Question about Maytag HAV3460AWW Top Load Washer
I have a Maytag A712 top load washer that filled with water and then stopped working. It will not agitate or anything. Also, how do I get the water to drain?
    Problem Solver:
  • 7 Answers
I drain water from stuck machine by filling an appropriately long piece of garden hose with water and holding thumbs on both ends. then i plunge one end deeply into the tub and have the other end below the first end when i let my thumbs loose. This machine has a water pump that will begin to lose a shiny steel retainer that digs into its housing and stops the belt.
Posted on Mar 20, 2010
I have may tag wash model nu mav5920eww i just hooked it up tried reg wash it filled with water then would not continue to wash went to pause mode
Maytag & Whirlpool washer diagnostic - Fills with water then ...
? 3:03
https://www.youtube.com/watch?v=71zySSScDPE
Jul 11, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your trusty Maytag Washer that has some of the ...washer diagnostic - Fills with water then cycle stops - LAT8014AAE .... Not agitating Maytag 2 belts top load washers - Duration: 26:55. by theapplianceman 23,820 views. 26:55.Washing Machine Keeps Filling With Water and Will Not Agitate ...
Maytag top loading washing machine stopped working & filled with
Dec 02, 2015 | Maytag MAV5920E Top Load Washer
Washer won't do anything but fill.
It is very likely that the motor has burned out. What happens is that the water solenoid allows water to fill to a certain point where a fill sensor stops it. The program then moves on to activate the motor which will agitate the wash. So when power is supplied to the motor, it tries to start, overheats because of a break down of insulation in the windings, and you smell burning. Replace the motor.
Nov 18, 2009 | Maytag Atlantis MAV6260AWW Top Load Washer
Maytag washer, model: LAT8415AAE top loader. Washer fills with water but will not start agitating,spin or drain.
Check lid switch. Most will not run with lid open and the switch may not be pressed down when door is closed
May 17, 2009 | Washing Machines
WASHER FILLED WITH WATER AND STOPPED WORKING COMPLETELY
if you hear a motot running the coupling between the motor and transmission has disinagrated.
Dec 26, 2008 | Maytag MAT12CS Top Load Washer
Washing machine fills, but won't agitate
maytag washer dryer stack unit , model # lse7806ace washer fills with water but won't agitate or do anything else. I had the same problem a year ago and replace the lid switch asssemby and fuse and it worked fine until now. the switch clicks when I open and close the lid and the pink and orange wires show continuity with the lid closed.
Aug 29, 2008 | Maytag LSE7806A Top Load Stacked...
Maytag MAV6257AWW Washer
Could you describe the noise you are hearing. This will help to determine what to look for.
Jan 13, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Maytag wahser not agitating
Either your transmission is bad which might carry a 5 year warranty or your lid switch needs replacement
Nov 14, 2007 | Maytag Atlantis MAV9750A Top Load Washer
Maytag washer
Check to make sure your drain hose has a loop at least as high as washer top.  If the drain hose is not looped higher than tub water will continue to drain and it won't stop filling.  If it doesn'y reach the correct fill level it won't agitate.
Oct 29, 2007 | Maytag PAV2300 Top Load Washer
Maytag HAV3460AWW Top Load Washer Logo
160 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
