Question about D-Link DIR-615 Wireless Router
Dlink wireless windows vista
Dlink wireless wont connect to windows vista
    Brigadier General:
  • 10,406 Answers
Connect an Ethernet cable to one of the 'LAN' ports on the router and to the network-port on your computer.
Click Start
Click Run
Type CMD and press ENTER
Type IPCONFIG and press ENTER.
You should get output like:
Ethernet adapter Local Area Connection:
IP Address. . . . . . . . . . . . : 124.268.336.448
Default Gateway . . . . . . . . . : 123.456.789.0
Start Internet Explorer.
Type: http://123.456.789.0
to connect to the web-server "inside" the router.
Run the "wireless network setup wizard" to configure the router
with an SSID and a password.
Save and reboot the router.
Disconnect the Ethernet cable.
Your computer should report "Wireless Networks are available".
Choose your network, and enter the password for the network.
Posted on Nov 18, 2009
I have a dlink dir-615. I have a windows xp desktop which is hardwired to the router. I have 2 windows vista computer on wireless and one apple macbook pro. the apple computer and the desktop works fine....
Use the DHCP function in the router administrator web page There you can assign and reserve the IP,s on each Vista PC,s.
If you need more help come back.Post / thumbs / testimonial are welcome!
Dec 10, 2010 | D-Link DIR-615 Wireless Router
Windows 7 Wireless connection problem
Disable IPv6 from your Laptop & then check ur Wireless Connection...
Also let me know the status...
Nov 12, 2009 | Microsoft Windows Vista Home Premium with...
Dlink dwa 130 wont stay connected
I had a very similar problem with my Netgear, I assume your Netgear is 802.11n standard router and your wifi card is probably integrated which means it only supports b and g standard. The only solution is either to buy a 802.11n compatible wifi card or to kick the speed of the rounter down to b & g compatible more.
Jun 29, 2009 | Computers & Internet
Setup is unable to detect card however windows
You aren't very descriptive. Either way. I'm assuming when you say Setup, you are referring to the driver installation setup. Delete/uninstall the driver. Unplug the adapter. Now, start the setup. When the installation goes along, eventually it'll ask for you to insert the card, thats when you insert it. It should then work, if you finish the setup. If thats not the issue. Heres a possibility. You are running windows Vista, or running Windows Vista 64 bit, or maybe XP 64 bit. Either way, you are likely using a 32 bit driver, on a 64 bit machine. Or vise versa. If not then you could be using a vista driver on an XP machine and the XP machine doesn't know what to do with it. I suggest going to dlinks website. There are 3 versions of this wireless card, and that also could be the issue. The first one they released is here http://support.dlink.com/products/view.asp?productid=DWL-G630 and that only has drivers for XP and 2000. http://support.dlink.com/products/view.asp?productid=DWL-G630_revB rev B. Also only XP and 2000. http://support.dlink.com/products/view.asp?productid=DWL-G630_revC rev C. also again XP and 2000 BUT includes a Vista 32 bit driver. I hope i helped. Not bad for free...
Jun 09, 2009 | D-Link AirPlus DWL-G630 802.11g/b Wireless...
Cannot connect to DLink DIR-655
The part below is all you need to look at, the rest is Ethernet which is your wired connection, ethernet card.
Here is what are causing your problems from what you gave me and basically your computer is not communicating with the router:
1)I don't see any IP address for your laptop so you can't get on the internet if you don't have an IP address, also, I don't see any gateway address. The gateway address is your router address, and that address is given to the router automatically from your Internet Service Provider.
So if your computer cannot see the gateway address then the gateway address (router) cannot give you an IP address to get on the Internet.
Your Wireless card looks ok, that is the physical address and if you were able to do the loopback then its working.
So on your laptop I would begin from the beginning. Go into network connections and delete the DLink connection if it is there. Then Start>control panel>Network connections>click wireless network connection>click change settings of the connection on the left window>click wireless network tab>make sure checkmark"use windows to configure my wireless network settings>click add a new network>TYPE IN THE SSID FOR THE NETWORK>ENTER WEP/WPA KEY>CLICK OK, then close and you should be connected.
You said other computers are able to access the internet thru the DLINK so it all points to your laptop not being configured correctly.
HOWEVER :)...I see alot of "Media disconnected in your list. Make sure all of the lights are working on the front of the router, if not check the cabling or call the ISP sometimes the problem is on their end. Hope this helps, keep me updated.
C:>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : HPdv7
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Wireless LAN adapter Wireless Network Connection:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Atheros AR5009 802.11a/g/n WiFi Adapter
Physical Address. . . . . . . . . : 00-24-2B-12-FD-63
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
May 01, 2009 | D-Link Xtreme N DIR-655 Wireless Router
D-Link DWA-130 running Vista
OK!! I figured it out!! Ok you need to go to the Dlink web site, cursor over to the tech support tab, on the drop down select DOWNLOADS, enter your Dlink wireless adaptor version(you'll need the box for these steps), ok now in the new window click downloads, choose and download the 130 one not the beta version, have a flash usb ready and save all downloaded files to ur usb flash, next insert your usb flash on ur laptop, open my computer select ur removable drive and double click the dlink software, after you do this it should bypass that prompt screen and you'll be able to continue your setup for your Dlink wireless adaptor.........hope it works for you cause it worked for me.....
Aug 30, 2008 | Computers & Internet
Dir-655 router
Yes. Here's a link to the spec sheet:
http://www.dlink.com/products/resource.asp?pid=530&rid=2027&sec=0
What specific problem are you having?
Jan 31, 2008 | D-Link DI 514 Wireless Router (DI-514)
Glb-502t driver of Dlink compatible with vista
The Dlink device came with drivers which works in Windows XP.
I installed vista driver from dlink website, but its of no use, it still doesn't work in Vista.
Well Dlink WORKS BEST in Ubuntu (Linux), without any driver installation. Either USB or LAN.
Use Ubuntu Linux.
Dec 20, 2007 | Microsoft Windows Vista Ultimate Edition
Dwa 142
The latest drivers are Vista compatible, they can be downloaded from:
ftp://ftp.dlink.com/Wireless/dwa142/Drivers
The latest drivers are really good and i'm using it with Vista
Sep 23, 2007 | D-Link RangeBooster N DWA-142 (1010125954)...
D-Link DIR-615 Wireless Router Logo
172 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
