Locked up on one channel ,fitted new working batteries to remote ,nothing ,can not swich off or on with remote
    Scholar:
  • 63 Answers
I would double check batteries and be sure you installed them correctly. Next I would be sure I had not pressed a remote button for control of another device such as cable box, DVD etc. This is a very common problem; press the TV button on your remote and try again. If that does not help then your remote may have failed or the remote receiver on the TV itself may be defective. You could take the remote to the store where you purchased the set, if a possibility, and they could try it with another set.
Posted on Nov 18, 2009
Sansui TV/VCR/DVD combo
This solution is provided by one of our experts premtech
Child Lock
Combos
--Should have original remote. Press and hold the power button for 6 to 10 seconds
Combo Model T25208, V-Chip Forgotten Password
If you forget your password, simultaneously press VOLUME down on the TV/VCR front panel and the 0 number button on the remote for a few seconds. This resets the password and you can enter a new one.
Combo Model 13TVR62, V-Chip Forgotten Password
If you forget your password, press STOP/EJECT on the TV/VCR front panel and MENU on the remote simultaneously. This resets the password, but not the limits you’ve set.
Televisions with Parental Lock Feature
If you forgot your password for this feature, press the following buttons on the remote, one at a time. (Note: You must be in the password entry screen) Press, Mute, Display,Clear and Reset, this unlocks parental controls and you can now re-enter a new password.
OR TRY THIS..
Press and hold Menu on the TV AND volume down on the remote for 3 seconds. Nothing will appear on the screen, and the Parental Controls will unlock, and you can re-enter a new password with the LOCK PARENTAL CONTROLS
CTC169AU
Channels that have been locked can be viewed only when the PARENTAL CTRL function is set to OFF. This can only be done with the remote control-it can not be changed with the buttons on the front of the TV.
Therefore, after you turn on PARENTAL CTRL, you simply hide the remote control so that your children can not watch the locked channels. The locked-out channels will remain unviewable even if the TV is unplugged or the channels are autoprogrammed again. The only way to view locked channels is to use the supplied remote control to set the PARENTAL CTRL function to OFF.
The PARENTAL CTRL and the CHAN CTRL functions work hand-in-hand. The instructions below will first tell you how to turn parental control on or off with the PARENTAL CTRL function and then how to lock desired channels with the CHAN CTRL function.
1. Repeatedly press MENU to select SETUP MENU, and then press + or - to display setup functions. Repeatedly press MENU to select the PARENTAL CTRL function. . When this function is set to ON, PARENTAL CTRL is activated and any channels you locked with the CHAN CTRL function will not be viewable. . When this function is set to OFF, PARENTAL CTRL is deactivated and all channels are viewable.
2. To lock channels, press the MENU button to select the CHAN CTRL function. Select a channel you want to lock by pressing CHANNEL up or down. Then press +. The CHAN CTRL setting will change from NORMAL to LOCKED when that channel is locked. To return the channel to NORMAL, press the - button. Repeat step 2 for each channel you want to lock. If the PARENTAL CTRL function is set to ON while you are locking out channels, each channel will go blank as you lock it. When the PARENTAL CTRL function is set to ON and a channel which has been locked out is tuned, the TV will display the words PARENTAL CONTROL to let your kids know you have locked it.
CTC185's
If the front panel function buttons don't work, (menu, ch up/dn etc.) but the functions work normal with the remote, enter the "Channel" menu with the remote and turn "Parental Control" off.
CTC203's
In the event you have forgotten your password, perform the following procedure:
Press and hold for 3 seconds the TV button on the remote while pressing the menu button on the TV.
This procedure will turn off the parental lock and erase the previous password .
Another Possibility To Try For Various Models: If TV's in the Parental mode and askes for a password that's forgotten, Press menu on the TV, select Parental Lock #4 on menu, then with the remote press Mute, Display, Clear, and Reset buttons in sequence.
TX808 Chassis
If Parental Controls have been set and you don't know the password, do this:
Press and hold the volume down and the channel up buttons at the same time for 5 seconds.
Now you can reset the password to 0000, and using that password you can now access the V-Chip menus.
