside fridge at back at the bottom - so far so good, only lettuce freezing now, everything else v. cold but not frozen. :)
Jun 02, 2010 | Hotpoint RLA50 Refrigerator
No disk & freezing
possible dirty or defective lens
May 31, 2010 | Oppo Digital OPDV971H DVD Player
Fridge is freezing everything!
There is a flap that directs the air from freezer to fridge. Sometimes this flap can stick Or the actuator that controls the flap can go out. Same with autodefrost timer which seems to give a lot of people trouble. Thermostat is at the top, uncirculated cold air sinks, food in the bottom of the fridge freezes.
Sep 09, 2009 | Frigidaire FRS3R5EMB Side by Side...
Freeze
man lsn. r u using a direct cable to connect to the inter or a Wireless router?? if ur using a router then turn the moden off for 5 mints also the router and then re-connect, but its much better if ur using a direct cable, by the way make sure that the internert username and password r 100% right and there is nothing missing if u still  having the prob. then u should contact ur ADSL provider let them check ur stauts ASAP ok. hope it will work, and by the way about the freezing thing clean ur DVD first then turn the PS3 and then insert the DVD, DONT u EVER leave any DVD inside the PS3 and shut it down DONT DONT DONT ok man
May 18, 2009 | Sony Playstation 3 (PS3) Console
1988 new yorker atc trouble codes
12 Direct battery input to PCM was disconnected within the last 50 key-on cycles 14 MAP sensor voltage too low 15 No vehicle speed sensor signal
Dec 20, 2008 | 1988 Chrysler New Yorker
Refridgerator is freezing food
if you only have one thermostat put it in the middle if you have two put both in the middle,but it sounds like your thermostat is bad that's why it is freezeing the food in the frig.it's not shutting off,let me know-mike
Sep 26, 2008 | Amana ABB1927DE Bottom Freezer...
Xbox 360 entire system freeze
Hi Mattrobi8886, It sounds like your console is heading for a 3 red light error, I know from experience that freezing is not good and probably means there is trouble on the way.
Adding extra cooling to the XBOX or doing an X-Clamp replacement fix works in these situations. Getting the console apart is pretty straight forward and is quite easy, I've done it plenty of times, visit the Tutorials sections here http://360solutions.eamped.com/ for instructions on taking the 360 apart.
xbox-scene.com also have allot of X-Clamp tutorials. I hope this helps in some way, leave me a message on the forum if you need more pointers.
Please rate if at all useful, thanks!
Dec 04, 2007 | Microsoft Xbox 360 Console
Screen trouble
try *2767*3855# this should help, if it does not then take it to a repair center and have them reflash the firmware on the phone.
Nov 18, 2007 | Samsung D840 Cellular Phone
GPS Logo
12 people viewed this question
Top Jensen GPS Experts
Rochell Cruz
Are you a Jensen GPS Expert? Answer questions, earn points and help others
