Question about Cuisinart Grind and Brew 10 Cup Coffee Maker
Cuisinart Grind & Brew not using all the water in the reservoir
My Cuisinart Grind & Brew is not using all the water I fill in the water reservoir. It is only making 4 to 5 cups of coffee and there is water left in the water reservoir. How do I fix this?
  • 10 more comments
  • Billie Caveny Jan 22, 2008
    Same problem - only sending two cups (at the most) through. Then stops. Have used the vinegar clean technique, still no luck. It turns itself off, starts beeping that it is finished.
  • Jylan7 Feb 19, 2008
    I have the same problem. The water is still in the reservoir and it is not done brewing, but claims it is by shutting off. I love this coffee maker, but this new problem is driving me insane!
  • filhashope Mar 24, 2008
    We fill the reservoir to 10 cups and it only brews 2-4 cups (even though the 1-4 cup program is off). This has happended repeatedly even though we have cleaned it really good, repleaced the water filter, etc. Any clues? It's about 1 year old.
  • Anonymous Aug 27, 2008
    I have the same issue. Any answers??
  • Anonymous Aug 31, 2008
    Same Problem....I am sending it back....hopefully it will come back right.
  • wwh18940 Sep 02, 2008
    We had the coffee maker over a year when this problem first occurred, and it went away after replacing the filter. Now even a filter replacement doesn't solve it. Has anyone tried running vinegar through the system to clean it out? Does Cuisinart have any advice?
  • Anonymous Dec 30, 2008
    mine is new and will not brew
  • Anonymous Jan 10, 2009
    It would be nice if Cuisinart would own up to this problem and fix it.  In the meantime we've sort of gotten used to it, by doing it twice every morning: the first to grind and brew, and when that's (prematurely) done, we do it again with the "1-4 Cup" and "Grind Off" settings on.  Somewhat of a bother, but it gets the job done.
  • catpav Feb 08, 2009
    We have ot hit 1-4 cup 3 or 4 times to get the coffee and we did just add a new filter
  • Anonymous Feb 08, 2009
    I have had two Cuisinart coffee makers with the problem of not brewing all the way through. Cuisinart has a design glitch that should be addressed.
  • barryend Feb 13, 2009
    Me too. Unplugging it over night helps. Mine is 4 years old. I have had 3 Cuisinart Grind & brew machines. They all get flaky after a while. Micro-processor locks up I venture. I emailed Customer service. Maybe a separate grinder and regular coffee maker is my next move.
  • Anonymous Mar 15, 2014
    when press brew water not being pumped from reservoir into the machine for heating, Makes a grinding noise
I was having problems like this and then I read on a different string on this website that people have had success by flushing the system numerous times (sometimes up to six times) with vinegar. I took out the charcoal filter and flushed once with vinegar but only saw a small amount of improvement. I was out of vinegar so I used Lemishine mixed with water and it went from making one cup to making a full pot with one flush.
Posted on Jan 08, 2009
  • Suzanne Gallic
    Suzanne Gallic Mar 23, 2017
    I used a coffee cleaning solution ( Mr.coffee , I think) then I ran a 4 cup vinegar/2 cup water solution through, then two water cycles and it cleared up - we'll see how long it lasts, but I'm glad it seems to have cleared up!
Same problem . Sent my first machine back (less than 1 year old, you pay shipping and handling both ends) and now after 4 months, same issue. Not sure what to do.
Posted on Feb 17, 2008
Yep, push the 1-4 button, works just fine then
Posted on Mar 31, 2008
We have the same problem. the only fix we've found is if you want to brew a full pot, put in appropriate amount of water and beans but push the 1-4 cup setting and if you want 1-4 cups, use as if grinding a full pot.
Posted on Feb 06, 2008
My coffe pot does not brew at all. I plug it in and everything works except it does not bre the coffee. do you know where i can send it to be repaired
Posted on Sep 06, 2008
Doesn't always brew all the water, stops early
All coffee makers do this over time from calcium, lime, and mineral deposits building up inside the tubes and heating coil. Fill the reservoir with a 50/50 mixture of water and white vinegar and run a normal brew cycle, turning it off and on if necessary to completely empty the reservoir. Repeat this 2 or 3 times with fresh mixture of vinegar and water until it brews the reservoir empty without the need to cycle the power. Follow this procedure with plain water 2 or 3 times to clean the vinegar out. This should get it working like new again. It's best to use distilled water for brewing coffee as distilled water does not have the minerals that regular tap water has and therefore will not clog up the machine.
Mar 02, 2014 | Cuisinart Grind and Brew 10 Cup Coffee...
