Question about Kidde Nighthawk Combo Gas/co Detector
Error code with a beeping-- reading 172 flashes
Error code with a beeper reading 172 flashes is this an error a or a real problem
    Problem Solver:
  • 5 Answers
Call Kidde during business hours at the following number. I took the next paragraph off their website.
"The next time your carbon monoxide alarm has ERR on the display, push and hold the Peak Level button.You will see an E and an O followed by a number.Contact our hotline at 1-800-880-6788 and provide us the error code, along with the model number, assembly number and date of manufacture from the back of your unit.If your unit is under warranty, a replacement will be mailed to you."
Posted on Dec 06, 2009
My toaster oven started beeping and showed a flashing error message. Anyone have any clue what may be wrong?
I suspect that the Logic Control Board is shot. If the unit is 1 year old or less try:
In the U.S.A., warranty is offered by Sunbeam Products, Inc., located in Boca Raton,Florida 33431. 1.800.334.0759
In Canada, this warranty is offered by Sunbeam Corporation (Canada) Limited,located at 5975 Falbourne Street, Mississauga, Ontario L5R 3V8
To refresh, the beeper should sound once. The definition of the Beeper from the manual follows:
BEEPERFUNCTION
(1) When you plug the unit in, the beeper sounds once and " - - - "appears in the LCD.
(2) When you press one of the four menu buttons the beeper will sound one time.
(3) When you press the adjustable button, every time you press the button, the beeper
will sound once. If you press the button continually, the beeper only sounds one time.
(4) When you press the start button the beeper will sound once, and ":" will flash, that means
the unit is in operation. Once the unit has begun the cooking cycle, the menu selection,
time or temperature cannot be changed. The unit must be stopped and reset.
(5) When the unit is in operation, press the stop button, the beeper will sound once and the unit
will stop operation.
(6) At the end of pre-set time, the unit will sound a long beep to remind you the work is done.
Jan 03, 2015 | Oster 6239 Toaster Oven with Convection...
2006 chevy Avalanche check engine code 172 & 175
the temperature sensor can cause a rich mixture at the wrong time by providing a false reading of cold engine
Sep 28, 2013 | 2006 Chevrolet Avalanche
Hi I just baught a Renault Clio with a Philips stereo in it but I don't know how to put the code in - I can see 4 zeros with the first one flashing on the aux display - I know the code but not the...
Philips Renault Code Entry (For cars with a Steering WheelRemote Control.) Note: If your car does not have this remote control, thenplease ask for alternative instructions ) Turn on the radio and the display will show 'CODE' Use the Steering Wheel Remote Controls for code entry. Press the [ ¬] button then rotate the thumb wheel for thecorrect first digit Press the [ ¬] button then rotate the thumb wheel for thecorrect second digit Press the [ ¬] button then rotate the thumb wheel for thecorrect third digit Press the [ ¬] button then rotate the thumb wheel for thecorrect fourth digit If the correct code is now shown on screen, press and hold the [ ¬] button for up to 10 seconds to storethe code ============================================================ With Compliments
Feb 27, 2011 | Philips Car Audio & Video
Flash card error appears on the screen and stops the camera from shooting
Solution 1 • Unlock focus area selector. • Auto-area AF selected for Custom Setting 2 (AFarea mode): choose another mode. • Press shutter-release button halfway to turn monitor o?¬? or activate exposure meter • Memory card is full, locked, or not inserted. • Flash is charging. • Camera is not in focus. • CPU lens with aperture ring attached without locking aperture at highest f/-number. • Non-CPU lens is attached: rotate camera mode dial to M. • Mode dial rotated to S after shutter speed of bulb selected in mode M: choose new shutter speed • P, S, A, and M modes: lower ?¬? ash. • Digital Vari-Program modes: turn ?¬? ash o?¬? Turn long exposure noise reduction o?¬? Turn long exposure noise reduction o?¬? Press multi selector up or down or rotate sub-command dial to choose photo information displayed Select All for Playback folder. Note that Current will automatically be selected when next photo is taken • Select On for Rotate tall. • Photo was taken with O?¬? selected for Auto image rotation. • Camera orientation was changed while shutter-release button was pressed in continuous shooting mode. • Camera was pointed up or down when photo was taken Use Nikon-approved card. • Card may be damaged. Contact retailer or Nikonauthorized service representative. • Delete unwanted ?¬ les or insert new memory card
Jan 28, 2011 | Olympus EVOLT E-410 Digital Camera
Whirlpool Calypso error code reads FL...
FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display. http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
Should you continue to have appliance issues or need parts or service advice, please don’t hesitate to contact us. We are at your service from 7 AM until 9 PM CST Mon – Sat!
Thanks, Ella :>)
Nov 08, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
E20 flashing mid cycle
E20 is a general error code to get to the real problem try this..
Reading Error Codes 1. Wake the washer by pressing any button. 2. Wait 5 seconds. 3. Press and hold the START/PAUSE and CANCEL buttons simultaneously. As long as the buttons are held, the failure code will appear in the display as an “E” followed by two numbers, a number and a letter or two letters. The control will beep and the Door Lock, Wash, Rinse, and Final Spin indicator lights will flash. let me know what code come up... hope it helps
Jul 01, 2009 | Zanussi ZWF1430W Front Load Washer
Error code sc 172 on ricoh aficio 2103
Hello sir; This error code is indicate video process error, may be can be reset, the procedure as follow;
press "clear mode", "107", then press and hold down "clear/stop" key for about 3 sec., until SP menu display, touch "copier sp" on screen, enter 581002 then press 1, then turn power off and back on. see what's happen. good luck !
Feb 23, 2009 | Ricoh Aficio 2022 All-In-One Laser Printer
Fatal error 172
From OKI error list:
Error 172 - Upper Heater Temp State: High
Heat Roller Thermistor indicates high temp
Solution:
Turn off printer, let cool down.
If problem still exists seek service
Mar 07, 2008 | OKI C5300n Led Printer
F4 error code on Jenn-Air W30400BC expressions built in oven
Slone, F4 is the code for a shorted temperature sensor. This is the temp probe in the oven. There are 2-quarter inch screws holding it on. It should pull out through the insulation until the quick connect comes through. If you want to make sure, the sensor should ohm out at 1143 ohms at 100 degrees. I think you can be pretty sure that this is the problem. The part number I have is 704657. Catriver.
Dec 04, 2007 | Jenn-Air JJW8527C Expressions Collection...
Kidde Nighthawk Combo Gas/co Detector Logo
454 people viewed this question
Top Kidde Home Security Experts
Are you a Kidde Home Security Expert? Answer questions, earn points and help others
