Question about Microsoft PowerPoint® 2007 Full Version Academic License for PC (079-03434)
Transparent Images slow down in Powerpoint 2007
Hi everyone,
My company has a problem when we insert a transparent image (such as a PNG) or make an image or part of an image transparent in Powerpoint 2007. While we've narrowed it down to file size of the image playing a part in the problem, it doesn't seem to be as big a problem as the file simply having some transparency with it. An example is this, i have a JPG file without any transparency that is roughly 500k that moves smoothly in Powerpoint (moving the image around in powerpoint). Now, i've converted that file to PNG with some added transparency and the file size has actually gone down (about 200k) and the image moves very slowly in Powerpoint (moving the image around, scaling it, simply navigating the slide).
Has anyone had a similar issue and do you know if it's a problem inherent to powerpoint 2007? We've been using PNG's for years in Powerpoint 2003 with no issues whatsoever with slowdown and we are trying to upgrade to Windows 7 and the new office suite. This will be a huge disadvantage for us if we can't resolve the issue.
Thanks to anyone in advance.
Ikkenom's solution is wrong. I'm experiencing the same on bleading edge machines. It seems to be an issue overall with high res images and I think it has a lot to do with the program trying to draw a preview image to move around before it actually lets you move. Previous versions of PPT did not do this preview draw and I think that's why we could move our images right away. If anyone knows a registry value or anything else, it would be greatly appreciated.
Posted on Nov 19, 2009
    Brigadier General:
  • 10,406 Answers
Get a faster computer. Making "transparent" images work (combining two layers of images to produce the desired effect) is CPU-intensive.
Or, at least, run the PowerPoint show on the *FASTEST* computer that you can find, to see if the extra "speed" is helping.
Posted on Nov 18, 2009
Besides Gif images, what other types have transparent background?
File formats that support transparency include GIF, PNG, BMP and TIFF, through either a transparent color or an alpha channel.
Source: http://en.wikipedia.org/wiki/Transparency_(graphic)
May 20, 2014 | Adobe Photoshop Elements 7
How do I get one color of an image to go transparent in HTML Programming. I am going through the web page version of powerpoint document trying to find out how the transparent pen tool works and I'm...
you can use a css term opacity it will mahe your image transparent upto the extent you required <img src="imagename.jpg" width="150" height="100" alt="txt"
style="opacity:0.4;filter:alpha(opacity=40)" />
Nov 24, 2010 | Computers & Internet
Visual transparent lines at top of picture
You have a vertical output circuit problem. This was common for Philips' sets. Have a repair shop check it out. Should not be too expensive to repair.
Oct 15, 2009 | Philips 27PT6441 27" TV
Hi sir i did as you said to get transparent file to use for web but when i saved in gif format it's coming transparently but the object edges are not good to see, so what i have to do next? i also saved in...
Take the png pict in PhotoShop or a similar tool so you can remove edges, make a layered image without the beckground and save it as transparent.
Mar 23, 2009 | Computers & Internet
Cut image and transfer to transparent background using gimp
Hi Jody,
Gimp can be frustrating, but it's one of the most amazing and powerful free applications out there. You're right...what you're trying to do is very simple, but you need to know a few tricks to get it to work well.
First, you need to use .PNG as .JPG files don't support transparency. When you try to save a file in .JPG that has a transparency, or alpha, channel, you should be prompted to "export" the image by flattening all layers, which essentially replaces all the transparent areas with the current background color (usually white).
Second, there's a tool that's been added to the most recent versions of the Gimp that does exactly what you want to do. It's called the "Foreground Select Tool" and is really simple to use once you get the hang of it. This tool was added in Gimp 2.4, so you'll need at least that version or higher to use it. This tool uses a two-step process: first you draw a rough circle around the object you want to cut out (your daughter), then you "paint" over the foreground object so the tool can sample all the colors you're wanting to extract. This sounds strange until you do it...once you understand, it's really pretty simple. You can read the docs for this tool here. There's also a YouTube video that shows the basic process. Apparently no sound on that video, but at least you can see what to do.
Not sure what was happening when you tried to use the scissors. There are so many variables, it's hard to tell. You probably didn't need the extra step of adding a transparent layer...when you had your selection copied to the clipboard, you could have used "paste into" or "paste as new layer" or "paste as new image" to get what you want.
Let me know if this doesn't answser your question.
Eric Imboden
http://commoncontext.com
my take on tech : http://redsquiggly.com
Mar 10, 2009 | GIMP GNU Image Manipulation Program
I need to get a drawing in autocad lt 2004 into the background of the draft so when plotted out it will be alot lighter than the main linework
Transparent Toolbar Button images
To create a transparent background in the Button Editor for creating images in AutoCAD 2004 and higher. To do this you can use the Light Grey color in the lower-left corner of the swatch for AutoCAD 2002 and earlier, or the True Color 192,192,192 in AutoCAD 2004 and later.
Apr 15, 2008 | Computers & Internet
Images
if you want to import any image, it has to be saved with a transparent background, like a (.gif or .png) image.. for example if you have an image i.e plane.jpeg you need to open it in an image editing software like adobe photoshop and delete the background save the image as plane.png and import the plane.png to flash. You can edit the picture in flash also to remove the background.. but the process is not easy and its time consuming. so try that workaround like i said before let us know if it worked.
Oct 02, 2007 | Macromedia Flash MX
Microsoft PowerPoint® 2007 Full Version Academic License for PC (079-03434) Logo
353 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
