Question about Kenmore Refrigerators
Ice maker not producing ice. Changed the water solenoid valve and the ice maker. still no ice! what is the problem here. how can i remedy this.
    President:
  • 1,218 Answers
Good Day,
Obvious but,
Shut water off to house at the meter. Remove supply line to water valve. Place end in a bucket, have someone turn on main valve for a 15 second count. Should have a hard steady supply from the line into the bucket.
If no joy, and this is common,
Remove Ice maker and see if ice has built up in supply tube from outside back of machine into the rear of the ice maker.
If iced, defrost, but caution. Heat guns, hair dryers ect. can do more harm than good. Go slow.
I do not recommend heat because of all the plastic and vinyl. Just shutting down the machine by unplugging it, and air drying.
P.S. I've installed brand new ice makers and valves that didn't work out of the box.
Posted on Nov 18, 2009
My ice maker doesn't produce ice reliably.
Do you have a filter in the refrig. It may be clodded
Feb 08, 2015 | Refrigerators
My ice in ice maker melted then frozen again..ice maker not making ice. how do i remove the ice bulid-up in the tray and how do i reset the ice maker to produce ice?
First, clean out ice in ice bin by removing bin and rinsing water over it to melt ice. The remelting and freezing of your ice is probably not to refreezing but probably do to your water solenoid valve not completely shutting after the fill cycle and spilling over into bin and then freezing. Take your model number to searspartsdirect.com and you should find your solenoid water valve on the water circuit diagram.
Sep 28, 2014 | Maytag Refrigerators
Ice Maker Not Producing Ice - No Power To Water Control Solenoid
Yes, most likely a defective ice maker, since we know the valve is passing water, once energized.
Dec 31, 2017 | Whirlpool Refrigerators
Ice maker has stopped making ice. Infa-red light on inside doesn't seem to be working
One of the causes of ice maker not producing ice is a bad solenoid valve allowing water to pass by and causing the water line to freeze inside the freezer. In other words, if the valve is not holding very well, it will allow water to pass in the line that supplies water to the ice maker. A small drip will ensue and slowly freeze in the line and eventually turn into an ice plug that will prevent water from filling the ice tray. Thawing out the freezer will not solve the problem, you will have to replace the solenoid valve.
P.S.Test the solenoid valve coil and disconnect the line from the valve to verify that it is not allowing water to pass when not energized. Test the infra red module according the manufacturer's instructions if you have them at hand. If the solenoid valve is good and the infrared sensor system is bad , replace it (Infrared system) . The ice maker should be the last part to consider for replacement at this time.
May 06, 2011 | Refrigerators
The ice maker does not produce ice. The arm moves up by itself after I move it down. The filtered water spigot works, so I assume the ice maker is getting water. How can I remove the ice maker from...
Water valve has 2 solenoid so solenoid for water dispenser could be working and one for ice maker may not be. Visibly inspect ice maker to see if water is in it.
Nov 11, 2017 | Jenn-Air JFC2089HP Bottom Freezer French...
GE Profile TFT25 PR. Ice maker quit producing
Had the same problem. Replace the water filter and is should begin making ice again.
Mar 05, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ice maker been working fine, just stopped?
If no ice is being made at all it is probably one of three problems. The ice maker itself needs replacing. The water inlet valve needs replacing. Or the freezer is not 10 degrees or less. You will need to test the water valve solenoids. If you have water in the door then there will be two solenoids. One for the ice maker water and one for the water in the door. They are both mounted on the same assembly. The easiest way for you to test is with a meter. You want to check for continuity on the solenoid for the ice maker. If no continuity, it is bad. If you have both water in the door and ice maker and no meter you can swap the two quick disconnects on the two solenoids and then see if you still get water from the door by now using the other solenoid. If you do not, then you know that, that solenoid is bad. If the soloind is good then you probably have a bad ice maker not calling the ice maker fill valve to allow water.
Jan 10, 2009 | Maytag MZD2766GES Side by Side...
I just changed the water filter and in my fridge and now my ice maker had no water flowing to it.
The ice maker has a problem The ice maker is a separate appliance within the freezer section. Please see the How things Work section of our website to learn about the normal functioning of ice makers. Some common problems with ice makers are:
The ice maker has completely stopped producing ice
The ice maker is producing ice poorly
The ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Jan 06, 2009 | Refrigerators
Refrigerators Logo
82 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
