Question about Bose Companion 2 Computer Speakers
Wind sound from speakers
The speakers are giving off a sound that sounds like wind blowing, which gets louder, till it drowns out any music
4 Suggested Answers
sys_admin
  • 829 Answers
SOURCE: static noise coming out of speakers
What sort of computer do you have? Is it a laptop or desktop? Many laptops have this problem and it is quite widespread in laptops. The crackling or humming noise could be a result of interference from the mains power signal.
If it's a laptop, try running it on battery alone (take out the mains power cord). My laptop has this kind of noise in speakers when running on mains electrical supply, but it goes away like magic when I run it on battery.
A more long-term solution is to buy a 'Ground Loop Isolator' and insert it between your computer and the speakers/earphones. They are quite cheap and you could get it for under £10. It removes all static noise and you'll hear crystal clear sound.
Posted on Jan 01, 2009
SOURCE: Quiet, low quality sound from one speaker, static from both
Take your fist and cram it up your ***.
Posted on Feb 16, 2009
gymowner
  • 679 Answers
SOURCE: the speakers sound goes in
Check the jack on the input of the computer it sounds like a dirty or loose input
Posted on Mar 24, 2009
It sounds distorted when the music gets louder
Time to start upgrading! Think power delivery, then amps, then speakers, then enclosures.
If you need more voltage, add batteries, capactors etc, if you're exceedingg the amp output range, you'll blow speakers (no matter what the speakers are rated for), if you have good power and the amp(s) are fine, your speakers may not be up to the task
Feb 08, 2014 | Kicker Car Audio & Video
Gt5 12 inch 275 watts how many watts of amp best?
Depends on what output your stereo is. If you underrate the speakers (speaker watts is less than stereo output), the unit will sound louder for a while, then you end up blowing your speakers with the excess distortion. If you overrate the speakers (speaker watts is higher than stereo output) the speaker will not operate correctly and the distortion can damage it also. Its best to get a close match. Slightly higher is better. It is important you know actual wattage output not PMPO ( Peak music power output) A lot of stereos are rated at PMPO. The higher number sounds great but in reality, the figure is the MAX output and by then the sound is distorting badly. Distortion ruins more speakers than anything else...
Oct 11, 2013 | JBL GT4-10 Car Subwoofer
Hi. Today I bought a 3 foot audio y-cable and an RCA (Phono) Female to RCA (Phoneo) Female cable so that I could hook up these two speakers that I have that belong to a predisian sound system (boom box)...
All you need to do is get a USB based sound adapter 16/32BIT MINIMUM to plug your speakers straight into your laptop with better sound. Many laptops will have limited sound OUTPUT which places large limitations on pushing sound through your nice speakers. You already know the problem is not the speakers or new cables, therefore you know that problem has been isolated to your laptop. You may also check the volume settings in the laptop to ensure your running the highest possible BIT or volume enhacement software. Let me know if this does the trick for you.
Jan 09, 2011 | HP Audio Players & Recorders
We are using a mounted data projector to show a DVD before a school musical program and have a hum that all but drowns out the childrens voices on the DVD. How do we hear the voices and get rid of the hum?...
One of the speakers or more than one maybe next to something is giving the speaker feedback. Try placing the speakers farther apart. A cell phone, office phone, or even a laptop could be giving feedback to the speakers. Tring moving the speakers father apart and at different locations. If that does not work you may possibly have the speakers plugged into the the wrong output outlet. Check the wiring connections to make sure they plugged in properly as well.
Nov 19, 2009 | Insignia 2.1 Speaker System (3-Piece)
The background music is louder than the voices
in the menu there should be some type of set up for this, it will most times show you on your screen a room with all the speakers in it and ask you to hit test then it will shoot a white noise type of sound around to each speaker and ask if you heard it, there are then adjustments you can make for the front, rear, and side sperkers independent of one another.
Mar 23, 2009 | LG LHT854 Theater System
Music on DVDs is louder than the dialogue.
In the Audio set up menu, see if there is a setting to turn off surround sound. I believe it's in your owners manual also. LMK
Feb 28, 2009 | Philips 32PFL5403D/27 32 in. LCD TV
Monitor making humming noise
First try moving speakers away from monitor a bit. Some speakers magnets actually reduce the life span off monitor. I hope I am wrong but usually a high pitch whine is the High voltage Transformer. Costs more than the monitor. All you can do is continue use till it goes. Speakers usually deteriorate the tube itself. HVT are just one of those parts that go due to use. Hope it gives you more enjoyment before it goes. Good luck and try to have a good day.
Jan 31, 2009 | KDS Visual Sensations 190i 19" CRT Monitor
Background sound too loud
Thank you, everyone! I thought maybe I was losing my mind. I can hardly watch a lot of the TV shows anymore due to the inappropriate use of music -- either it's too loud or there's just too darned much of it. Come on, TV producers! You are supposed to get better with time, not worse! Thank goodness I'm not alone.
May 30, 2008 | JVC AV-32260 32" TV
Bose Companion 2 Computer Speakers Logo
485 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Ben Armstrong
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
