Question about KitchenAid Dryers
The dryer gets hot when initially started but shortly after gets cold. I cleaned the lint screen, removed the exhaust hose an blew the debris from it, cleaned the lint screen housing and the inside of the dryer where the lint is filtered out to the screen.
    Guru:
  • 1,738 Answers
It is your heating elements.
Posted on Nov 19, 2009
My dryer will not run. Code C5
Clean lint screen. Then exhaust hose maybe clogged or pinched.
The drum is getting hot could be just took many items in dryer
Jul 17, 2015 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Why does dryer start run a little beep 3 times cut off
Really you need to provide your model number. but that said... the number one cause of a dryer shutting down after a short warm-up is a blocked exhaust outlet. Dryers have a sensor that checks the exhaust temperature... if its not moving the hot air out side than it over heats and trips the sensor which will shut off the dryer for safety (no fires please!!). So check your exhaust outlet outside for lint blockage... check your exhaust hose/pipe for kinks where lint can build up and of course always check the lint screen for blockage.
Aug 05, 2014 | Kenmore Dryers
Dryer was running put next load in will not start has power to dyer
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Feb 21, 2011 | Dryers
Maytag Neptune Gas Dryer MDG 5500Aww Dryer runs and heats when cold, then after about 5 minutes the flame cuts off, after a few minutews, the ingiter glows red, but the flame does not come on again unless...
Hi!!
I seems like you have a plugged up filter and/or an obstruccion in the exhaust hose/pipe.
Remove and clean lint filter, also remove exhaust hose/pipe from back of dryer and remove any lint accumulated. Check also the exhaust hole in the dryer.
Don't forget to rate this post. Good Luck!!
Jul 06, 2010 | Dryers
Entire vent system cleaned (was really bad). Purchased thermal fuse and thermostat kit la-1053 . Motor spinning fine as well as the air wheel is tight. Removed tumbler unit, checked tension pulley, motor,...
Did you clean the exhaust from the wall behind your dryer to the outside. This is more important than the dryer exhaust system itself. If not get behind dryer and remove exhaust to the wall and using a leaf blower,(electric) put it inside house vent then push dryer back to hold in place go outside and watch to see what all blows out. Good luck.
Jan 29, 2010 | Dryers
Thin twin washer dryer that smells like burning electrical. The dryer was very hot after the cycle. What could be causing this?
That sounds like the exhaust air is restricted somewhere. Take the lint filter out and wash it in hot water and detergent to remove the fabric softener deposits. Remove the external vent hose and clean the lint from it and the outside shutter assembly. Vacuum below the lint filter and from the exhaust tube that the hose attaches to. Try to get inside the door cavity with the vacuum (watch out for sharp metal edges). Run the machine for a short time with no clothes in it, without the lint filter, and with the hose disconnected to blow out any lint previously missed. Make sure that there is a good volume of air moving. Hope this helps!
Jan 12, 2010 | Dryers
Dryer will not dry clothes
Hello. Unplug your dryer. Remove your vent duct hose and, holding it like a "U", take it outside and clean it out. While the duct is removed, inspect the dryer exhaust (where it goes into the duct) and the other end (where it passes through the wall). Clean and remove any debris that you find. Remove the lint filter and check for debris in this cavity as well. If you find and clear any debris, this may get you drying better.
There are other things that might be at issue, but this is the most common and most easily repairable. Please repost after giving this a whirl.....Operators are standing by!!!!
Regards, --W/D--
Jul 17, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
SLOW TO DRY
HI, i recommend making sure that this dryer has a clear exhaust duct and hose. place your hand on the outside exhaust hose and check for a good flow. if the flow is low, you will have some sort of clog in the exhaust system and you will need to clear this blockage. if the exhaust duct and hose is clear of debris, you will the need to check the lint screen for debris as well. make sure you Clean this regularly after every cycle.
I also recommend checking the dryness sensor as well.
May 19, 2009 | Whirlpool LER5636P Electric Dryer
The dryer does not stay hot
You probably have a restriction in the exhaust somewhere. Check vent to outside , if that is okay remove hose from back of the machine and look for lint buildup in hose and machine. More than likely the problem is in the duct in the front panel where the lint screen goes. To check and clean this you will have to remove the front panel.
Apr 04, 2009 | Maytag Atlantis MDG8400AW Gas Dryer
I want to know how to remove the lint trap (not just the screen but the entire assembly) from a Maytag Performa PYET344AZW front loading electric dryer. The lint screen will not even properly slide back...
Besides drying clothes, dryers also remove lint. This fine, fuzzy material can cause trouble because it blocks dryer lint traps, clogs vents, and fills blowers. Lint can also gather around and in the tracks of the drum rollers, or in and under the pulleys and the drive belt. The result is poor clothes drying or -- sometimes -- no drying. To avoid lint problems, clean out the dryer's lint trap system every time you use the dryer.
To clean the lint screen, remove it from the unit. The screen may be located near or under the door sill, or in the top of the dryer near the control panel. It can usually be removed by pulling it up and out of its housing. Remove the accumulated lint to clear the screen; then replace the screen.
The exhaust vent also collects lint. Vent maintenance involves cleaning the lint from a screen in the dryer's vent exhaust collar and/or at the end of the exhaust vent where it sticks out through a basement window or through an exterior wall. To clean the screen, remove the clamp that holds the vent to the collar, or back out the screws that hold the vent to the collar, or pull the vent straight off an extended collar. Clean the screen thoroughly and replace it in the vent assembly.
To clean the vent itself, use a vent-cleaning brush (available at hardware stores) to pull out any lint deposits. Also check the vent run to make sure that the vent piping or tubing isn't loose at the joints, or -- in the case of flexible plastic venting -- isn't sagging between hanging brackets. Breaks or sags cause undue strain on the dryer's blower system, and can cause drying problems. If the vent pipe or tubing has become clogged with lint, remove the lint by pushing a garden hose or a drain-and-trap auger through the vent to a convenient joint. Disassemble the joint to remove the debris. With this procedure, it isn't necessary to disassemble the entire vent to find the blockage.You can head off problems before they become too serious by providing routine maintenance for your dryer's door gasket, thermostat, timer, and other frequently used parts. Let's discuss how to service these important components in the next section.
how-to-repair-a-dryer-1.jpgTHANK U.. RATE IT...
Sep 11, 2008 | Dryers
Open Questions:
Dryers Logo
67 people viewed this question
Top KitchenAid Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a KitchenAid Dryer Expert? Answer questions, earn points and help others
