Question about Delphi NAV200 Car GPS Receiver
My gps battery after charging in the car all night when we take it off and make it portible it says low battery and shuts off
I had the same problem now it won't turn on at all. i have no idea what is wrong with it, can't find any info on computer that is helpful
Posted on Mar 29, 2010
Once the unit is charged how long does the battery run dry
Once fully charged, it will last for about 4 hours, if it is used without shutting down. The good thing is that it comes with a rechargeable lithium ion battery. That can be recharged once it is weak. I will strongly advice that you do not allow the battery run down completely before recharging as the battery might become weak and unable to hold a charge. So do not let your gps die before recharging. you can charge once it is low.
Dec 24, 2010 | Nextar X3-03 Car GPS Receiver
Low battery display comes on when it is turned on then it shuts off its self
If this occurs when running on battery power, then it sounds like you just have a dead/bad battery.
If your GPS works fine when connected to a power source, then leave your GPS plugged in to a power source over-night, and if you still have this problem...
You can check to see if your device was included in a recent battery-related recall here:
https://my.garmin.com/rma/recallLanding.faces
If your unit is not included in the recall and you are (or a friend is) handy, you can buy a replacement on the net and replace it yourself for around $25 (US Dollars):
http://vimeo.com/8387716
(There are other sources for the battery, I do know if the linked company is trustworthy.)
I'm not sure what Garmin charges for this type of service?
Oct 11, 2010 | Garmin nuvi 750 GPS Receiver
Will not power on
Disconnect the GPS from the car's cigar lighter jack and connect via USB cable directly to your computer's USB port (or use your GPS's AC adapter if included) and allow to charge for 8 hours (or over night).
The over night charge should "refresh" the GPS's battery. You should be able to switch the GPS back on to run off its internal battery at this point. Leaving the GPS constantly connected to the car's power can cause the problem you describe to happen. If it happens again, simply repeat the process.
May 20, 2010 | Garmin nuvi 765T GPS Receiver
Low Battery notice kept coming on
TRY RESETTING THE UNIT - Also - charge the unit over night with a WALL CHARGER - this helped when mine pulled that same stunt. Eventually it went away after charging it over night in the wall. Here's how to reset -it just puts everything back to factory settings - 1- Turn unit on WHILE HOLDING your thumb in the lower right corner as shown in picture. 2-Select YES 5770b9e.jpg
May 03, 2010 | Garmin StreetPilot C330 GPS Receiver
Battery gradually discharges unless forced to charge
something is wrong withe your lighter so unplug it when the car is off also you may want to do a complete charging system inspection on your vehicle
Jan 06, 2010 | Garmin nuvi 205W GPS Receiver
My gps battery says low battery and shuts off when I set it down after putting in travel info. What to do ?
Check the power on your 12v car cord. The internal batteries are low and are not being charged by your vehicle system. The fuse may be burned out in the 12v car plug.
Dec 19, 2009 | Garmin StreetPilot c340 GPS Receiver
My Garmin turns on and shuts its self off.
But it might have a very low charge or a bad battery (despite being connected to Dc) recharge the battery from AC or replace the battery
Jul 24, 2009 | Garmin nuvi 255W GPS Receiver
Plugged device into car outlet. Device comes on, shows Garmin name and then shuts off and does nothing more. Prior to this happening screen displayed "battery low".
DC power will not properly charge the battery. It is possibly damaged. Change i. Preferably charge it via AC before using on DC.
But change battery....
Jul 05, 2009 | Garmin nuvi 205W GPS Receiver
My garmin c330 will not run it had said battery low. Even in car lighter it will not stay on. When I push the power button it will power up and shut down right away
The Garmin C330 has an internal Lithum Ion battery that needs to be recharged. Use your USB cable that came with the device to connect it to you computer. The computer of course has to be on. Leave it connected to the computer all day or over night. After that time it should be charged completely. If it is not charged after that time the unit will have to be returned to Garmin to have the battery replaced.
Apr 02, 2009 | Garmin StreetPilot C330 GPS Receiver
Delphi NAV200 Car GPS Receiver Logo
87 people viewed this question
Top Delphi GPS Experts
Vernon Taylor
Are you a Delphi GPS Expert? Answer questions, earn points and help others