TV's (Made by Daewoo or possibly Apex, ie. GE model 24GP653)
The factory default pass code of 6688 is also the override code, in case the owner forgets their pass code. If that doesn't work, another place in the owners manual says to push Function and Mute on the remote at the same time. Function is the top right button.
Jun 28, 2008 | Sansui DTV2760 27" TV
I want to know how to swich the tv to wach dvd player? the remote works with the tv but how can i swich to wach a movie....i dont want to set up the remote to the dvd...
Sounds like you need to change the input channel of your TV with your TV remote. Look for an Input or Video Source button. Once you've found it, insert a DVD then cycle through the inputs with that button until you see something on the screen. As always this could be undermined by incorrect connections to and from and the DVD player. Double check these as always!
Jul 18, 2011 | Televison & Video
Sony KV-32FS12. Buttons on the TV don't work, the remote don't work. Now stuck in one channel. Can access Menu with TV button but can't go anywhere. Unplugged from main power source still no go. Tried...
Hello
Your TVs front control buttons are inoperative except menu button. There are microswiches fitted inside the main board of your tv from which shafts ar extented towars the front of the cabin where you press to access the functions. Replace all the micro swiches inside at onetime. It won't cost more. Micro swiches as they have said is mini swiches, which can get damaged easly with high pressure thumb or impact put on it.
Oct 15, 2010 | Sony KV-32FS12 32" TV
ALL OF A SUDDEN MY REMOTE ISN'T WORKING. I CHANGED A CHANNEL AND NOW NOTHING. CHANGED THE BATTERIES AND TRIED TO RESET THE CODE. STILL NOTHING. HAVE A PHILIP MAGNOVOX. ANY IDEAS?
Take off the battery, open the back of your remote, lift the circuit board, clean the green painted part with cotton balls slightly damp with rubbing alcohol as well as the black thingy behind your remote pad, let it dry put it back together, replace with a new battery and try if it works.
Jun 12, 2010 | RCA RCU403 Remote Control
I have a AST 24igb-w aircondioner. The remote was dropped last night. I put the batteries back in the remote and reset the clock. The remote does not sync with the unit. I can not swich the unit on or off....
in the remote there is a sensor.with that sensor the remote gets connected to the unit.but if that sensor is cracked the remote will not get communicated with unit because the sensor is cracked faulty so no signal will be sent.
you can only try opening the remote completely.
some remotes have screws, some have plastic locks and some are dye based they no locks and no screws.
if yours have screws then take a screw driver remove the screw and open the remote.if yours ave plastic locks take a thin strong knife and insert where the locks are seen.the locks are internally fitted so you will have to insert the knife in between the two parts of the remote and move the knife where the knife gets stuck there will be lock.move the knife up/down position lock will be released.there will be 6 to 8 locks.
if there is nothing like locks and screws then also take the knife and separate the remote in two parts.you will see thing line in between the two parts of the remote there you have to place the knife and separate the remote in to two half.after the remote is opened.check out internally.the parts will be slightly moved.lift the moving parts and reset it again properly and check out.if still the same problem the remote needs replacement.you can get replacement remote from local electronics hardware shop dealing in remotes.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Jan 11, 2010 | Fujitsu 24C1 Air Conditioner
Remote doesn't work
Return ur univeral remotes,try this website 1-800-Remotes Factory original to buy a original remote.
Dec 15, 2009 | RCA Universal Remote Control
Vue 2003 saturn
try locking and unlocking the car with the remote, maybe a anti-theft issue?? what do you mean" tries to start?" either the engine turns over or it doesnt. if it turns over, but wont run, thats another story.
Sep 21, 2009 | 2005 Saturn VUE
Unlock Hyundai TV
motimoti 's solution worked. Thanks.
By the way, how do you find the solution ?
Apr 21, 2008 | Televison & Video
Remote problems and now FPA locked
In the worse case:
It is very possible that the remote recieve on the set has gone defective. It is also possible that there is a fault with the processor in the set, and the remote signals are not being responded to.
As for your universal remote, I don't trust them.
Did you try changing the batteries in the remote? Make sure the new ones are actualy in good condition.
Jerry G.
Jan 01, 2008 | RCA 32V420T 32" TV
Televison & Video Logo
47 people viewed this question
Top Televison & Video Experts
Electro Med Services...
