I have F5D7230-4 router. Modem downstairs connected to DSL. Computer upstairs needs a wireless card to work This is a ''G'' router, but it only picks up signal upstairs with a ''B'' card which I stole from my laptop. What can I do to receive signal upstairs reverting tho the ''G'' Linksys card?
    Brigadier General:
  • 10,406 Answers
The Belkin F5D7230-4 router should offer "Wireless G" connections,
unless you have used its built-in web-interface to only allow "Wireless B" connections.
So, if your "upstairs" computer, with a "Wireless B" adapter, connects, it will connect only at the slower "Wireless B" speed.
If you want "Wireless G" speed, you will need to purchase a "Wireless G" adapter.
Posted on Nov 20, 2009
How to connect a linksys e1500 router to a repeater?
Run an Ethernet cable from one of the LAN ports on the downstairs router to connect to the WAN port on the upstairs router. Result: 100% connection.
Jul 08, 2012 | Linksys E1500 Wireless-N Router with...
My telephone connector is downstairs, and I want to have my PC upstairs - but I do not want to run wires around the house. Is there any way I can connect my computer wirelessly. i.e router downstairs,...
Yes, a wireless router should work fine.
You'll need a wireless-adapter (either internal PCI add-in card, or external USB stick) in your computer, if it does not have built-in wireless capability.
May 22, 2011 | Computers & Internet
I am running qwest DSL through a Linksys wrt160N that is brand new. it will work next to the router, but not upstairs or in the basement which is less than 15 meters. The upstairs bedroom is directly above...
If you have concrete floor slabs the the wireless signal from the Linksys will have a difficult time penetrating the floor slabs.
The wireless card in the computers will show a low signal strength.
Try altering the Linksys aerial to a horizontal position and also positioning the Linksys to another location.
You could be getting interference form other wireless sources, check the wireless channels of other wireless router/access points in your area. If they are broadcasting on the same channel then configure your Linksys to broadcast on an unused channel or one that has the weakest signal strength.
If none of these methods work then I would suggest you run network cables from the Linksys to upstairs and downstairs and not use the wireless connection.
If network cabling option is not an option then consider extending the wireless range with wireless repeater access points.
Nov 07, 2009 | Linksys WRT160N Wireless Router
Trying to connect a wired network wirelessly to a router
No. You'll need to run a "cross-over" Ethernet cable from one of the "LAN" ports on the "downstairs" router, connecting to the "WAN" port on another router that you will need to buy, and place "upstairs", and connect the 4 devices to the 4 "LAN" ports.
Or, run a long "straight-through" Ethernet cable from your DSL-modem (or cable-modem) that is "downstairs", and move your wireless router "upstairs", and connect the 4 devices to the router's "LAN" ports.
Your laptop "downstairs" should still be able to connect (wirelessly) to the wireless-router that is "upstairs".
Sep 16, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
I lost my dlink d1514 installation cd, have dsl set up
You can download the driver for your adapter from D-Link's support page here.
There are 5 different versions, so make sure you get the correct one.
You can then either burn that file on a CD or copy it on a USB stick - it is too big for a floppy though - and install it on your downstairs computer.
Of course you can carry the computer upstairs and connect it to the router via an Ethernet cable, but that would be my last resort.
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Aug 16, 2009 | D-Link AirPlus G DWL-G122 802.11g/b...
Home Network Problem with Netgear MR814 and Netgear FS105
Is your ReplayTV and Xbox configured to use DHCP? If not, you may need to configure static IP addresses for each of them.
Feb 17, 2009 | NetGear ProSafe FS105 5-Port Ethernet...
Problem connecting to my network
What I would do is replace the wireless router with a 4 or 5 port switch to control computers (devices) downstairs. Or, if you need wireless access, purchase only an access point to cover downstairs.
This way the wire from upstairs goes directly into the access point and you have wireless access downstairs.
And yet another way would be to purchase Airlink 101 PowerEthernet boxes ($54.99 each) and use those to connect an access point anywhere in your home that has an outlet.
Nov 19, 2008 | Linksys Wireless-G WUSB54G 802.11g/b
Cable modem
Go and buy a router. Plug your existing modem into the WAN port and your computers into the LAN port. You could even get a wireless router and connect your upstairs computer wireless. Be sure to lock down your SSID (Wireless Access Point Broadcast Name) so your neighbors or people driving by don't get on and do bad things on your network.
May 31, 2008 | RCA Cable Modem DCM315R (11603540)
Wireless adapter ......need something compatible with a siemens router
you probably need another router such as linksys, netgear, belkin.. etc.
Nov 10, 2007 | Siemens SpeedStream Modem (4100) (SS4100)
Computers & Internet Logo
97 people viewed this question
David Payne
David Payne
