Question about Poulan Pro Chain Saw 46cc 20"
Need chain adjustment wheel part # for poulan pro model pp4620apx chsain saw
    President:
  • 2,220 Answers
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
I think this is the what you seek:
http://www.ordertree.com/modelinfo/PWE/PP4620AVX-Gas-Saw/75.PP4620AVX-Gas-Saw.1.59.1.html
The "Handle, Chassis, and Bar Assembly" detail
Items 63 through 69 are parts, I think item 70 is a complete assembly ($22.78 without a kiss).
Your saw without tooless adjustment.
http://www.ordertree.com/modelinfo/PWE/PP4620AVHD-Gas-Saw/75.PP4620AVHD-Gas-Saw.1.59.1.html
Item 64 (complete assembly) $2.53.
If my saw I'd ask if it can be modified!!!
http://www.ordertree.com/cms/parts-lookup-help/73.html
I suspect a vert simple modification. HTH
Lou
Posted on Nov 19, 2009
  • 132 Answers
All the parts and there numbers are at this sight, you can even order it from them if you want.
http://www.superxpower.com/pages/parts/viewbybrand/11/Poulan.aspx
Posted on Nov 18, 2009
How to tune the carb on 1950le poulan chain saw
H I ONE quarter turn L one turn then adjust the idle.
Oct 10, 2014 | Oregon Poulan/Poulan Pro 12" Chain Saw...
Adjust idle up on poulan pro 42 cc chain saw
Adjust the low side out another quarter turn first before messing with the idle screw.
Sep 15, 2014 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Where can I find a thumbwheel adjustment foe a poulan chainsaw?
You can find just about any item needed to fix you chainsaw on www.ereplacementparts.com
I am not sure if you have the Poulan 260 pro, but I have attached the link from e replacement parts for that saw.
http://www.ereplacementparts.com/poulan-260-pro-chainsaw-parts-c-16962_17133_202439.html
Good luck in fixing your saw.
Aug 13, 2014 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
How to tighten chain on 4620avx poulan pro
First, RTFM- read the manual. Lost it? No problem, download it from Poulan PRO website page for PP4620avx. Pick a version you like, save and read it. Google is your friend.
Chain Adjustment Part cut and pasted as follows:
Adjusting the tension:
Chain tension is very important. Chain stretches during use. This is especially true during the first few times you use your saw. Always check chain tension each time you use and refuel your saw.
1. Lift lever on bar knob and turn counter-clockwise 1.5-2 turns to loosen clutch cover.
2. Turn adjusting wheel (downward direction) to tension chain until chain solidly contacts bottom of guide bar rail. Lift tip of guide bar while adjusting tension. Tighten chain Adjusting Wheel
3. Use a screwdriver to move chain around guide bar to ensure all links are in bar groove.
4. While lifting tip of guide bar, tighten bar knob securely (clockwise).
Hand tighten only.
Be careful not to destroy the adjustment mechanism. When it breaks, go for a clutch cover with the simple adjuster that needs a "scrench". Longer term, learn how to search this info. Saves time. Now you can work on sharpening chains- very important.
Manual page:
http://www.poulanpro.com/ddoc/PPOO/PPOO2006_USen/PPOO2006_USen_PP4620AVX_952802146.pdf
Jul 21, 2014 | Poulan Pro Chain Saw 46cc 20"
How do i adjust the module-ignition on poulan pro chain saw model #PP4218AVWhat's your problem?
are you talking about the magneto to the flywheel gap i just use a piece of paper between the two and tighten it
Apr 07, 2012 | Poulan Pro Chain Saw 46cc 20"
JUST BOUGHT A 20'' POULAN PRO TENSION A CHAIN
the adjustment screw near the end of the bar( next to the engine) needs to be turned in to tighten the chain just don't tighten it to much
Apr 04, 2010 | Poulan Pro Chain Saw 46cc 20"
Poulan prochain saw I need the wheel for the chain tensioner
Following is a link to a Poulan Parts Dealer that has the adjusting wheel. I also included a pdf of break down parts list for your model. Please rate the answer on its value of help. Good Luck have a great weekend.
Order Part
Parts List PDF
I need an Idle Speed Adjustment Screw for a Poulan ProPP4218 Chain Saw.
Ordertree.com (Poulan authorized parts outlet)
http://www.ordertree.com/cms/contact-us/9790.html
Telephone - For Handheld or Wheeled Products contact us at 1-877-500-7499
I looked at "Gas Chain Saw PP4218 Types 1 & 2" IPLs. there are no carburetor illustrations. I suggest you contact them by phone. Please have your saw and a supply of common hand tools within easy reach before calling. HTH
Lou
There are often multiple carburetor manufacturer's used on the same model. They can easily help you determine what is on your saw.
Dec 14, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I have a Poulan Pro PP3516AVX chain saw. I used it
Their not the best saws but make sure the nuts holding the bar and cover on are tight after adjusting chain sometimes improper cutting will continue to kick chain off bar.
Mar 15, 2009 | Poulan Pro Chain Saw 46cc 20"
Poulan pro with tooless chain tightening - chain will not stay on
i have a 4620 poulan that had the same problem. use it for 10 minutes, spend 15 minutes reinstalling the chain. i sent poulan an email threatening to sue them and they decided to send me the parts to change it over to the old style for free. try poulan.com
Mar 04, 2009 | Poulan Pro Chain Saw 46cc 20"
Poulan Pro Chain Saw 46cc 20" Logo
196 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