My 12 Cup grind and brew coffee maker needs a good cleaning. How do I do it?
To clean the inside of the coffee maker, fill the reservoir with water as you would to prepare coffee, except add 2 tablespoons of vinegar to the reservoir. Place a clean filter in the basket and run the solution through. When it is complete turn off the unit and let it cool for 2 minutes and then pour the hot solution back into the reservoir for a second run, you can reuse the filter that you placed in it the first time. After it is finished this second time, turn off the unit for 2 minutes and pour the used solution down they kitchen sink. Allow the carafe to cool for a couple of minutes and fill with cold water and run it through as you did the solution, but put a clean filter in this time. Repeat this one more time to remove the vinegar solution and discard the used filters. Once the carafe is cooled fill it about 1/3 full of water, add several ice cubes and 1 tablespoon of baking soda swirl this around in the carafe for a minute or so. Rinse the carafe and run it and the basket through a cycle in the dishwasher or wash by hand with warm soapy water. Rinse thoroughly and you're done. Good luck.
Aug 28, 2013 | Cuisinart Grind and Brew 10 Cup Coffee...
This coffee maker (10 c maker with grinder) beeps it's done every few minutes with water left. we have to brew about 5 times for a full pot, what gives?
Presume this is the Grind & Brew Thermal™ 10-Cup Automatic Coffeemaker, Model # DGB-600BCC
An instruction booklet is available here: http://www.cuisinart.ca/pdf/ibs/en/DGB-600BCC_en.pdf
Review the sections beginning on page 11 of the pdf on Turning Off the Grind Function (if not using the grind feature) and Making Coffee.
Make sure you are turning off the grind function if using preground coffee and that the reservoir lid is securely closed.
Check the Cups Setting button; is sounds like the 1-4 feature may be turned on.
Jan 30, 2011 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart Grind and Brew will not emply all the water
The two most common reasons for overflow or underflow have to do with the carafe lid and the filter basket - they key to smooth flow with this coffee maker is making sure the filter basket and carafe lid are making the proper contact with each other so that the center knob on the carafe lid pushes slightly up on the filter basket spring. Make sure the carafe lid is completely closed. Make sure the filter basket is pushed all the way down. Make sure you are not using the gold tone filter and a paper filter at the same time. For some reason, I get better results when the handle of the carafe is resting against the right side wall. If everything is in place, I would suspect a problem with either the filter basket being clogged or some problem with the carafe lid - call Cuisinart as they should be able to order these parts for you.
Aug 18, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
I have a cuisinart Grind and Brew with a glass carafe - not pictured above. The self clean button keeps lighting up and I don't know how to run the clean cycle.
Fill the water reservoir with 2 cups distilled white vinegar and 2 cups water - then press the self-clean button. If the water doesn't start going through after a minute or two, just turn the machine on like you were brewing coffee. After the vinegar/water soultion has gone through the machine, brew one cycle of plain water to flush out the vinegar. If the self-clean light stays on, just unplug the machine for longer than 20 minutes, and the light should not come back on when you replug the machine. Good luck!
-Tha Mp3 Doctor
Feb 26, 2009 | Cuisinart Grind and Brew, 10 cup, black
Cuisinart grind and brew--water does not come down
If the water is not coming out of the filter basket, and is instead leaking over the edges, then replace the brew basket.
If there is no water at all, call Cuisinart - those coffee makers have a 3-year warranty.
Feb 25, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart Grind & Brew DGB-600 fills up water in goldtone filter;
Some fine-grain coffees are too fine for the Gold Tone Filter. If this is the case, remove the Gold tone Filter and use paper filters only. You may have to wash excess grinds out of the black filter basket, since there may be a few stuck in there now - don't take the filter basket apart - just rinse it out with water.
Also, don't use a paper filter and the gold tone filter at the same time.
-Tha Mp3 Doctor (also loves Cuisinart)
Feb 20, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
This happens when the machine needs cleaned. Fill coffee maker with white vineger instead of water. Turn grind off, make sure empty pot is in place. Brew a pot of hot vineger. Repeat. Brew a pot of hot water. Repeat. This process removes mineral buildups inside machine. If you have access to filtered water, start using that to brew your coffee. I do and probably do this process 1 per 6 weeks.
Oct 07, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
What is the best method to clean the Cuisinart Grind and Brew coffee maker? And how often?
Get descaling solution at any drug store and follow the manual on the bottle. When you do this once a month that should keep your machine in top form
Aug 17, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart Grind and Brew 10 Cup Coffee Maker Logo
4,082 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
