Question about Whirlpool Duet GHW9150P Front Load Washer
Have error code f 02 showing up on my Duet fronload washer, during rinse and spin cycle
  • 126 Answers
F/02
DURéE EXCESSIVE DE LA VIDANGE
If the drain time exceeds eight minutes, the water valves are turned off
and “F/02” is flashed. Press PAUSE/CANCEL two times to clear the
display.
NOTE: After four minutes the “Sud” error will be displayed, then four
minutes later the “F/02” error code will be displayed.
Si la durée de l’opération de vidange est de plus de huit minutes, le système commande
la fermeture des électrovannes et l’affichage du code “F/02” clignotant. Appuyer deux
fois sur la touche PAUSE/CANCEL pour commander l’effacement.
NOTE : Après quatre minutes le code d’erreur “Sud” sera affiché; quatre minutes plus
tard le code “F/02” sera affiché.
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and
make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Posted on Nov 19, 2009
Whirlpool duet washer error code f-02
Error F-02 is a slow drain problem. Remove lower front panel. You will see a circular door. Be prepared for a lot of water and junk, maybe keep some old towels ready. Open, clean out, check pump which comes right behind it - see that blades rotate freely; refit carefully. You are done, for the next six months or so, depending on usage.
Click if helped
Apr 14, 2013 | Whirlpool Washing Machines
During a normal wash cycle, the error code FH occurs. The owners manual says inlet problem. All water pressure is good and inlet screens are clear. Drain function appears to work well. Repair guy came...
If the flow meter does not register 10 and 1/2 gallons of water in 8 minutes the FH code appears.
Could be a bad flow meter, sensor, wiring harness is loose or a bad CCU Central Control Unit.
At the RINSE cycle if water enters the machine you must time the water fill for 8 minutes or less.
If water does not enter the machine suspect the CCU as bad.
Jan 06, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Code F 35 i cant find my manual
christydubar --
Whirlpool Duet GHW91000 Technical Service Manual does list F35 error code. Try running the diagnostic test below and then write back with condition indication code. -- SWT
DIAGNOSTIC TEST
The control must be in the OFF state before pressing the touch-pad sequence to start the test.
Starting the test mode
Close the door.
Press the Control On button.
Select the DRAIN/SPIN cycle.
Select NO SPIN by pressing the SPIN SELECT button, as needed.
Push Prewash Option button four (4) times within five (5) seconds. C:00 will show in the display.
NOTE: If Model does not have PREWASH Mode as an option, press RINSE/HOLD.
If the Starting procedure fails, push PAUSE/CANCEL button. Then repeat the starting sequence.
Test Program Control during Execution
To advance to the next step of the test procedure, push Prewash Option button two (2) times.
Indications
C:00
C:01
C:02
C:03
C:04
C:05
C:06
C:07
C:08
Aug 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How do I fix my washer that only says 'sud' constantly and won't work at all? Whenever I try to start a cycle nothing happens. Whenever I push a button nothing happens. Please Help.
http://whirlpool.custhelp.com/app/answers/detail/a_id/2948
Hi please go to this above link, it is all explained at length what is going on and what to do.
This error code indicates that excessive detergent suds occurred during the cycle.
If a "Sud" or "Sd" error code is displayed, or if you can see excessive suds in the window:
There are too many suds in the washing machine. The washer will not be able to spin out water with the excess suds. When "Sud" or "Sd" is displayed, the washer automatically extends the rinse time to remove the excess suds. During this time, the washer pauses the tumbling and adds water for additional rinsing. This pause allows the bubbles in the suds to break. This pause and rinsing are necessary and may occur several times to eliminate the suds. See the animation below for more information.
  • If you see "Sud" or "Sd" with the Rinse status light on, the washer is in the process of removing suds. Let the cycle continue.
  • If you see "Sud" or "Sd" and the Cycle Complete light is on, the washer detected too many suds during the cycle and your load may not be fully rinsed or water may not be fully removed. You may want to select a Rinse/Spin cycle for further rinsing.
Aug 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet washer, during the wash cycle, get H F error code
Hi
Thanks for using FixYa. Error code F/H means no water was detected entering machine or Pressure switch trip not detected. If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed. It can also happen if the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash. You’ll need to Press PAUSE/CANCEL twice to clear the display. Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jul 31, 2010 | Whirlpool Washing Machines
Whirlpool duet washergets a code 2 when it gets to spin cycle.wont rinse and spin
If the drain time exceeds eight minutes, the water valves are turned off and “F/02” is flashed. Press PAUSE/CANCEL two times to clear the display. NOTE: After four minutes the “Sud” error will be displayed, then four minutes later the “F/02” error code will be displayed.
1. Check the drain hose and make sure it is not plugged or kinked. 2. Unplug washer or disconnect power. 3. Check the electrical connections at the pump and make sure the pump is running. 4. Check the drain pump filter for foreign objects. 5. Plug in washer or reconnect power. 6. If the above does not correct the problem, go to step 7. 7. Unplug washer or disconnect power. 8. Replace the pump.
Apr 24, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Error code OF 2 When this error code appears it happens during the spin cycle. I manually switch to the Drain/Spin cycle and change the spin speed to medium and press start. This fixes the problem each...
It sounds like you may have a motor control board issue. It acts like the motors brain and tells it what to do and when. part number 8182706. Also the closet error code i could find is a f/02 which means long drain, which could indicate a bad pump or draining cycle, alos knows as the spin cycle This should definetly be diagnosed by a technician. hope this helps
Thanks
Mar 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet. Strange noise and F 02 error code
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
Feb 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My Duet washer doesn't run through the entire spin cycle on heavy duty setting. Clothes come out of washer, naturally,WET!!!!!!!!!!!!!! Seems to spin out better on the normal cycle. spin cycle dosent...
displayed.
Possible Causes / Procedure
or kinked.
Jan 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
321 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
